Washer will run with hot water only ( amana heavey duty washer)
Checked hoses and are fine. Replaced the valve on the back of the washer for $35 dollars and that didn't work. If we put it on hot water it runs fine but the minute we change to cold, it shuts off.
  • 706 Answers
What if you swap the hot and cold lines on the back of the washer? Does the problem remain the same? Only you get cold water OK but not hot? The test I suggested is to verify if the inlet valve for both hot abd cold are operating and by switching the hoses, the problem should switch with them if the inlet valve is not opening when it is supposed to, Please provide details on the make and model of your washer so I can look at the control circuitry to determine how the inlet valves are operated.
Regards,
Rick
Posted on Nov 25, 2008
Where is the cold water valve on amana washer
the cold water valve is at the end of the hose at the back of the machine
if the cold water pipes run outside to the garage , it is a fair bet that the water in the pipes has frozen
easy to check --take the cold water hose of the tap and see if it runs
if it runs replace the solenoid for the cold water valve
May 10, 2017 | Amana Washing Machines
Water fill and start
if the water valve is bad it will hum and no water will enter the washer,first thing is to see if it's a problem with the houseicon1.png water valve or the washer valve,shut off the water supply,reomve the water hoses from the back of washer,mark the hoses so they go back on the same way,stick the hoses into the washer or a bucket and turn the water on,if water comes out of hoses then you know the problem is just the washer,check the valve,look at the screens where the hoses connect to the valve,usually sediment gets in there and the valve on the washer has to be replaced,on some the screens can be removed and cleaned,also you say you have trouble with the lock,what's humming is it the lock or the valve,if you turn it to drain and spin will it run?you could have a bad door switch,if door doesn't latch washer won't run but most likely bad water valve
Jun 15, 2013 | Amana NFW7200TW 3.5 Cu. Ft. Front Load...
NFW7200TW hums and does not turn or fill with water
if it doesn't fill the water valve will hum,first thing is to see if it's a problem with the house water valve or the washer valve,shut off the water supply,reomve the water hoses from the back of washer,mark the hoses so they go back on the same way,stick the hoses into the washer or a bucket and turn the water on,if water comes out of hoses then you know the problem is just the washer,check the valve,look at the screens where the hoses connect to the valve,usually sediment gets in there and the valve on the washer has to be replaced,on some the screens can be removed and cleaned,also you say you have trouble with the lock,what's humming is it the lock or the valve,if you turn it to drain and spin will it run?you could have a bad door switch,if door doesn't latch washer won't run but most likely bad water valve
The cold water fill just trickles, I removed filter it was not clogged, hot water runs fine. I checked water flow at faucet, I checked for kinked hose. Did not find any obvious problem. Is there a check...
Good day,
The washer has a dual valve, Hot and cold. The cold side has failed. Valve needs to be replaced. Very common problem.
Before changing, turn off cold water supply, remove cold water hose at the machines valve, and turn on to check for proper pressure.
Dec 04, 2009 | KitchenAid KAWS850L Top Load Washer
Have a Kenmore 500, top-loading washer-The hot/cold water does not work correctly. Often, it washes it cold, and rinses in hot which is the opposite of what I want it to do. It seems to be realted to the...
It could be as simple as having the water supply hoses switched, that is, the cold and hot water hoses are connected to the opposite inlet connections on the washer.
You can check for this by feeling each hose and seeing which one is getting warm and trace it from the water supply valves to the washer and see if that's the issue.
It the hoses are connected to the proper washer inlets and they are connected to the correct water supply valves, it would appear that the water inlet valve on the washer is faulty and should be replaced.
With the complete model number for your washer, you can locate the replacement part at www.searspartsdirect.com and order one online as well, if you wish.
The site will provide you with a line drawing and parts list for your washer and the replacement is straight forward and simple for most people to do themselves. Just unplug the washer from the electric outlet and turn off the water supply valves and disconnect the hoses at the washer. Now remove the back panel of the washer and you should be able to get at the water valve.
Remove the screw(s) that hold the valve onto the washer cabinet and you can get at the wiring plug that controls the valve. Just swap it out and connect the plug and re-mount the valve to the washer and put the back on, connect the hoses, (make sure to get them on the right location HOT / COLD) and plug in the washer and turn the water back on and you should be all set!
Hope you find this Very Helpful and best regards!
Oct 12, 2009 | Kenmore Washing Machines
Does this washer even have a hot water cycle? There is a hot water hose going in and it is turned on......but how do Iget a hot wash?
If the hot water is not working, then check the water inlet valve. Unplug the machine and turn off the water. Remove the water supply hoses and check the small metal screens inside the valve. Pay particular attention to the hot water side. Make sure the screens are clear of rust or debris. Check the solenoids using a multimeter or ohmmeter and check for continuity. A lack of continuity will mean a bad solenoid and the assembly will have to be replaced. I'll attach a photo for reference. Really sorry for your trouble and I hope this helped. Best wishes.
Sep 28, 2009 | Amana NTW5100TQ Top Load Washer
No cold water, only hot
The cold water inlet line is either clogged (it has a filter screen in it) or the cold-water solenoid valve is malfunctioning.
Remove cold water line, check for obstruction -- if no success, inspect electrical connections on solenoid valve (where the cold water line attaches to the back of the machine). If valve is getting current, take it apart and clean it. If that doesn't work, replace the solenoid valve.
May 29, 2009 | Washing Machines
HOT WATER WON'T FILL TUB
most inlet water hoses have screens in them.  You could remove the hose from the back of the washer and see if there is water flow.   If there isn't, the hot water valve assembly is defective.  These are solenoid operated valves that admit water into the tub.  They can be accessed behind the washer after you remove the back.
Mar 30, 2009 | Amana DLW330RA Top Load Washer
Kenmore Elite washing machine will not fill as fast as usual.
You will need to get behind the washer, turn the water off, disconnect the hose from the washer, look for a screen inside the water valve, hopefully there is one that you can clean if necessary. I always put the hose over in the washer and turn the water on to check the flow.
If the screens on both hot and cold are clear, water flow is good on both hot and cold, connect the water back to the washer. If the flow is still slow then the problem is inside the valve. The valve will have to be replaced.
Dec 17, 2008 | Washing Machines
Amana washer has no hot water - cold works fine
There is a solenoid control valve on all washing machines, located where the water hoses enter the machine. If you have a rubber mallet, you can whack the machine gently with the mallet. If the problem is resolved, it was just a stuck valve. If not, then you likely will need to replace the whole solenoid valve control. Typically there are controls for each water supply.
Dec 04, 2007 | Amana ALW880WH Top Load Washer
Washing Machines Logo
41 people viewed this question
Top Washing Machines Experts
