Question about Hoover Vacuums
Brush on my hoover z400 bagless upright stopped working. Model # u9125-900
  • raquilino Nov 28, 2008
    the belt isn't broken because i took it apart and it won't run in the reclined position
    Scholar:
  • 55 Answers
I think that machine needs to be in the reclined position for that brush to turn on. It its not that then, you probably just have a broken belt.
Posted on Nov 26, 2008
  • David Cleary Nov 28, 2008
    Unfortunately I haven't seen this problem occur on this machine before.
    Make sure the machine isn't set on the Hard Surface setting, because the roller doesn't turn on that setting.
    The next thing to check would be the brush motor. Make sure it has voltage to it. If it doesn't, you have an electrical problem and if it does, you have a bad motor which is part# 92001237
    Let me know if any of this helps
  • magumbo Mar 28, 2011
    I had the same problem, I checked the motor by taking and running current through it and it ws working so i figured there must be a kill swith for when it is upright the brushes wont spin. Next to the wheel inside is a cyntech power choker ( it should be yellow/purple and brown wires together), this kills the power to the motor so if its not the motor its this. very simple to remove and replace.
Replace belt on Hoover savvy vacuum
There is not a brush belt on your model. It has a drive mechanism that turns the brush rolls.
Feb 20, 2016 | Hoover U8145-900 Savvy Bagless Upright...
When you turn it on the lights on the battery come on and the brush roller will turn but the suction motor will not turn on.
Hoover Air Cordless Series 3.0 Bagless Upright Vacuum ...
www.amazon.com/Hoover-Cordless-Bagless-Upright...
Amazon.com, Inc.Hoover Air Cordless Series 3.0 Bagless Upright Vacuum, BH50140 ... The batteries come pre-charged, plenty to get up and running. ... The brush will stop as soon as the handle is in the upright position for like using the attachments. ..... and in need of charge, in carpet mode, the motor runs, but the brush roller won't spin.
Hoover Air Cordless Series 3.0 review - Best vacuum cleaner
www.vacuumsguide.com/hoover-air-cordless-series-3-0-review/
Rating: 4 - ‎Review by Jason Roberts
Aug 4, 2014 - Hoover Air Cordless Series 3.0 is a new upright vacuum cleaner reviewed by ... power, 2 batteries - each lasting 25 minutes, good filtration system,light ... Just as in the case of the Linx, it filters dust particles, but doesn't come with HEPA filtration. ... Multi-Floor Cleaning - you can turn the brush roll on or off.
Dec 18, 2015 | Hoover Air Cordless Series 3.0 Bagless...
Hoover Whole House Bagless Upright. Belt Changed but Brushes arent moving
Take off the bootom plate and remove the brush assembly. Inspect both ends for any hair, string or anything else that might prevent it from revolving. Check to see that the ends are lubricated with some grease, just a bit. It should take care of the problem. The ends should turn easily and smoothly.
Oct 15, 2013 | Hoover Whole House Bagless Upright,...
Brush on vacuum stop spining (HOOVER U-5753-960) Thank You
A worn out carbon brushes of vacuum will cause that motor spinning stop. Because brush no longer capable of pushing a stator or rotor hence electromagnet windings motor will not meet each other.
Have a brush replacement be customize in a nearby machine shop or find brush replacement on hardware store.
Look also for the possibility of loose wiring of the vacuum, check it also.
Thanks for asking.
Jun 26, 2011 | Hoover U5753-900 WindTunnel Bagless...
I cant get my hoover vaccum brush to spin
First be sure the switch/circuit breaker on top of the nozzle is on. The brush also will not turn unless the handle is released and tilted back. This model of Hoover has a gear drive to turn the brushes. This was VERY prone to problems, and Hoover discontinued making replacement parts for it several years ago.
Mar 18, 2011 | Hoover U8147-900 WindTunnel V2 Bagless...
My machine (Hoover Wind Tunnel - bagless) is only 1 yr. old. The agitator brush doesn't turn all the time. I know it's not supposed to turn when in the upright position. However, it only seems to work when...
Sounds like you should do two things: 1- Remove and clean the beater brush of all debris as best you can. At the end of the brush you will see a hard rubber piece, at both ends, that holds it in place in the body of the vacuum. Add some WD40 between the brush and these pieces and turn until they move freely. 2- When you reassemble, put a new belt on.
This should be all you need to do. If you find this information to be of help, I would appreciate a Thumbs Up from you. Be well, Paul
Oct 08, 2010 | Hoover Self-Propelled WindTunnel Bagless...
Had a problem with the brushroll now its burning up the flat belt
When you put the flat belt on, is the print on the outside of the belt? Is the brush correctly positioned?
Dec 21, 2008 | Hoover U6630-900 WindTunnel Bagless...
Vacuums Logo
155 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
