Question about Kenmore 15212 Mechanical Sewing Machine
Thread loosens in bobbin case while sewing
While sewing thread in bobbin case loosens up causing tangled stitches,which have to be removed. Sometimes there is no problem,other times it may happen 3 or 4 times on the same project. Tightening screw on bobbin case helps for a short period of time and then it loosens up again and all stitches need to be ripped out.
  • Kenmore Master
  • 1,388 Answers
If you are using a standard top tension of 4 or 5 and this problem has developed over time, the most likely cause is lint deposited between the tension disks....... if the top tension is loose, or in the tension spring of the bobbin case if the bottom tension is having troubles. In either case you need to remove the lint......
Raise the presser foot and with a length of scrap fabric, use an action like flossing your teeth to get between the top tension disks......in extreme cases a probe (old needle) may be used very gently to remove thread and lint, but be VERY careful not to scratch the polished surfaces.
I have also written a tutorial on tension balance which may be of further assistance, particularly for bobbin tension issues:
Please TRY the solution BEFORE giving your considered rating.
Ensure that all is clean and free of lint and jams, this is the most likely cause....now for tension troubleshooting .......
This solution is for tension problems...if you cannot form any sort of stitch, the issue is quite different, so please let me know if you need a different problem solved.....
It is quite long, but just work through each section in order.
The "knotting up" can reveal a lot. If you have loose threads on one side or the other, the tension on the opposite side will be the culprit.
QUICK SUMMARY FIRST:
Ensure sharp new needle,
Thread guides and Bobbin are Clean & Clear of lint
Set Top Tesion to 4 ....then....
Balance Bobbin to suit.
TOP THREAD TENSION:
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your
projects).
IS YOUR NEEDLE SHARP ?
If you are using a needle that has seen quite a deal of work, or you suspect it may be blunt, change it for a new one !
TOP TENSION & GUIDES:
Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and not to one side, top tension between 4 and 6, and that you have threaded through all the guides, including the last one, usually on the needle arm, just above the needle clamp.
It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
If tensions appear correct, and the thread is definitely in the channel between the discs, but still too loose and looping, try raising presser foot and remove your thread.
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with
a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to
disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
Far less common, but if the loose threads are on the top, it is bobbin tension that is loose, it too may have lint in the spring and be giving a "false" tension.
I would not recommend fiddling with bobbin tension without good reason, it may end up with missing small screws and spring pieces, however, you can take the needle plate off to clean
the hook race area (where bobbin case sits)
...this is just good housekeeping, my wife does this every time she replaces the bobbin....
just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint. If there is a significant amount of lint, use a vacuum and small brush to get the worst.
Then wipe all this area with a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit, especially if there appears to be fine dirty deposits....oil and lint combine to conspire against you.
If it seems likely that you ......really ....do .....actually .....need .....to adjust the bobbin case, first check there is no lint trapped in the metal spring where the thread is tensioned.
TOP LOADER:
Drop-in Bobbin case will look similar to this image with the tension screw in the middle of the metalwork....
thread loosens in bobbin case while sewing - 4c76dc1.jpg ...the other screw at one end is holding it all together, so beware....it is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
FRONT LOADER:
....this is a bobbin case from a front loading machine and works in a very similar fashion to the top loader with drop in bobbin, again, if you dismantle it, take care so you can put it all
back properly.
165ca5c.jpg FINISHING UP
GETTING THE BALANCE RIGHT:
When you are certain there's no trapped lint in top tension or bobbin, set the top tension to 4 and the bobbin tension to a point where you just begin to feel resistance.
Try using good quality thread of contrasting colours so you can more easily spot the changes.
Set your zigzag to one width less than maximum (eg. 5 of 6 ...or... 4 of 5 etc) and sew a sample for a few inches and check the result.... adjust the bobbin tension screw very little at
a time, perhaps 1/16 of a turn.
You may find you are playing with this balance for some little while and if you are putting the needleplate on and off each time begin to think it cannot be correct to do this.....BUT....it is,
and eventually, you do get a "feel" for the correct tension and then it happens quite quickly.....as a user you won't be doing it very often unless there is lint built up (or are there small hands at work around the house !?!?!)
OTHER ISSUES:
If you live near the ocean as we do, salt air can play havoc with metalwork inside and out, so to help minimise this, keep a few small packets of dessicant (silica gel) in your machine
case....no case ? then make some sort of cover !
