Question about Sony Alpha DSLR-A100 Digital Camera
Vibrating when switched ON
Handling such equipments is not a problem for me. I am Hasselblad factory technician, repairing cameras since 30 years. I have opened this camera for the first time, and do not expect such a camera to come in future. Besides, the local Sony distributors here in Dubai, U.A.E. do not have a trained technician to handle this camera, so they will not help, rather would want to send the camera to the principal. I would love to solve this problem if someone would help out!
    Genius:
  • 1,011 Answers
Sir/Madam,
The motor is shot, you will have to replace it.
also check these link
click also
Thanks
Good Luck
Posted on Nov 25, 2008
  • 10,594 Answers
If you are in Dubai, you can contact Sony Gulf as its regional headquarter of Sony middle east region.
As I mentioned my previous reply,
http://www.fixya.com/support/t1270383-vibrating_when_switched
get help of service manual to rectify the problem in camera.
  • Shahid Electronics
    Shahid Electronics Nov 25, 2008
    If you wish I can provide you service manual for this model.
Hi, i have a hasselblad 500cm and is giving me tne negatives wich are too close to each other or iiregular space; thanks
Send to a repair facility like CRIS or United camera repair. This is something mechanical that cannot be repaired at home.
Dec 03, 2012 | Hasselblad Photography
The camera plays a short portion; stops and an error messages shows C31:30, then stops playing.
Error code 31:30 indicates a problem in the cameras tape transport system. This can be caused by several problems including the transmission gear in the tape mechanism not engaging properly, a defective clutch in the take-up spool or a faulty rotary mode switch. This will require disassembling the camera to repair and can be done fairly inexpensively. However, it's not really a user serviceable problem and should be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Sep 02, 2011 | Sony Handycam DCR-TRV315 Digital Camcorder
DV tape is stuck in (will not eject from) Canon Vixia 30 HD camera.
This can be caused by several problems including a defective eject switch in the cameras internal circuitry or a bad motor and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired qualified service technician.
Aug 05, 2011 | Canon VIXIA HV30 DV Camcorder
I have a Hasselblad 500C/M camera and can't get the lens on.
http://www.butkus.org/chinon/hasselblad.htm
Get the manual. They are picky, it might require the shutter to be wound or something like that.
Jul 01, 2009 | Planar Normal 80mm f/2.8 CFE Lense
Adapt a Hassie 500el/m to a Imacon ixpress back V 4.7
The Hasselblad ELM does not need adapting to use the Imacon or hasselblad digital back  the following backs fit on the ELM and can be triggered with a cable that should be supplied with the back.
Hasselblad V96c 16mp square format back  Hasselblad CFV 16mp square format back with CF slot Hasselblad CFVII 16mp square format back with CF slot + larger screen
the following backs will work but need to have a V adapter plate fitted to the back
96c 16mp square format back  132c 22mp 645 format back  528c 22mp 645 format back with Multishot option CF-22 22mp 645 format back with CF slot CF-22 MS 22mp 645 format back with CF slot & Multishot option CF-39 39mp 645 format back with CF slot CF-39 MS 39mp 645 format back with CF slot & Multishot option
When fitting and digital back to an older camera the best advice is to get the camera body serviced to ensure that the back mount is correct as the digital backs require a better fit than the film backs did. If the mount is off it will cause back or front focus.
Mar 16, 2009 | Hasselblad 503CW Medium Format Camera
1,2,4 hasselblad cft* 80mm speeds runs like 1/30
Those speeds tend to hang up from lack of use. You can try exercising them by cycling through the speeds, but it will most likely need service. The lubrication on the gear train has probably dried up, it is a common problem since those speeds aren't normally used.
Sep 28, 2008 | Hasselblad Cameras
Which Hasselblad?
There were several versions of the 500C/M as production was over many years. The 501C had all the latest revisions of the 500 C/M series to make it the better choice. You'll get more $ for the 501 for this reason. Later versions of the 500C/M had a much better coil spring to control the mirror for starters. Unless you are going to use this camera for daily professional use, either would be a reliable camera. A good way to check the amount of use on any Hasselblad is to look at the back of the camera where the film magazine mounts. A good solid black with no shiny spots on the plate would indicate little use. There are raised lines around the aux. shutter opening that will wear as film back are removed and replaced.
Nov 12, 2007 | Hasselblad 203FE Medium Format Camera
Sony Alpha DSLR-A100 Digital Camera Logo
113 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
