Question about Technics Audio Players & Recorders
Tecnics multi disk player SL PC 15 will rotate disk, pick it up, put it down but does not play the cd.
  • Sandy Fisher
    Sandy Fisher Nov 25, 2008
    I tried cleaning with a cd cleaner but the changer just picks up the cd then puts it down and rotates to the next disk without playing. I can hit stop and it stops but then a few seconds later it will just put the disk down. If it hit change track while the cd is up it just drops the cd down and rotates to the next cd.
  • 905 Answers
Manually clean the laser lens
Posted on Nov 25, 2008
  • jason Nov 25, 2008
    If you wanted more help you shouldn't have rated me already , since I don't know what you have or haven't done. but now I know you haven't tried to clean it manually with a q-tip and cd lens cleaner
    and that rating is insulting!
    electech
Where do I Service/Repair CD Player Tecnics SL-Pg 340 in the Western Cape
Laser mechanism is losing ability to focus . You replace - repair not cost effective.
Oct 11, 2016 | Audio Players & Recorders
Technics SL-MC-7 Multi Disk CD Player- When I put a CD in it says
What does it stay? I am (Hooch) Please get a different CD (PLayer) I have (Retired)
Nov 09, 2012 | Technics SL-MC7 110-Disc CD Changer
I had bought a regular cd from hmv with music on it & when i put the cd in the cd player,it wont play & reads NO DISC also does not reads the amount of music on the cd,why does it give me this...
1. Check that the disc is free of scratches and dirt or dust. If the disk is dusty, use a soft, lint-free cloth and wipe the disk gently, using straight strokes from the center of the disc to the outer edge.
2. Make sure that you are inserting the disk with the plain, reflective side down.
2. Try listening to another CD (not burned) that you have purchased. If the other cd is giving you the same error message, return the cd player to the store, because it is defective.
3. Ensure that the disc you are using is not a DVD disc. It is easy to confuse the two.
Hope that helps! Good Luck!
Mar 13, 2011 | Panasonic SL-SX420 Personal CD Player
Technics 5 cd changer Model SL PC11 will pick up
This is a problem with the laser assembly which requires service. The laser assembly needs to be replaced as a whole. It is not easy to replace them, but someone with patience, and a knack for mechanical things can do it.
Nov 27, 2009 | Audio Players & Recorders
I have a tecnics turntable and need to know how to put the belt on Its model # is SL-L26
Lift off the rubber platter cover (the disk that records set on while playing) there should be 2 openings in the aluminum plate. Slowly rotate platter until you can see the pulley of motor. Lift aluminum platter straight up and off. Place belt around underneath pulley on platter. Reinstall platter to turntable. Reach through one of slots in plater and grasp the belt gently, line up slot with motor pulley and place belt over pulley (ensuring not to twist belt) rotate platter to observe belt, confirming correct installation. Reinstall rubber platter cover. VOLA!
Jun 11, 2009 | Audio Players & Recorders
I have a 90's vintage Panasonic radio/cd/tape combo unit that I have enjoyed since new. Recently the multi cd unit quit functioning. That unit is separate from the radio and the model is SL PK345. It will...
No answer after a year? Must be a really complex problem or some geek would know how to fix it!
Actually if you just unsnap the cover over the area where the disc plays (push in the two tabs at the edge and rotate upward) and use a swap damped with alcohol to clean the small plaster laser cover (the small part that jumps up and down) you will be back in business.
Mar 12, 2009 | Panasonic Audio Players & Recorders
What are the sockets on the rear of the Tecnics HD350 for
FOR RECIEVING SOUND FROM OTHER SOURCES,,LIKE A CD PLAYER,,,,YOU USE A RCA JACKS
Dec 12, 2008 | Technics SL-PG480A CD Player
Cds
Could be the power supply not supplying enough juice to the spindle motor. Make sure it's not plugged into a "multi-plug" adapter.
Could be the spindle motor as well, or the disk sensor.
Let me know should you find something else...
Sep 21, 2008 | Technics SL-PD687 5-Disc CD Changer
The DVD player doesn't play DVD disc only CD discs
first thing to do is try a lens cleaner disk. If that does not help you can try to remove cover and maualy clean the laser pick up with a q-tip and isopal alcahol. If that is not something you want to try have it done by a friend that has experiance or a shop. If that does not fix it you will need a new laser assy.
Dec 03, 2007 | kawasaki SVP500 Multi-disc DVD Player
90 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