Same applies in any damp or humid environment, keep your machine dry and dust free.
Budget for a proper full service every couple of years (more often if heavily used) and if you don't use your machine for a few years, be aware that old oil will dry out and combining with
dust and form a "clag" like glue (another reason for some sort of cover, even a teatowel !)
FINALLY, A WORD ON THREAD:
If it is worth spending the time, energy and money on making something that you would like to give lasting enjoyment......use quality thread, .......it may seem to cost a little more at the
time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistent diameter with good thread, and less compensating to be done by your tension plates and less thread breaks !
www.bargainbox.com.au
Posted on Nov 26, 2008
I have a elna lotus sp, it keeps bunching up underneith, ive had it working. I've changed the needle , it's starts sewing then stops due to it getting tangled ,
try another needle-- one for the fabric being sewed
make sure the top thread has not come off the thread take up lever
clean under the needle plate and in the bobbin area for lint
make sure the bobbin is inserted into the bobbin case correctly
make sure the bobbin is turned the correct way in the bobbin case
Mar 09, 2016 | Elna Sewing Machines
I've had my singer simple 3116 for a number of yrs. For last few weeks I've had problems with the bobbin stitch, it sews fine for a few seconds then jumps & the stitches are a tangled jumbled mess , I've...
You may have a burr from an errant needle strike on your bobbin case or even on the bobbin itself. Check to see if there are any rough spots on or around the bobbin.
If you don't find anything, you may want to remove the bobbin assembly and clean the lint out from the lower assembly. Sometimes the smallest amount of lint or pieces of thread can cause problems with the bobbin.
You didn't mention if the tangled thread happens on the top or the bottom of the fabric. If it is on top, then it is a bobbin issue. If it is on the bottom, then it is an upper tension/thread issue.
Try removing the bobbin, thread, and needle. Rethread the entire machine using a different bobbin and a new needle. This may solve your problem. Good luck!
Jul 07, 2014 | Sewing Machines
The bobbin case on my singer feaherweight is stuck
Sounds like thread or lint has got on the centre spindle of the hook. and jammed bobbin inside case. unclip race and remove hook and bobbin assembly. remove feed dogs and all tangled thread. machine should then be freed up
Feb 05, 2014 | Sewing Machines
I keep getting error E6 on Brothers CS 6000i- I cleaned the thread several times and when I try to restart sewing it happens again. I've removed the bobbin and re-threaded and it keep jammin and beeping....
The motor locked up because the thread is tangled.
Solution:
Remove the tangled thread before continuing the operation.
Clean the bobbin case to remove the tangled thread.
After cleaning the bobbin case, insert the bobbin case properly.
If the needle is bent or broken, replace the needle.
Then, thread the upper thread properly, and continue the operation.
Dec 21, 2013 | Brother CS-6000i CS6000i 60-Stitch...
Worked great until the needle broke and now the bobbin thread bunches up
Hello
Clean out the bobbin area if there are any thread tangles there.
If the bobbin does not fit snugly into the bobbin case, then get new bobbins. You need class A or 15 and they do not cost very much. Make sure they are plastic and not metal.
Refer to the maintenance section of the manual - see the configuration of the bobbin case and shuttle race? The bobbin case as an extending arm and the race a notch. When inserting the bobbin case into the shuttle, turn the handwheel so the needle is at it's highest position. Then lift the lever on the back of the bobbin case and insert the cast into the shuttle, arm pointing straight up toward the bed of the sewing machine.
Now thread the machine with the presser foot up - always - and see if the tangling stops.
There should be a tension setting for your bobbin thread, as well as your top thread. It sounds to me like your bobbin tension setting is not in sync with your top thread.
most common solution to this is to remove the top thread completely from machine and re thread it with the presser foot UP not down. This will allow the top thread to engage properly in the top tension disc
Aug 10, 2011 | Brother LS-2125 Mechanical Sewing Machine
My machine is a designer 2 but I encounterd a problem with my stich getting all tangled. tryed to clean the bobbin case and under, stich is still tangling bad.
Be absolutely sure that the machine is threaded correctly, with the upper thread clicked into the tension discs (the presser foot MUST be raised when you thread so the tensions discs are open to receive the thread) and bobbin thread clicked into the bobbin tension slot. Change the needle - a bent or blunt needle can cause tangles. Hold onto the thread tails for two or three stitches when you first start sewing to avoid them being drawn down under the fabric and making a mess.
