Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
No forward progress
I have a Craftsman Lawn Tractor with a Kohler engine. When I engage the transmission, there is no forward progress initiall until it seems the oil heats up. When progress is achieved, it is slow and without power to go uphill. The balsed function well when engaged, just the transmission. Fliud has been changed regularly and fluid levels are OK. Air filer is clean.
Ken
  • 5 more comments
  • almaraz Dec 09, 2008
    I have the same tractor and it is just starting to act up like that, especially after it has not been used in a whyle. I am suspecting it to be internal in the drive unit. mine will make a loud whine and you feel it in the lever. it wont move forwards or reverse. then for no ryme or reason it will start working ok.
  • dmorrow25 Feb 01, 2009
    I just experienced a simillar problem, I have a snowblower attached on the front on my craftsman and took it out this week and the second pass around I heard a weird noise and then a grinding. The tractor only moves backward now, will not go forward and it grinds if you put it in gear and neutral, I had no trany fluid on the ground, so does anybody have any idea what it could be and where do I start, buy a new transaxle or try to have somebody rebuild the existing one?
  • JERRY ABELL
    JERRY ABELL May 11, 2010
    hello! you took the time to ask question. i took the time to answer your question. could you take the time to rate the answer. thank you.
  • Al Perry May 11, 2010
    Can you push the tractor easily in neutral?
  • JERRY ABELL
    hello! yes is it a belt drive or a hydraulic system; could you find time to answer the question!!!!!!!
  • Antonio Boscia
    Antonio Boscia May 11, 2010
    is it a belt driven system or a hydraulic drive system?
  • Captian Bill Aug 28, 2013
    there is a button on the console between you legs. It operates the parking brake. If the brake is stuck in park, the little spring came off the rod that controls the brake making it stick in park. Look under hood and move the switch back and forth and you will see the rod move
  • 40 Answers
Seems that your clutch needs adjustment, no biggie here. Get your needle nose pliers and a spare ¼ inch bolt or pin. A small Philips screwdriver will also work. The needle nose pliers are for removing the cotter pin and the screwdriver (or bolt) will hold the brake lever in place while you make the adjustment. Then, check under the right side of the deck (side where the grass discharges) right under the plastic mat where your foot rests and next to the tractor's frame you will see the brake lever with the long spring attached. Have a helper move the brake/clutch pedal so you have a better idea of what's going on down there. Then:
1. Remove the cotter pin, washer, and brake spring from the
adjustable nut
2. Disconnect the adjustable nut from the brake lever assembly
and the parking brake latch.
3. Align the hole in the brake lever with the hole in the frame. Hold
the brake lever in place with your 1/4 inch pin, bolt or the screwdriver.
4. Pull the clutch rod forward until tight. Turn the adjustable nut
until the nut will fit through the hole in the brake lever.
5. Assemble the adjustable nut to the parking brake latch,
brake lever and brake spring. Fasten with the washer and
cotter pin.
6. Remove the 1/4 inch (6 mm) pin, bolt or scredriver.
That should return everything to normal. Assuming that there are no broken or bent parts in your clutch mechanism.
These are the general instructions for this type o tractor. If you find any discrepancies in the description of parts or location of mechanisms, please consult the owner's manual of your particular model under “How to check and adjust the clutch”.
I hope you find this solution helpful. Please rate it and thanks for using Fixya.
Posted on Nov 05, 2009
    Scholar:
  • 138 Answers
First thought would be the brake sticking or the belt slipping, but then you said the fluid has been changed regularly [i'm guessing this is a hydro trans?] did you change it? what fluid did you refill it with? most hydros use regular 10w-40 motor oil, few use ATF. you could have some air in the hydraulic system and that will cause loss of power. to purge the air, pull the trans bypass rod out, start the engine, release the brake and move the shifter slowly to the forward position, then slowly back and to reverse, do this about 10 times, it should purge any air trapped in the system
Posted on Aug 17, 2009
I drove my mower into my shed after the last use and now I cannot get it to move either forward or backward, even pushing it
Lift left hand foot pedal to full extent with top of foot may find that it is not engaging idle pulley, may be time for a new drive belt
May 30, 2015 | Craftsman YT 3000 42" Kohler 22 hp Gas...
Started craftsman lawn tractor 24 hp kohler engine drove it a few feet engaged blade clutch and mower stopped. disengaged blade clutch tried to restart . engine turns over starts runs few a few seconds and...
You should be able to push it forwards as well as backwards. I had a similar problem (engine stalling) with mine. I found out if I half choke it, it will stay running. Transmission may still have a problem.
Jul 29, 2017 | Craftsman 24 Hp 48" Deck Yard Tractor
I have 2001 Husqvarna lawn tractor model YTH1746 wnt go into gear
those fluid drive transmissions fail on quite a few brands as they all use the same ones....replace the trans...they are expensive but still cheaper than a new mower.
Jul 21, 2010 | Husqvarna Ariens 46 In Deck 20 HP Kohler...
The tractor will not go forward or backward it starts right up but will not engage
1) The drive belt between the engine and transmission has broken or jumped off a pulley.
OR
2) Your hydrostatic transmission is dead.
DO NOT STICK YOUR FINGERS UP INSIDE A RUNNING MOWER TO SEE IF THE DRIVE BELT IS MOVING.
Jul 01, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Lawn tractor forward movement problem
Check the adjustment from the lever to the transaxle, if the linkage is ok the transaxle may be suffering from age and has leaking internal seals.
Jun 03, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
The transmission will not engage,
it is possible that there are no parts missing - reach in and push the "rod end over the rear axle doesn't move the lever" lever forward - the brake is sticking in the "on"position - wiggle the lever back and forth, if it moves more than 1/4 inch, use a half inch wrench to tighten the nut holding the lever until the lever has only about 1/4 inch movement
Jun 14, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Loss of drive in a Craftsman Lawn tractor
I also have a Craftsman tractor with the same problem. Sears repairman said it needed a new transmission and it would cost $1,400 to install. A new one is about $1,000. Anyway, if you remove the battery and the battery tray under the seat it will expose the transmission fill hole (hex). I opened the top and it looked empty. I had a bottle of 90 weight gear oil in my shop and filled the transmission to the top. I have not had any problems with it since. $4.00 bottle of oil verses a new tractor is worth a try.
Mar 30, 2009 | Craftsman Garden
No power when drive is engaged
Hi
Check your drive belt and the tensioner pulley that holds tension on the drive belt. Its possible for the tensioner pulley to be sticking and not putting enough pressure on the drive belt causing it to slip.
Grab hold of that tensioner pully and make sure it moves in and out freely against the drive belt.
Nov 25, 2008 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Will not go into gear
a hydro uses a foot pedal on the right side , you push forward to go forward or rock the pedal rearward to go in reverse - a regular transmission has a shifter usually between your legs for reverse 1st 2nd or 3rd gear - you also said the blades wont engage . are they electric ( with a switch ) or do you manually move a lever .
Oct 23, 2008 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
619 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
