Question about Garmin nuvi® 5000 Car GPS Receiver
My Garmin Nuvi 5000 keeps searching but never finds a signal
It was purchased in late June. It has not been working for a couple weeks.
SOURCE: garmin nuvi 350
Heres what to do:
- Connect to computer using USB cable
- Flip up antenna and hit reset button.
- The unit should power up.
- Then put unit on wall charge to get a full charge.
That should do it if not call 1-800 800 1020.
Posted on Jan 07, 2008
Arius
  • 446 Answers
SOURCE: Garmin Nuvi 205 Problems aquiring stellite
usually gps are automatically sensing the signal, with clear view without and sometime even with minimal obstruction like trees windows etc. there is no other way your gps could not acquire signal unles it is having a problem .
all gps thesedays have 10-20 meter accuracy, it is only a receiver, this model particularly have the highest signal.
in other words i suggest you reset your unit from the bottom and see if there is any improvement, replace the unit
cheers
Posted on Sep 04, 2008
  • 20 Answers
SOURCE: Garmin nuvi 610
https://buy.garmin.com/shop/buymaps.do
Garmin offer new maps, the majority in different formats such as online downloads, pre-loaded SD cards, or on DVD.
However, these are pretty costly for all they are worth. For the same price as a map, you could easily buy a brand new device with full EU maps.
Posted on Dec 11, 2009
sharcnet
  • 2130 Answers
SOURCE: garmin nuvi can't get satellite signal
Please see this link:
http://www.sharc.net/gps_antenna_repair.htm
- Jim
Posted on Dec 23, 2009
SOURCE: my garmin nuvi 5000 is
Mine was doing basically the same thing. Ended up being the power cord. Put a new cord in place and everything was normal.
Posted on Aug 05, 2010
The Garmin Nuvi 1300 was working gret. It was a Chrismas gift. It just stopped working it will not come on at all the screen is blank black. No signal will not turn on at all. Did not drop it or and other...
A Garmin Nuvi 1300 that won't start, freezes on 'loading maps,' or is acting erratically is symptomatic of having corrupt firmware.
To correct this, I recommend backing up your favorites, clearing all user data, and if it still is stuck, then updating your Nuvi firmware.
Follow these three steps to take to get your Garmin Nuvi 1300 running like new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin WebUpdater to replace its firmware / system software.
I hope that helps.
_______________________________________
Garmin Nuvi 1300 Manual Download
Garmin Nuvi 1300 QuickStart Download
Garmin Nuvi 1300 Favorites Backup
Garmin Nuvi 1300 Hard Reset
Garmin Nuvi 1300 Webupdate
May 11, 2010 | Garmin nuvi 1300 Car GPS Receiver
Hi i have a garmin 265 only 4 weeks old. i have lost all side roads and the navigation is well out. says im on the road next to me. i keep loosing gps signal also. any solutions??????????
I can help you reset and fix your Garmin Nuvi 265W.
Losing gps signal and poor tracking are indications that the firmware / system software inside your GPS need updating.
There are three steps to take to get your Nuvi 265W running like new:
I hope that helps.
Nuvi 265W Manuals here.
Mar 21, 2010 | Garmin Nuvi 265W GPS Receiver
The Garmin Nuvi 1300 was working gret. it was a Chrismas gift. It just stopped working, it will not come on at all the screen is blank, black. No signal will not turn on at all. Did not drop it or and...
A Garmin Nuvi 1300 that won't start, or is acting erratically is symptomatic of having corrupt firmware.
I hope that helps.
Mar 19, 2010 | Garmin nuvi 1300 Car GPS Receiver
Just purchased a garmin nuvi 205W in Florida. It
This device should find a signal nearly anywhere it is used. The further away from the earth's equator it is used will increase signal lock or "fix" time though. You should be able to get a fix by bringing the unit into an open space (few / low trees, buildings, etc.) and leave on for up to 20 minutes. The GPS should provide an accurate location in this amount of time and should be able to fix in a moment or so from that point on.
If you have troubles still, contact Garmin Support below:
http://www.garmin.com/garmin/cms/site/us/support/supportcontact
I hope this helps!
Oct 24, 2009 | Garmin nuvi 205 GPS Receiver
Garmin nuvi 5000 wont turn on. I can plug up the usb up to the computer and the screen shows garmin logo with a gps connected to a computer like its charging. But when i press the power button weather it...
Your nuvi 5000 does NOT have a internal battery and that means that you cannot operate it unless it is connected to a 12 volt power source. Connecting it to your computer via USB allows you to install map updates, check for firmware updates, etc, but you will not be able to use it as a gps while it is connected to the computer. There is nothing wrong with your gps.
To use your gps in the home you need to purchase a 12 volt adapter, there are several types, plug the adapter into your wall outlet and connect your gps to it. If you can sit near a window it will help in picking up the satellite signal. Just keep in mind that you cannot connect the 12 volt power supply and use the usb cable at the same time. Enjoy your gps.
Jun 11, 2009 | Garmin nuvi® 5000 Car GPS Receiver
Need instructions how to use garmin nuvi 5000
You can obtain the manual for your nuvi 5000 at Garmin.com
If you would like to learn some tips and tricks relating to your gps you may want to check out Gary Hayman's web site. Just do a search for his name. The advice he gives is not specific to the nuvi 5000 but in most cases it is applicable.
May 07, 2009 | GPS
Broken
my nuvi 200 don't have the map of canada. how i can update it
Aug 07, 2008 | Garmin nuvi 200W GPS Receiver
Garmin nuvi® 5000 Car GPS Receiver Logo
123 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
