Question about ASUS G2P Notebook
Vertical Hold issue on Laptop Screen
I have a Toshiba Sattelite that seems to have a vertical hold issue like the old TV's. For the most time it boots fine with the screen normal as it can be. The not too long into it being on the screen starts to scroll vertically and it is fast. It will occassionally stop but not long enough for me to attempt to change any settings on the resolution or anything.
Vertical lines appear on my screen on my toshiba sattelite p105-s6147 laptop computer.
looks like the pixels are going try anther screen it should work ok
Jan 08, 2013 | Computers & Internet
Vertical line running thru my laptop display
This sounds like the display is possiblely aged to a point to where its showing that its going bad this is normal on any LCD display even for a LCD TV it maybe time to replace the screen in ur laptop
Jan 12, 2012 | Toshiba SatteliteĀ® Pro A200 PC Desktop
My toshiba sattelite has the fan on,but it won't boot up.
Try unplugging the laptop. Then remove the battery. With the laptop unplugged and the battery removed, hold the power button for 10 seconds. After that replace the battery and plug the laptop back in. Press the power button and the computer should boot if there is no issue with the motherboard.
Mar 17, 2011 | Toshiba Computers & Internet
I cant stop the tv monitor screen from jumping it has something with the dvr
Hello What type of TV do you have, analog or digital? If you have an analog TV and the screen is rolling it is the vertical hold. Because the vertical hold operate on 60 cycle which the same as AC line cycle. The 60 cycle in the vertical hold is as a oscillator or timing circuit. When the TV pick up the image for the NV devise, they just don't mix. Why, because image intensifier tube in the NV devise is operation at 25 to 50K Hz or cycles. The vertical hold circuit pick up on the 50K Hz signal which mixes with 60 cycle timing circuit causing the screen to rolling with lines across the screen @ 60 cycles. Digital camera and digital camcorder with digital TV will help, or a image inverter that takes this 50k Hz signal and covert it to some that analog TVs can use. GB...stewbison
Jan 18, 2011 | Optics
Toshiba 40H80 Rear Projection TV Picture Rolling/Scrolling
problem is bad hyper module or can have tech repair it with capacitors
Feb 05, 2009 | Toshiba 40H80 40" Rear Projection...
Dark Grey Vertical Bar
1. try connecting laptop to an external monitor and check if this vertical dark gray bar appears. if yes it means video is the problem. you need to boot in safe mode then uninstall the video driver. boot to notmal mode then download and install the latest video driver. if still same problem then replace video card. if video is built in with motherboard you need to replace motherboard.
2. when the vertical dark gray bar did not appear in the external monitor then it means issue is with the LCD panel. Do this turn off laptop. press and hold D key then press Power button at the same time or Press and hold on the Fn key then Power button check if the test will run. Color displays full screen when you keep pressing on N key when the colors appears check the vertical dark gray bar if still exist in the test, this means LCD panel and LCD cable needs to be replaced.
Oct 31, 2008 | Computers & Internet
Vertical hold problem
There is a fault in either the input video amp, sync amp, sync separator, or the vertical scan generator areas. Most of the time this type of failure is caused by capacitors in these areas going off spec from age and use.
An experienced TV tech who is familiar with your set should be able to service this for you.
Jerry G.
Jul 16, 2008 | Toshiba 32A43 32" TV
Toshiba sattelite A135-S2246
Hard Drive Issues most likely, Try booting to your Bios Setup utility Page...
Hold the f2 key (or delete key)(some are also f12)Check to see if your HD shows up in there, then reboot and hold the F8 key to try and get to the SAFE MODE options screen... there ya can boot it into safe mode if able to get to it..
Jun 04, 2008 | Computers & Internet
Vertical hold not working
on mitsubishi just replace the caps that are near the vertical ic this will fix the problem good luck
Nov 02, 2007 | Mitsubishi WT-46805 46" Rear Projection...
2004 Toshiba TV 32A41 problem
to me its sound like your on the right track. there isnt a physical vertical hold adjustment. more than likely the vertical hold ic has failed. send me your email addy to and i will be more than glad to email you a service manual
Oct 25, 2007 | Televison & Video
ASUS G2P Notebook Logo
540 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
