Question about Philips Magnavox 50ML8105D 50" HDTV DLP TV
I HAVE A BIG SCREEN SONY MODEL 9105953 53" THE PLASTIC SCREEN ON THE FRONT HAS CRACKED THE BLACK FELT BEHIND THE PLASTIC IS FIND AND THE LAMP IS FINE WHERE CAN I GET A REPLACEMENT PLASTIC SCREEN FROM? hOW MUCH WOULD THAT COST? or what else could i use to replace it with? i need the plastic cover that goes over the screen. it is an older model.
    Champion:
  • 240 Answers
Allrepair has the screen you need
thier phone is 719 687 6997
Posted on Jan 14, 2009
JUST PURCHASED A NEW LAMP HOW DO I CHANGE IT
Lamp are pretty easy to change. Your lamp is mounted in the front of the TV.
On the back side of the T by the screen you will have 2 big plastic screws. You need to unscrew them. You might need to use a quarter to get them started.
Once the screws are loose then you need to go to the front of the TV and pop out the bottom front panel. This is where the power light is. Don't be afraid to apply pressure when trying to pop it out.
Once the panel is off you will see a door with another plastic screw.
Open the door and you will see the lamp. The lamp will either be screwed in or held in by a latch.
Remove the lamp and insatlee the new lamp.
Reassemble everything and turn the TV on
Go into the user menu and reset your lamp timer and you are done.
Good luck to you.
Mar 20, 2013 | Sony Lamp/bulb For Kf-50we620, W/housing,...
Everything is working well except gaining access to the second screen. Pressing the advance key takes the first screen away then brings it back to the front, wihtout stopping at the second screen. The...
I still had both pieces of felt on mine and it failed like that. I took Ross' advice and just put a piece of electrical tape over both pieces of felt, a bit more than twice as big as what he suggested, and it worked fine. Easy access for me was to remove one of the back panels (4 screws) and then turn the unit on and then off when I saw the felt (in your case it may be where the felt used to be).
Thanks Ross. I found this thread by clicking on windledom in a different thread.
Sep 01, 2011 | Panasonic Panaboard KX-B530 Graphic Tablet
I am trying to replace the tv lamp on Sony Wega 50 Inch TV; Would like to know where lamp is located so I can replace.
on some models there is a cover on side of tv remove in reach in side (MAKE SURE UNPLUGED FIRST) ther is an other cover(SAFTY COVER )in side with a leaver on it turn ant-clock wise and pull out now reach in and feel for finger ring lift up and pull out lamp and change to put back to gether is revrse make sure to lock SAFTY COVER
UNPLUG
the other model is behind cover on frount of tv to get this off on each side of tv ( BACK CORNERS ) there is two big black srews that can be opened with coin unod they will not come out all the way
then pull the frount cover start at ends of tv ( IT NEEDS A SHARP PULL ) to releace clips then pull middle
once removed you will see a gray cover with big black screw( SAFTY COVER ) undo and remove next you will need ALEN KEY undo two bolts they will not come out all way and pull out lamp replace and revrse above
Dec 04, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
The unit turns on and works perfectly for 5-10 minutes then the screen goes black and the sound turns off. I removed the back panel, blew off the dust, and checked the fan. The problem still persists. Sony...
Howdy,
It sounds like your Lamp is bad, part number XL2100.
To replace Lamp:
1) Loosen the screws on rear panel (2 thumb type screws on either side of TV, just behind front panel/spreaker grill).
2) Remove front panel.
3) Loosen the screw with coin or similar object to remove Lamp cover (near left hand side).
4) Loosen the 2 screws that hold the Lamp, then pull out Lamp. Don't force Lamp it should go in easy.
5) Replace the new Lamp and tighten the screws, reattach Lamp cover & tighten screws.
6) Reattach front panel cover.
7) Tighten screws for front panel cover in it's place.
Good Luck, Big Irish.
Dec 02, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
BULB OUT
Part number for this model (2004 model) is: A1606-034B ---IT IS ALSO CALLED A XLU2100U and retails from Sony for $200 although you may be able to find it on the internet for less.
First: have the set turned off and then unplug:
The front grill under the screen has to be removed; you will find on either side on the back a single plastic black wheel you can back out by hand.
The front grill pops out(they do not come out gently) start on one side and pop it out from the pegs that hold it in.
Behind the grill is a plastic door marked and held in with a screw. Remove the the door and you will see the square black cartridge with a handle----it is secured in place by two allen bolts that you back out until they are free. grasp the handle and the lamp will pull out(a new lamp from sony comes with the allen wrench included.
MAKE SURE YOU GET A ORIGINAL SONY LAMP--the generic ones on the internet are no bargain.
I do this here for free so if this helps you give me a vote here.
Aug 21, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Changing the Lamp
Hi, they are all a little different but 95% of all Sony`s require you to remove the plastic panel just below the bottom of the screen, your owners manual has the procedure, if you don`t have it you should download it from the sony site. Basically there are either velcro or long plastic plugs that hold the plastic panel into the set, be sure to check for several screws that sometimes need to be removed just behind the bottom front cover, hard to explain over the internet, best to get the owners manual and follow the correct procedure for your model, hope this helps, video-tek
Jan 25, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
NVLR333ETOWB HOTPOINT DRYER EATING CLOTHES
I have the same dryer doing the same thing. Open the door and take the two screws out and lift the top. Remove the two screws that hold the front on. Remove the front. On mine both the plastic parts that stay on the front when it is removed are cracked and needing replaced. I found over 20 buttons that the dryer had pulled off clothes stuck in the front door. I'm sure if it will be cost effective to buy both these parts or not.
Jan 13, 2009 | GE DBXR453EV Dryer
Screen
yes you can remove the screen by removing the front plastic trim and the removing the screws that hold the screen in. clean the screen and put it back together.the front plastic trim should just pop off
Aug 30, 2008 | Sony KP-51HW40 51" Rear Projection...
Replacing Lamp
you're supposed to loosen the 2 big plastic looking screws on the bottom back of the screen. there should be one on the bottom right & bottom left. the ones on my tv were easily taken off with my hands. after you do that, go to the front of the tv. take off the bottom plastic piece below the tv screen. it's stuck on with a big magnet. tug @ it.
May 29, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Philips Magnavox 50ML8105D 50" HDTV DLP TV Logo
160 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
