Question about HP Computers & Internet
I need to put in new print ink and can't get old cartridge out
    Scholar:
  • 174 Answers
Press it downwards and then pull it out
Posted on Nov 25, 2008
How do you change the black cartridge in the printer epson stylus nx115
Here is the Link showing instructions below. If you find this helpful, pls rate me.
http://files.support.epson.com/htmldocs/nx110_/nx110_ug/wwhelp/wwhimpl/js/html/wwhelp.htm
Replace Ink Cartridges
Your Epson Stylus NX110 Series and its software will let you know when an ink cartridge is low or expended.
If ink is low, the ink light flashes. You can continue printing until a cartridge needs replacement.
If a cartridge is expended, the ink light stays on. You must replace the cartridge to be able to print.
Warning:
Keep ink cartridges out of the reach of children and do not drink the ink.
Note:
If you need to change a cartridge before it or any other cartridges are low or expended, run the Ink Cartridge Replacement utility.
You cannot print or copy when an ink cartridge is expended even if the other cartridges are not expended. Replace any expended cartridges before printing or copying.
Leave your old cartridges in the Epson Stylus NX110 Series until you are ready to
replace them to prevent the print head nozzles from drying out.
When an installed ink cartridge is more than six months old, you may need to replace it if your printouts do not look their best, even after cleaning and aligning the print head.
Follow the instructions in these sections to check and replace your ink cartridges:
Check Cartridge Status
Purchase Epson Cartridges
Replace Cartridges Using a Printer Software Utility
Remove and Install Cartridges
pls rate me. Thanks and Good Luck...
Jan 23, 2010 | Epson Stylus NX115 All-In-One InkJet...
Dell J740 won't print black text - the page is blank - have reinstalled it and put in new ink - goes thro motion of printing but only prints any colour parts (its 5 yrs old) PC is dell inspiron (1yr old)...
Are you using a factory new ink cartridge?
Please consider the following:
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
Don
Nov 18, 2009 | Dell J740 InkJet Printer
CANON PIXIMA IP5300 cartrage problem
I can suggest you one thing. If you can't do it yourself, get a friend who can.
Make a small hole (using a drill) in a new cartridge. This hole should directly go to the ink cartridge. (Make sure you don't spill ink everywhere!) Make a similar hole in the old cartridge. Take a syringe and pull out some ink from the new cartridge. Put it into the old cartridge. If you can see the ink level, fill about half of the old cartridge this way. Close both holes. Now use the old cartridge in the printer!
(You can repeat this process whenever the old cartridge runs out of ink).
Aug 13, 2009 | Canon Office Equipment & Supplies
Put in new ink cartridge -- won't print
Try lifting up the cover. If the ink level is low in a print cartridge, the Print Cartridge Status light stops flashing. If the problem is not related
to low ink, the light continues to flash after the cover is opened. It might be that the new cartridge is defective. Check the connections and see if there isn't anything keeping it from making contact.
Jan 26, 2009 | HP DeskJet 920c InkJet Printer
Black ink won't print
Any tape/plastic left on the contact points on the cartridge, or any dirt on the contact points on the cartridge or cartridge holder? Will your old cartridge work, except poor print due to empty of ink? If so your new cartridge may be broken.
See if you can try a cartridge known to work in your printer and also try your cartridge in a printer similar to yours to eliminate source of error.
Mar 13, 2008 | HP DeskJet 3930 InkJet Printer
Print cartridge error .
check the contacts, make sure they are clean and compare to the old cartridge.
Put old one back in to see if message goes away, if it does then the problem is with the cartridge itself (defective chip or contact).
Nov 07, 2007 | HP PSC 1315 All-In-One InkJet Printer
Ink cartridge error
Check the date on your ink cartridge.  I bet it has expired.  If you put in a "new"cartridge but it is even an HP one with an older date, it may not work.
I had my printer stop in the middle of a print job.  It was printing fine and suddenly would not print.  So I refilled the cartridge with an ink kit I had on hand and reinserted it--no go!  Then I opened a remanufactured cartridge I had bought some time ago and inserted it.  No go, despite the fact I could see ink coming from the jets.  I finally gave up and bought a new HP ink cartridge, and it worked just fine.  But it bugged me why the new one would work and the other two that seemed just fine would not.
Later I learned that HP has a chip that reads the expiration date on the cartridges and that is what keeps those old ones from printing.  I found one trick of setting my date on my computer back to a year earlier than the exp date on the cartridge.  I saw the date on the remanufactured one I had tried earlier was 2005, so I set my computer date to today's date but year 2004.  After forcing me to do print alignments several times and take the remanufactured cartridge out and put it back, I got it to print just fine.  And that 2005 cartridge that would not work earlier is what I am printing with right now.
Oct 16, 2007 | HP PSC 1210 All-In-One InkJet Printer
HP 1350V all-in-one
Hi, You need to get a new ink cartridge. It is really not recommended to refill ink cartridges but if you do then it is advisable not to exceed 3 times because it could damage the printer head. If the new inks still gives error, then your printer head may need to be checked to see if it needs replacing. Good luck!
May 25, 2007 | HP PSC 1350v All-In-One InkJet Printer
Computers & Internet Logo
13 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
