Question about Hotpoint RB757 Electric Kitchen Range
Oven top element does not come on when baking
When we are baking with our Amana range the top element never comes on so the top of the food being bake never browns.
The top element does come on when we use broil mode. Can something be done to fix this?
Thank you
    Problem Solver:
  • 3 Answers
The top element is for broil only. if you have convection mode try that
Posted on Nov 25, 2008
First start up
You're actually referring to the "broiler" elements. Most electric ovens have these at the top of the main oven space. (Some gas ovens are set up the same way, but many put the broiler elements in a bottom drawer.)
As their name implies, broiler elements are active only when you're broiling. They will not go on for baking.
Broiling is the process of cooking food by exposing it directly to a high heat source at close range. To broil a steak, for example, you would place the pan holding the steak on an oven rack raised to the top or next to top position in the oven (consult the manual) and set the oven to broil. The top elements will then turn on and cook the meat by direct radiation.
Most people, however, use ovens for baking far more often than for broiling. Baking is the process of cooking food (cakes, casseroles, roasts etc) by indirect heat. In other words you raise the oven to a certain temperature, put the food on a rack more in the middle of the oven, and let the surrounding heat cook it over time. When you bake the top broiler elements usually don't come on at all.
I hope this helps.
Apr 30, 2014 | KitchenAid Ovens
Top element does not work in bake mode,but it does work in broil mode
The top element is a broil element and will not come on in bake mode just as the lower bake element will not come on during the broil mode
Aug 21, 2011 | Maytag MER5775Q Electric Kitchen Range
When set to bake oven does not preheat and tempature does not increase. when set to broil oven heats
Since your oven has a separate element for bake and broil I would bet the bake element is burnt out or burnt electrical connection to the element. Make sure you disconnect all power to the range before checking.
Mar 21, 2010 | Amana AER5844VAD / AER5844VAB / AER5844VAW...
Amana electric oven won't get above 225 degrees. Takes over an hour to get to this temp.
sounds like only the broiler is working which comes on low during bake cycle. unplug or turn off breaker, remove bake element and check for continuity or take to someone who can.
Jun 13, 2009 | Amana AER5725QA Electric Kitchen Range
My oven take forever to preheat
Your bake element is probably open. When this happens the broil element may heat slightly when in BAKE mode and that is where your heat is coming from. First thing I would check is the connections to the bake element as well as the element itsef.
Dec 14, 2008 | Amana AER5715QAS Electric Kitchen Range
Bottom element on range doesn't work
we can check a few things, first off you need to confirm 220v. to unit itself, ill assume you do, the top elements are working correctly.. sounds like a bad electronic control, what youll need to check is on the control itself, there is a wire labeled L1, then there will be a bake terminal, ill also assume L1 has 110v, other\wise the clock wouldnt be liting up, but if you carefully unplug the bake terminal and test terminal for power( it will have 110v, after you select bake andstart oven.
Nov 17, 2008 | Amana AER5515QA Electric Kitchen Range
Amana Range, Electric wont bake or broil
the fact that the time keeps flashing is odd, an you set the clock?? and if so does it return to blinking again???sme stoves wont allow proper operation of oven without the clock being set.
Mar 23, 2008 | Kitchen Ranges
Oven will not heat past 220 degrees
Check your bake element, I had the exact same problem and found the bake element had burned in half. The broil element comes on during preheat and kicks off at around 220 degrees.
May 06, 2007 | Amana AER5515QA Electric Kitchen Range
Hotpoint RB757 Electric Kitchen Range Logo
430 people viewed this question
Top Hotpoint Kitchen Ranges Experts
Sal De
Justin Duby
Justin Duby
Ismael Rodriguez...
Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
