Question about ASUS G2P Notebook
Hi, I have a toshiba sattelit laptop that the screen seems to have a vertical hold issue like the old TV's. It will occassionally go into a normal boot with the screen all good and then the vertical mess starts all over again. Any ideas.
Vertical lines appear on my screen on my toshiba sattelite p105-s6147 laptop computer.
looks like the pixels are going try anther screen it should work ok
Jan 08, 2013 | Computers & Internet
My Toshiba M55 Laptop has a vertical 'ribbon' of flickering. Is it fixable?
Maybe your screen is going bad or the video card inside the computer is going bad. Try connecting another monitor to the computer to isolate the problem. Borrow a monitor from a neighbor, friend, relative or co-worker and connect it to the computer. If the Borrowed monitor displays ok without the vertical ribbon then your lcd screen is bad and your video card is good. If the Borrowed monitor displays the same vertical ribbon as your lcd screen then your video card inside the computer has an issue.
The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
May 31, 2012 | Toshiba Satellite M55-S329 Notebook
Vertical line running thru my laptop display
This sounds like the display is possiblely aged to a point to where its showing that its going bad this is normal on any LCD display even for a LCD TV it maybe time to replace the screen in ur laptop
Jan 12, 2012 | Toshiba SatteliteĀ® Pro A200 PC Desktop
I have a toshiba sattelite l3oo and i have a problem with my charger. when ever i plug my charger the laptop will reboot(when starting. i can't start the computer when my charger is on. and when i'm using...
I had same problem with my Sattelite L300. Motherboard has a defect in one Proadlizer film capacitor exactly on the back of CPU, the original ref. is nec-tokin 0E907 (900uF/2.5V) or similar code. I've replaced it by 4 tantalum capacitores of 470uF/2.5V each and 2 capacitores of 220uF/2.5V, all in paralell mode in same old place of nec-tokin component.
Vote for me... :)3_10_2012_6_45_55_pm.jpg
Apr 12, 2011 | Toshiba SatteliteĀ® A105-S2051 PC Notebook
Toshiba 32av502rz 32 " lcd, I keep getting half screen with vertical lines. Its unwatchable, tv was made in august of 09.
Hi
the problem you are describing seems to come from the screen panel your tv is a Samsung made and a very common problem so I would suggest you contact Toshiba even
if its out of waranty.
good luck
Sep 27, 2010 | Toshiba 32AV502R LCD TV
My Toshiba a305-s6909 notebook just comes up with a white screen, when I turn it on. I've tried holding the power button on but this does not help. All the keyboard lights seem to be on an occassionally...
so it is your display resolution issue.
When you power up press continue F8 key then enter in enable vga mode.
Then go to control panel and dispaly proeprty then change screen resolution to 1024*768.
but if you not see safe mode and other menu then you have to check your ram and motherbord.
Also check your Lcd screen.
Let me know if you need more assistanse.
Thanks.
Aug 25, 2009 | Computers & Internet
My toshiba sattelite sreen is not working if the plug is in
Laptops allow you to set differnt screen brightness settings when on and off AC Power. Try turning the screen brightness up when it's plugged in. Hold the "FN" key, and press F7 repeatedly.
Jan 03, 2009 | Toshiba Satellite A100-S8111TD Notebook
Tv screen get smaller
not the flyback
it is either the vertical ic
or related caps
it is repairable probally between $75 and $100
what size screen and how old (is it worth it? that your call
Dec 20, 2008 | Toshiba 27A50 TV
Toshiba sattelite A135-S2246
Hard Drive Issues most likely, Try booting to your Bios Setup utility Page...
Hold the f2 key (or delete key)(some are also f12)Check to see if your HD shows up in there, then reboot and hold the F8 key to try and get to the SAFE MODE options screen... there ya can boot it into safe mode if able to get to it..
Jun 04, 2008 | Computers & Internet
ASUS G2P Notebook Logo
63 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
