Question about Tascam 2488 Portastudio Multitrack Recorder System
Unable to record or playback on new DP 02
Brand new DP 02. Followed how-to instructions page 24 of owners manual on and off for weeks. No luck. While recording, meters do bounce. On playback, tracks are empty. Is unit non-functional or am I missing something? Kept on hold when calling Tascam phone support.
    Novelist:
  • 189 Answers
It sounds like either the inputs are not assigned or the tracks are not armed for recording (or both).
Here is a quick explanation of the procedure involved in recording with the DP-02 that I posted for another person who was asking for some basic instruction on how to record. You might be missing a step somewhere along the line as for instance you will still see the meters move even if you don't have the inputs assigned or don't have any tracks armed, but the DP-02 won't record anything until you do both.
To record you need to first assign your input to a track, then arm the track for recording, and then press play + record at the same time.
1. So you would patch your mixer output, mic or instrument into an input on your DP01 (say input A). You can run some audio to set the level with the input level knob (located next to input A on the front panel).
2. Then to assign that input to a track simply press and hold the 'input A' button and then press the 'rec' button of the track you with to record on. The 'rec' button will flash rapidly to indicate that the input is assigned to the track.
(To assign the input to a different track you have to clear the input assignment from the first track and assign the input to a new track. To clear an assignment press the input assign key, A in this case, and the track it's assigned to will flash its 'rec' button. Hold down the input assign key and then press the flashing 'rec' button. The button will stop flashing and the input can then be assigned to another track by following step 2 again).
3. Next, to arm the track for recording simply press the 'rec' button for that track. The 'rec' button with flash slowly.
4. To begin recording press play + record together in the transport section and the 'rec' light for the armed track will stop flashing and light steadily. Press 'stop' to end recording.
This should get you started. The operation of the DP02 is actually pretty intuitive once you've gone through it a couple of times (which is one of the real strengths of the unit). You'll be multitracking like an expert in no time.
Hope this helped.
Cheers,
bd.
Posted on Nov 26, 2008
I have the dp-02cf and have been using it for a couple of years. It has done this to also. Input assigned, tracks armed and ready to go as usual but the signal just would not get from the input to the track! How frustrating! Song almost complete and this happens. luckily for me i was able to use the other input to complete it. Strangely, upon the next song creation, everything was back to normal. I HOPE THAT NEVER HAPPENS AGAIN!
Posted on Mar 04, 2010
Can I bypass my CD driver on my Tascam DP-02? If yes how?
I'm not sure what you mean by "bypass my CD driver", as the unit is designed to record, save, and playback what you record on it. But here's the manual -
http://www.tascam.eu/en/docs/DP-02_DP-02CF_Manual.pdf
Everything it can do is in there.
Sep 20, 2017 | Tascam Audio Players & Recorders
Does anyone have "duct" assembly instructions for Dyson DC 24? (Not the owners assembly manual)
Google Dyson. co On the drop down window, find your model, type in Dyson DC 24, at bottom of page click on shopping info, click parts. you can order from there.
Oct 19, 2014 | Dyson Ball DC24 Bagless Upright Vacuum
How do I import a CD created on the Tascam DP-02 into the Tascam DP-32?
I have the Tascam DP-02 it uses a fat 32 partition, Fat 32 partitions are pretty much obsolete replaced with the New Technology Filing System or N T F S for short. Using the DP-32 systems software try plugging the DP 32 in to your computer once the software for you new unit loads locate and open the fat 32 system folder I'm not sure if the DP 32 uses the same fat 32 partition, But if it does the fat 32 folder should be there, Locate and open it you should then be able to move or delete your recorded material as desired
Oct 04, 2014 | Tascam DP-32 Portastudio 32trk Digital...
Changing the voicemail greeting on an ATT Dect6.0 CL82209
Here is the direct link to the User's Manual for that model of AT&T phone:
http://att.vtp-media.com/ecp/documents/product_Product/129/UserManual/5985/cl82309_manual_USA_i6.pdf
To view the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents.
You can download this free at WWW.ADOBE.COM if necessary.
Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, then follow the onscreen instructions to install the software on your computer.
See page 16 of the manual for detailed instructions on HOW TO RECORD A NEW OUTGOING ANNOUNCEMENT.
The instructions in the manual basically read as follows:
To record a new outgoing announcement:
1. When the handset is in idle mode, press MENU/SELECT
to enter the main menu.
2. Press MENU/SELECT again.
3. Press CID or DIR arrows to scroll to ANS SYS SETUP,
then press MENU/SELECT.
4. Press CID or DIR arrows to scroll to ANNOUNCEMENT,
then press MENU/SELECT, the system announces, "To
play, press 2. To record, press 7."
5. Press 7 to record an announcement, the system
announces, "Record after the tone, press 5 when you
are done."
6. Press 5 when you finish the recording. Your recorded
announcement plays.
To listen to the recorded announcement again, press 2 after playback is
completed.
To record a new announcement, press 7 and follow the above steps.
I hope that was helpful to you, good luck and take care.
Joe.
Sep 13, 2011 | AT&T CL82209 Cordless Phone
My tascam dp 02 started up with this mount error message I bought a tascam dp 02 for my son for christmas. When I plug it into the mains the display shows ' mount error :oc /please pwr off'. my email is...
