Question about Kenmore Dishwashers
Water drains to drain air gap on sink
The washer still performs but when emptying it drains to the air gap piece on the sink.could that mean a clog? and how do I go about clearing that? Not rinsing correctly also
John
  • jonflylv24 Nov 25, 2008
    Hi Rick
    Thanks for the info,but I must tell you I am an ignoramus when it comes to fixing these type of problems.My Garbage disposal obviuosly is under the sink, please tell me where the connections are that you mentioned and I give it a shot.its just that I dont want to unhook the wrong connectors
  • 706 Answers
Hi John,
From your description, it sounds like the line going into your drain system ( through the garbage disposal or directly into your drain itself) may be restricting water flow.. A quick test would be to detach your drain hose and cycle an empty dishwasher but run the drain water into a rubber barrel so as to eliminate your drain system from being the root cause. If it doesn't drain correctly into a barrell, then you may have a clogged filter or an something in the pump ( including but not necessarily the problem.. a bad pump) Try this test and let me know what happens..
Regards,
Rick
Posted on Nov 25, 2008
  • Rick Gelin
    Rick Gelin Dec 08, 2008
    Hi John,
    I've been away for a bit and hadn't checked back for comments until today. If you haven't gotten any further with your dishwasher problem by now, then I can provide a bit more incite into where things are hooked up, Once you gain access under your sink, look on the side or the back of your garbage disposer for a stub that would allow a hose to be clamped to it ( they are usually near the top of the garbage disposal and you should see a skiny hose claped to it ( sometimes they use adapter fittings to get the right hose to fit,... You should be able to unscrew the hose clamp and simply slip the hose off the stub...for the test.
    I am thinking that you may have already determined that and solved your problem by now.. and hope you have.. Get back to me if that isn't true..
    Regards,
    Rick
Whirpool dish washer has water coming out the air gap when flushing out of dish washer
I think you have a clogged line. the drain from the dishwasher goes up to the air gap and also into your sink drain pipe.
hope this helps
Jul 05, 2012 | Whirlpool Dishwashers
The washer will not drain after the rinse cycle
Three main causes for water not draining are listed below:
  1. Clogged drain tube - exhaust or relief tube the hose empties into (does not apply if hose empties into a sink)
  2. Clogged drain hose - occasionally, debris from the wash will find it's way into the hose and clog, backing water up into the machine
  3. Clogged drain pump - like the drain hose, debris gets jammed into the pump. It may take a while for the pump to accumulate enough debris before it clogs. Disconnecting the hose under the washer will occasionally leave enough room to dig out any clogs in the pump. If not, the pump may need to be removed to clear the obstruction.
Jul 24, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
My Bosch shx46A05UC no longer will drain.....it
I ran into the SAME problem with my Bosch SHX46A06UC /21. The problem ultimately ended up being a clog in the air gap vent, (meaning, SOMEBODY ran the dishwasher without the bottom filter being in place or not in place properly). Remove the air gap cover and upper surface nut to drop the air gap vent into the area under the sink. Disconnect the hoses from the air gap vent filter (placing a bucket under the hose from the dishwasher). Run the drain cycle on the dishwasher. The washer should drain into the bucket and let you know that your pump works and that there are no clogs or kinks in the drain hose. (This will also remove the clog if so). The air gap vent's smaller hose connection is MOST LIKELY where your clog is. Look at the upper end of the air gap vent. You'll see a couple of clips on opposite sides of each other, that hold the air vent cap in place. Using a small screwdriver, (or your hands if you can), depress the clips (or one at a time) to get to the point where you can pull the vent cap off the filter. Either use water or a thin, long blade screwdriver to force any objects out of the filter. You should now have full flow through both branches of the filter. Using water and a rag, clean the vent cap and filter. Mount the air gap vent filter back onto the sink. Reconnect the hoses and remove the dishwasher's internal filter(s) and clean them as well while you're at it, making sure to remove any debris that might remain underneath the filter and has the chance of clogging the unit again.
Run the washer again to test. You should be good!
Cheers!
Oct 13, 2009 | Bosch 24 in. SHX46A05 Stainless Steel...
My Culligan RO faucet has an ''air gap'' leak. How do I clear the clogged debris causing the water to constantly run? Culligan told me that the Faucet/Air gap is clogged. Need to dislodge the debris.
Normally when it leaks out the weep hole the drain line is plugged under the sink....turn off the ro to where it's not making water, disconnect the drain hose and flush it out....make sure the adapter that's connected to the drain pipe is still lined up with the hole if it was moved the water can't get to the drain.
