Question about HP 1040 Plain Paper Inkjet Fax
Hp1040 fax and copy machine
I seem to have a little problem with my machine. I cant set it on long form or legal format size. When i photocopy a long paper its only copying up to a letter style format. The serial number is ( S ) CN656AJO2T. The part number is (1p)Q7271A The option number is (30P) ABL . HP 1040 FAX Plain paper inkjet fax.
I solved this problem by returning my fax machine to where I purchased it and exchanged it for another type of hp machine and it automatically goes in long format when it scans long format paper. If it scans short letter form, it automatically copies itself and adjusts itself. Thank you aniway, durl
Posted on Nov 28, 2008
HP Office jet plus 8600+ - supposed to print legal but does not!!?!
The printer set up procedure may reveal there is no provision for legal size printing.
May 26, 2017 | HP OfficeJet Pro K8600 Printer
Have a canon b95 faxphone machine. When receiving legal size documents, it receives and prints on 2 separate sheets. How do I correct so incoming only prints on 1 legal size paper
Use the settings to select LGL as the paper size. (But note that you have to have legal size paper in the machine)
1. Press the Function key (left side, lower right button)
2. Press the Start/Copy key (right side, lower center button). The display will show USER SETTINGS.
3. Press the Left or Right arrows (right side, upper row) until you see PRINTER SETTINGS in the LCD.
4. Press the Start/Copy key
5. Press the Left or Right arrows until you see PAPER SIZE in the LCD.
6. Press the Start/Copy key
7. Press the Left or Right arrows until you see LGL
8. Press the Start/Copy key
9. Press the Stop key (right side, lower right button).
May 18, 2010 | Canon FaxPhone B95 Plain Paper Inkjet
How to print legal paper in 1210 printer
canon lbp 1210 printers
has a probleam a legal page setting
plese answerer legal page setting
May 11, 2010 | Canon LASER SHOT LBP-3000 Printer
How do you fax a document that is 11 by 14 inches?
Most fax machines and printers will scan and fax an 11x14 document. Just check your owners manual to see if any settings need to be changed AND contact the person you are faxing to let them know to put 11x14 paper in their machine, or some of the print may be lost if the fax will be printed on two 8x11 sheets.
If you don't have your owners manual, post a question and include the manufacturer and model number of your fax machine or printer and one of us will look it up for you.
Feb 10, 2010 | Office Equipment & Supplies
How to set hp1040 fax to work with aout answering
If you are using the same phone line as your fax, you can start by connecting the answering machine on Line2 or 2-Ext at the back of the fax. Set the fax to answer on two rings higher than the Answering Machine. (for example: if answering maching is 4 rings, fax is 6 rings)
And then, turn on the auto answer.
Mar 22, 2009 | HP 1040 Plain Paper Inkjet Fax
CANON IR2000 CANT PRINT MORE THAN 1 COPY
You just stated the problem yourself!!!!!!!!!!!!!!!!!!!!!
Are you using Letter or Legal?? then the tray need to be set to that particular size.
If using Legal set to Legal, otherwise the machine will automatically know you are using the wrong size.
Aug 14, 2008 | Office Equipment & Supplies
Canon LaserClass 7000 - Receiving problem
Make sure the rear guide is pushed up tight against the paper.
Remove all legal size paper and make a copy.
Dec 13, 2007 | Canon LaserClass 7000 Plain Paper Fax
HP 1040 Plain Paper Inkjet Fax Logo
147 people viewed this question
Seeker5211
Seeker5211