The TASCAM DP-02 Owner's Manual has no reference to a mount error in it. There are many people online complaining about mount errors on their computers, mac and win, when hooking the tascam up via USB, but your post suggests this error was on the DP-02 itself, is that correct?
I get less than a dozen hits of people asking this question online, and absolutely no useful answers or responses.
Do you have the DP-02CF model? If so, it may be a faulty CompactFlash Type I card that it is trying to mount. If there is a disk in the drive, I'd remove that cd in case it is trying to mount a bad disk.
I can most likely help troubleshoot a troublesome USB-to-computer connection, but otherwise I'm going to have to refer you to TASCAM customer service, (although I must say the forums I've perused have little positive to say about them.) TASCAM support in the UK (a guess, but you did use the term 'mains' in your post) is provided by TEAC UK Limited at +44-8451-302511 or www.tascam.co.uk.
Best of luck & I hope that helps.
Dec 26, 2009 | Tascam Dp-02cf Digital 8-track Recorder
I need tow download the manual for my dvd recorder which is a tevion dvd recorder Hdd with g code access. I bought it from cash converters and it doesnt have a manual
I have successfully found manuals for Sony TV and a Pioneer auto radio on Google. I entered the brand followed by the complete model # followed by owners manual. Give it a try and good luck.
Jun 21, 2009 | Televison & Video
TASCAM DP-02 (You don't even include it here in your products!)
Here's a link to the DVD tutorial for the DP-02:
http://www.amazon.com/Tascam-DP-02-Video-Tutorial-Manual/dp/B001JP6572
There is also a video on Tascam's support page for this product that you can download for free:
http://www.tascam.com/products/dp-02;9,16,3580,19.html
You can ask questions here or consider joining Tascam Forums (I think it costs $4) and talk to Tascam experts from all over.
http://www.tascamforums.com/
The DP-02 operates almost exactly as the DP-01 did, so manuals and videos for one should pretty much guide you correctly when applied to the other, but the video in the first link is the correct on for the DP-02.
Hope this helps.
Best of luck.
bd.
May 08, 2009 | Tascam DP01 All-In-One Recording Package...
New sky digibox fitted. Cannot timer record satellite programmes
I encountered a similar problem when recording and I phoned Sky and they changed my settings to eliminate standby mode for me.
No problem any more.
Mar 21, 2009 | Panasonic Televison & Video
Record, playback problem
Hi Nick,
The fuzz/white noise is a little confusing and it seems to be saying that you are recording something vs trying to record incorrectly and getting nothing at all. Anyway, despite that, I would try going over your recording steps first.
First off make sure your Hi-Z input is not set to the Hi-Z or guitar setting. It is possible your that MicroKorg is overloading the input and distorting. You should however have heard that in the headphones too, so I'm not so sure that's the problem. The next thing to check is to make sure your input is assigned to the track you expect to be recording on. (Press the input's button to check this. The select/record button over the track should flash).
Next make sure your track is armed for recording before you press 'play+record' (Record button above the track should light steady when recording).
Hope this helps.
bd.
Nov 21, 2008 | Tascam DP01 All-In-One Recording Package...
Just bought a DP-02 w/40gb hard drive
You'll first need to find some aux audio out jacks on your karaoke machine. You might need an adapter, but the basic idea will be to connect the aux out from the karaoke machine to an input on your Tascam DP-02.
Then on the DP-02 you need to assign whatever input your plugged into to one of the 8 tracks. Let's say you're using the left input (input A) and want to put the karaoke music on track 1. You'll press the 'Assign A' button on the DP-02 and while holding it then press the 'Rec' button of track 1. The 'Rec' button will flash rapidly to show its been assigned. (for reference: assigning an input is better described on page 23 of the manual). Then you'll want to arm track 1 to record. Press the 'rec' button for track 1 and it will start to flash slowly to show it has been armed for recording. Now you are ready to start recording. On the DP-02 press the large round play and record buttons on the lower right together to start recording and start your karioke machine playing. When the song is done press stop on the DP-02.
Now to record your vocals you'll need your mic to be plugged in (lets' say it's in input B). You'll need to assign this input to a free track (track 2). Press the 'Assign B' button and while holding it press the 'Rec' button for track 2 (rec button will flash rapidly). Then you'll want to un-arm track 1 and arm track 2 for recording. To do this press the 'rec' button for track 1 so that the light goes off and then press the 'rec' button for track 2 so that it flashes slowly.
So now when you press play and record together to record, you'll hear track 1 playing (the karaoke track you recorded earlier) and you'll be recording vox on track 2. Of course you'll also be recording whatever you hear in the room onto track 2 along with your singing, so in order to get a clean recording there (prevent bleed) you'll want to plug some headphones into the DP-02 and listen to those as you record.
That's pretty much all there is to it. Some variations if you wish to record the karioke in stereo vs mono (I gave you the instructions for mono here), and you may need to turn on phantom power if you have a non-powered mic, but the idea is basically the same.
Hope this helps.
Good luck.
bd.
Oct 24, 2008 | Tascam DP01 All-In-One Recording Package...
Tascam 2488 Portastudio Multitrack Recorder System Logo
815 people viewed this question
Top Tascam Audio Players & Recorders Experts
Sam Palermo
Sam Palermo
John
John
Michial Gueffroy
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