Mar 17, 2009 | Culligan Under Sink Water Filter
Washer won't spin and drain
Sounds like your drain poump is failing. It's spinning lighter loads but not able to take a full load. I woule definately replace the drain pump,
Feb 28, 2009 | Frigidaire Washing Machines
Maytag Model WU482 Dish washer completes cycle but dishes remain dirty and water is laying in the bottom.
Check the hoses and air gap for clogging. Air gap is located under the sink between housing seawar line and dishwasher hose.
If no help check/replace drain valve
http://www.partselect.com/repair.aspx?appliance=dishwasher&part=replace-drain-valve
if no help drain pump might be faulty.
Good Luck
Feb 25, 2009 | Maytag 24 in. PDB1420 Built-in Dishwasher
Dishwasher does not drain completely, has standing water after every complete cycle.
  • Some water, usually one to two cups, remaining in the bottom of the tub is normal. However, if water is covering the bottom of the tub, the dishwasher is not draining properly.
  • Check for paper or large objects covering or blocking the sump area in the rear of the tub.
  • Make sure that the right type and amount of detergent is used: Using the wrong type or too much detergent can cause sudsing that can prevent the dishwasher from draining. Only detergent specifically designed for automatic dishwashers such as Electrasol®, Cascade® or Cascade Complete® should be used. If you find suds in the dishwasher.
  • Check disposer plug. If a garbage disposer has been recently installed, it is possible the disposer drain plug was not removed. The drain plug is a plastic piece in the disposer that blocks the hole where the dishwasher hose connects.
    Please consult the Owner's Manual. Download a free copy of the Owners Manual and/or Installation Instructions. In the Installation Instructions, will be the procedure for removal of the drain plug. You may also check with the installer.
  • Be sure the kitchen sink drain is not clogged. The dishwasher typically drains into the kitchen sink drain or a garbage disposer. If the dishwasher drains into a garbage disposer, run the disposer to clear the drain system. Do not put hands into the garbage disposer. Serious injury could result. You should always turn on your garbage disposer prior to running the dishwasher to clean out any food or debris within the drain system.
  • Check drain hose where it connects below the sink for blockage or a kink in the hose. New dishwashers come with a white corrugated drain hose, which should be used. Re-using old, worn out drain hoses may promote kinking and blockage. If it is neccessary to extend the length of the corrugated drain hose, be sure the total length does not exceed 120 inches and the extention used is not kinked or crushed. See your dishwasher installation instructions for details.
  • Check the air gap if one is installed. It could be clogged. An air gap (not part of the dishwasher) is usually located on top of the sink. Some state or local plumbing codes require the use of an air gap between the built-in dishwasher and the drain system of the home. This plumbing device is used to prevent the possibility of back flow into the dishwasher in the event of a clogged drain system. This item is not a part of the dishwasher and, therefore, the dishwasher warranty does not cover costs related to cleaning or repairing a drain air gap.
  • Typical air gaps are easy to inspect and clean. Be sure the dishwasher latch is in the OFF position or unlatched prior to removal of the drain air gap cover. Simply lift off the cover (usually chrome, could plastic) and unscrew or unsnap (depending on type of air gap) the plastic cap below. Remove any material that may have accumulated and replace the plastic cap and chrome cover. This simple procedure should be followed any time the dishwasher fails to drain properly.
    View a short video about cleaning the air gap:
    Play Video
    Sometimes perceived "no drain" problems are not "no drain" problems at all, but back flow of water from the sink or some other device into the dishwasher:
  • If you notice dirty water building up over time in the bottom of the dishwasher and do not have an air gap, make sure you have a high drain loop. A high drain loop is created when the drain hose is makes a loop at least 18 inches above the floor. Usually this is accomplished by attaching the drain hose to the underside of the countertop. Without a high drain loop or air gap, dirty water from the sink can flow into the dishwasher. The high drain loop prevents back flow of water from the drain into the dishwasher if an air gap is not installed. View a short video about a high drain loop:
    Play Video
May 08, 2008 | Dishwashers
Diswasher airlock
By the airlock , you mean the air gap? .If the water is coming out of you air gap that means the hose that connects the air gap to your drain is clogged or your drain itself is clogged.Check the hose that connect the air gap to your drain(or disposer), check air gap and clogged disposer opening
Dec 01, 2007 | Bosch 24 in. SHU66C05 Stainless Steel...
Dishwashers Logo
83 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