Dec 19, 2010 | Husqvarna Designer I
Bunches of threads on the bottom
You didn't give the brand, but if it's any of the older, non computerized machines, your problem is most likley in the tensions.
Loopies (tangles or nests of thread) on the bottom means upper tension too loose (or bobbin too tight).
Let's do the bobbin first...once it is set...99.9% of loopies on the underside are a problem with upper tension.
This is for bobbins that load on the front/side of the machine.. Take out the bobbin case...check the area (hook/race area) that the bobbin goes into for lint, tiny thread pieces, etc.). Now, most of this type of bobbin loads into the case with the thread going counter clockwise (when you are looking at the open side of the case), insert the bobbin in the case, and pull it through the hole/slott in the side of the bobbin case. To test for proper tension:
Lay the bobbin case in the palm of one hand, pull on the thread coming off the bobbin case. The bobbin will gently lift off your hand & if you wiggle the thread, the bobbin case should slowly drop about an inch at a time. If it's too tight, loosen the Larger (closest to where the thread comes out) screw on the side of the bobbin case about 1/16 of a turn...tiny bit...retest. Once that is done try a test stitchout. Remember to hold onto the bobbin & top thread for first few stitches.
If you still get loopies on the bottom...tighten the upper tension...it should be set between 4-5 for regular sewing.
Make sure the needle is in properly.
For a drop in bobbin...adjusting that tension is harder. You take the face plate (needle plate, the plate covering the sewing area of the machine) off and remove the bobbin case...First...look at the case in the machine...there is a little lip sticking out, usually at the bottom right corner of the open area (closest to you)...this is where you need to have the little lip when you replace the bobbin case.
Remove the case...check under it and inside the machine for lint/dust/threads & using a small paint brush (I use a childs tooth brush sometimes), clean the lint out. Now check the bobbin case for lint, especially where the thread fits..look at the inside of the case, you will see a little flat metal thing with a slott in it...make sure no lint in that slott. I use a pin to remove lint from there. Reinsert the bobbin case, rethread it all, (bobbin goes counterclockwise). Put the faceplate back on & test the stitches...still loopies with the upper set to between 4-5? Then you will remove the faceplate, remove the bobbin case & loosen the screw on the outside about 1/16 of a turn (these are usually covered in a colored coating) and retest.
I know that most home machine makers say not to adjust the bobbin..but that was back when you had one size thread...now we have many, many sizes and types of thread, so adjusting the bobbin may be needed sometimes.
Rule of thumb is:
loopies on underside...tighten upper tension
loopies on top...loosen upper tension.
But, like I said...with all the new threads..sometimes you have to adjust that bobbin.
May 12, 2010 | Sewing Machines
My sewing machine keeps getting jammed when sewing. the top stitch keeps getting tangled in with the bobbin thread and jamming up the machine.
Here are a couple of things to try.
* Un-thread your machine and remove your bobbin. Clean any loose thread or lint out of your
bobbin case. Re-thread your machine, reinsert and re-thread your bobbin.
* Change your bobbin
There could be a nick along the edge of your bobbin spool that’s catching your thread as you
sew.
* When you start to sew a seam, grasp the upper and bobbin thread tails. Hold them back
and out of the way as you sew your first couple of stitches. This will keep them from getting
caught in your machine.
I hope this helps.
Sep 11, 2009 | Singer 5160 Mechanical Sewing Machine
Jammed thread.
To address my needle thread tangling (horribly) in the bobbin compartment, I rethreaded the bobbin. I cleaned the bobbin and the feeder feet, I changed the bobbin and the thread. I changed the tension on the needle thread and the bobbin thread. NO FIX! Then, I changed the needle - the problem was fixed instantly. I sewed awhile and then put the original needle back in. No problem. I think perhaps that the problem is being caused by the needle getting out of alignment somehow during sewing. If you are having the same issue, try it. It can't hurt!
Sep 08, 2008 | Kenmore 15516 Mechanical Sewing Machine
Upper thread getting tangled in the bobbin
Always remember T-N-T. Thread, Needle, Tension. Assuming its threaded properly, is the needle all the way in and facing the right direction? These symptoms also suggest the bobbin may be in the bobbincase upside down thus turning in the wrong direction. Hope this helps.
Aug 21, 2007 | Euro-Pro 416 Mechanical Sewing Machine
Kenmore 15212 Mechanical Sewing Machine Logo
253 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Douglas Plant
Douglas Plant
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
