Question about Frigidaire Refrigerators
Water accumulation in bottom of freezer in Frigidaire FRS26ZSHB5
Over the past 2 weeks water (which freezes to ice) has accumulated in the bottom freezer portion of our side by side fridge. It looks like the water comes from the back of the inside of the freezer portion. The door on the freezer side has the water and ice dispenser. What is the most common cause(s) and can I fix it myself?
  • Sara Whitfield
    Sara Whitfield Jul 25, 2012
    I had the same problem, but, I noticed the ice build up where the light bulb goes, at the end of this attachmen
  • Sara Whitfield
    cont: t there was an inch thick layer of ice and the end of the drain pipe it was plugged up with ice
    Sergeant:
    Champion:
  • 291 Answers
Take out everything and at the lower inside back of the freezer you have a drain ..... pour hot water till it opens / the water comes from you evap when it goes into defrost and it cant get out the drain / Larry
Posted on Nov 25, 2008
Water puddle on floor from inside refrigerator could it be defrost heateris bad? water accumulates in the bottom of freezer and freezes seems to come out of evaporator/fan location
unkink the drain hose...I just opened up the back of my Frigidaire Side by Side counter depth to find the drain hose was bent and collapsed coming right out of the bottom of the freezer and the pan was dry as a bone. It doesn't look like my drain hose has ever drained a drop of water. The freezer bottom is full of ice And the rust and chipping paint under the bottom of the freezer door along with the mysterious puddles of water every morning means the drain system definetely never worked. Frigidaire should be responsible for this. This, along with the ice maker rebuild I had to do,... after ice was spilling all through the fridge. I actually had warrantty left on that one and called customer support in India to find out I could make the repair myself. Yep I had to do it. Frigidaire you failed.
Jun 12, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
Water is accumulating and freezing on the bottom of the freezer
YOUR DEFROST DRAIN IS PLUGGED, YOU NEED TO REMOVE THEBACK PANNEL THE DE-ICE THE BOTTOM TRAY TO FIND A HOLE, YOU NEED TO CLEAN IT OUT UNTIL YOU CAN RUN WATER THROUGH IT.
Apr 26, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water pools and freezes at bottom of the freezer. When tray is full water leaks out of freezer onto kitchen floor.
I am uncertain as to what you mean by "when tray is full"? However, you probably have a clogged drain in the freezer compartment. During the defrost cycle, which usually occurs every eight hours, defrost components (defrost thermostat & heater(s) ) melt the ice that has accumulated on the evaporator coil in the freezer compartment. The water from the melted ice drains through a hole in the freezer compartment (behind the freezer's rear panel) and accumulates in a drain pan below the refrigerator. This water should evaporate over time, whereby you should not have to regularly empty the drain pan. If the drain hole is clogged (usually from algae or other debris, etc.), the water finds another path to flow (which is inside the bottom of your freezer compartment). This water will usually freeze. Water will then flow toward the front of your freezer compartment and out of the door on to the floor when you open the door.
Contact an appliance service company to unclog your freezer drain. Also have them check your defrost components (thermostat & heater(s)).
Feb 15, 2010 | Frigidaire Refrigerators
Water under the crisper
it needs a good de frost now as a chunk of ice develped in a line. un plug fridge, let it warm up, use the chance to give it a good cleaning. this should solve the problem.
Nov 04, 2009 | Frigidaire 20.6 cu. ft. Top Freezer...
We have a side by side Maytag refrigerator. Model # MSD2758DRQ Serial # 14043813YU. The bottom of the freezer is accumulation water and freezing. We turned the ice maker off, and it continued to accumulate...
your drain in the freezer is plugged or frozen ...remove the back panel and pour HOT water down the drain until it runs thru.... hope it helps
Sep 20, 2009 | Refrigerators
Water is accumulating inside the bottom of the freezer.
Hi, The defrost drain behind the rear freezer panel is plugged. Remove the rear panel and clear the ice away from the drain. Then you will need to flush the drain hole with hot water to make sure it is open.
Some models require an after market drain heat kit.
Please get me your model # and I can look this up to let you know if you need that heat kit.
Thanks
Vic
Jul 13, 2009 | Frigidaire FRS26R4A Side by Side...
Water accumulates at the bottom of the freezer unit and leaks
You must clear the drain of anything that would cause water to pool up after each defrost cycle. Check your door gaskets for wear. Air entering the ice box can cause excessive frost.
Jul 06, 2009 | Refrigerators
Ice in the bottom of frigidaire side by side frost proof freezer
take all the bottom shelves and baskets out of the freezer. look at the back wall of the freezer. youll see a block of ice in a metal pan looking part at the bottom of the rear panel. there is a hole in the bottom of that pan. thats the defrost drain. its clogged. use a hair dryer to get all the ice out then use hot water to flush out the drain hole.
Nov 28, 2007 | Frigidaire FRS3R5EMB Side by Side...
Refrigerators Logo
310 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
