Question about Amana Heating & Cooling
I have 15 year old Amana horisontal furnace model gsc075a30a. it was working fine till the exhaust fan cracked and needed replacing. I have done that and the fan works good but I had to bypass the pressure switch witch is not engaging. can't seem to find a replacement switch. Any suggestions?? Regards Jack
  • gcbspoke Jan 17, 2009
    We have the same furnace. Just recently replaced the inducer motor blower. There was water also found in the pressure switch tube that would stop the furnace. We had someone come out and put the pressure switch higher and it was working fine, until today. You can hear the blower motor running, but nothing is moving and furnace wont click on. Any suggestions, does this have to do with the pressure switch too?
  • 1,420 Answers
If there are markings on the pressure switch as to what pressure it closes at, you may be able to substitute another brand pressure switch. Amana is made by Goodman. Maybe you can cross reference the switch with a Goodman distributor. Try Amana parts at 1-407-699-5411.
Posted on Nov 28, 2008
15 year old bath fan/light noisy. rectangular 2 bulb model 164A-D
Could be that dirt and dust have collected on the fins over the years and are throwing them out of balance. You could try cleaning the fins on the fan.
The bearings may also be wearing out.
15 years is a good life for a fan.
May 03, 2008 | Broan-NuTone N-8664RP Combination Light...
I have an 11 year old natural gas forced air furnace--a Goodman GMPN100-4 Rev B, which is 100K BTU and 92% efficient which was working fine at the end of last winter. I went to turn it on for the first...
You are correct. If the inducer motor is warm, but not running, it has seized up. If you replace this yourself, I also suggest that when you replace the inducer fan, check to make sure the secondary heat exchanger isn't clogged, or the condensate drain(s). If you have an HVAC contractor replace it, he should do this for you. It shouldn't run more than $350, to have it replaced and he can check for clogs (The price I'm quoting is for standard hours).
You can check this yourself by running the inducer fan without it being attached to the furnace, then attaching it to the furnace. If you notice a significant reduction in airflow, then you have a clogged secondary heat exchanger. I've run across this situation before on this particular model. The owner recenly replaced the inducer motor, but couldn't figure out why he was still having problems. I suspect the clogged heat exchanger contributed to the inducer motor to failing previously, and feel It would definitely be worth checking while you have the fan removed to help eliminate any future problems that could result from this, including heat exchanger failure. The manufacturer of this unit actually recommends you clean the secondary heat exchanger every year, but this is overkill if your furnace was installed and set up properly. I'd recommend doing it every 10 years and you're at that mark now. Instructions on how to do this are in the manual for this unit if you have it. Otherwise, e-mail me at wheels38_97@yahoo.com and I can send you a copy.
Finally, check the limit and flame roll out switches after replacing, as they could have tripped when the motor failed.
Oct 22, 2010 | Heating & Cooling
Furnace unit to be louder now than last season
Check your air filter, make sure all registers are open full and there is no restriction in all ducts. Could be an unbalanced fan, clean the squirll cage fan with a brush and vacuum.
Jan 09, 2010 | Heating & Cooling
The fan motor went out and the furnace is not even 5 years old.
I have an Amana High Efficiency furnace that I purchased 5 years ago this past October (2009). My furnace started making a horrible noise last night and then stopped working. The repair person, told me my draft inducer motor needed replaced, and showed me where the plastic fan blade inside of the inducer was "chewed up." Of course my first question is, "How can a 5 year old furnace need such a costly repair already?" The only answer I received is that it will cost me close to $500.00 to have the situation remedied (service call, parts, labor). I started looking around on the internet today, and discovered that high efficiency furnace inducer motors are usually encased in plastic and the motor fan blades are made of plastic rather than metal like the lower efficiency models. Turns out that these plastic blades over time can't withstand the high heat generated and in time (they estimate 3-4 years) break. The damage to the blades causes an imbalance in the way they spin, which in turn, generates the resulting problem of a damaged draft inducer motor. Appears this is a design flaw. Yeah! I'll say. I spent $3100.00 for a brand new furnace and 5 years later I'm paying another $500.00 and apparently can look forward to doing the same in 3-5 more years! Maybe this answers in part your question?
Dec 07, 2009 | Goodman Furnace Draft Inducer Blower ...
Amana Air Command 90 - Model GSC075A30A
water should never reach the nipple for the pressure switch tubing on the IDM. Check the entire condensate drain system for obstructions. Verify water makes it from the furnace location to the outside drain. Flush p-traps and any anti-siphon devices thoroughly.
Jan 17, 2009 | Heating & Cooling
Furnace dont have heat
pressure switch stuck take off hose **** on it then put back on
Dec 21, 2008 | Amana PTC153B35AE Air Conditioner
150000 1974 national gas forced air furnance does the fan come on the same time the gas comes on. ...
not familiar with that particular model but on virtually every type and style of furnace i have worked on in the last 21 years. the fan is delayed. usually the burner lights then 3 to 5 minutes later after the heat exchanger has gotten nice and hot the fan comes on and blows nice and hot air. on old furnaces there was and is a switch usually on the upper right side of the furnace bulkhead that has a spring like device that heats up and rotates till it makes a set of contacts that turn the fan on. if it gets to hot the set of contacts breaks the power to the gas valve and shuts down the burner. as the furnace cools down on shut off there is a third set of contacts that open to turn off the fan so you don't get a draft. sometimes the stat can be wired up wrong, and it will bring the fan on right away ,and air will be cool and drafty till furnace catches up.
Nov 12, 2008 | Heating & Cooling
Noise exhaust fan on my Amana AOCS3040
The exhaust fan on my oven (Aosc3040) is loud also and has always been. Just hope nothing significant brakes because this model has been discontinued and it is difficult to get parts for it. I have been told by Amana that the life expentency of this oven is 10-13 years, so don't invest in anything that is not necessary. The glass door broke on mine and I cannot get a replacement piece. My kitchen looks terrible. It is a shame because the oven works great. Linda
Oct 06, 2008 | Amana AOCS3040 Electric Single Oven
Carrier Weathermaker gas 8000 will not ignite
Your hot surface igniter may be bad. It may be cracked which would prevent it from starting the burner flame.
May 21, 2008 | Heating & Cooling
Heating & Cooling Logo
104 people viewed this question
Top Amana Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Shehu Pro
Shehu Pro
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
