Question about EliteGroup K7VMM Motherboard
Wire hookup could you pls send a schmatic hookup for the k7vmm 462 pin,i have power but no video
  • Tutiepie7771 Feb 25, 2009
    Hi, can you help me out I am trying to find out where these plugin's go on my board, they are the wires that go to the power botton and usb plugin's I don't know what pin they go onto.
  • 105 Answers
Compatible processor in K7VMM ecs motherboard
According to the ecs website :
http://www.ecs.com.tw
the K7VMM version 1.2A has a cpu socket 462 for AMD Athlon XP/ Athlon / Duron processor
Go to : http://www.ecs.com.tw/ECSWebSite/Index.aspx?MenuID=0&LanID=0
and use the ECS search box with your model # K7VMM
then choose your version #, click it
then click on the CPU tab (under the pic of the motherboard). It shows a complete list of compatible cpu's for this motherboard. Did this answer your question?
Dec 25, 2012 | EliteGroup K7VMM Motherboard
WHERE DO I CONNECT THE PWER SWITCH PIN ON WINFAST MOTHERBOARD
hai, i am using winfast motherboard pc and i was remove my cpu all wire so please tell me about how to connect the power switch wire and restart wire
Oct 28, 2012 | Foxconn WinFast K7S741MG Motherboard for...
CASE WIRES TO PANEL1 CONNECTIONS
The hdd red wire gooes to pin #1 the hdd white wire goes to pin #3 the power sw orange wire goes to pin #6 the power sw white wire goes to pin #8 The reset sw blue wire goes to pin #7 the reset sw white wire goes to pin #5 the power led green wire goes to pin #2 the power led white wire goes to pin #4.
Now the layout of the pins is the long row (5) pins are the odd number pins 9 being the odd one and 1 is the other end of the row. 2 through 8 start at the pin accross from 1 : : : : . I hope this helps you.
Aug 22, 2009 | PC Chips MB PCCHIPS SiS746FX M848A V5.0...
First time building power hookups on mobo
the general guidline is that if your power supply has the extra cables and your mobo can support them, then plug them in... those extra 4 wires in your long power strip will normally be used for grounding, so that's a must. check your mobo manual to see the exact specs. ... as for raid, wiki it man.
Jul 17, 2009 | ASUS P5WD2 Premium Motherboard
Hi i have a problem with panel1 on M848A v5.0 motherboard i cnt seem to work out how to connect the case properly it looks like this ()()()() ()()()()() i have the power switch, reset switch, hdd led and...
OK, this is for all the idiots who reply and offer NOTHING. You need more info, model and ver? HE ALREADY GAVE ALL THAT INFO.
Type "M848A v5" in google and you will see it is a PCChips mobo AND the manual is here:
http://download.ecsusa.com/dlfilepcc/manual/848Av50.pdf
BUT the manual DOES NOT HAVE THE PIN-OUT, so the manual is worthless...
Here is the pin-out:
(2)(4)(6)(8)
(1)(3)(5)(7)(9)
...and thanks to guntotenmadm
Aug 28, 2009 - The pin layout on the MB are color coded. There is green, orange, pink, and blue. I'll start with the green pins 2 and 4 these are for the power led wires, bottom pin #2 is the + pin (your green wire). Pin #4 is - (your white wire). Now the orange pins, pins 1 and 3 these are for the HDD led. The bottom pin #1 is the HDD + pin (your red wire). Pin #3 is the HDD - (your white wire). Now the pink pins, 6 and 8 these are for the power switch. Pin #6 is the + pin (your orange wire). Pin #8 is the - pin (your white wire). Now the blue pins, 5 and 7 these are for the reset switch. Pin #5 is the - (your white wire). Pin #7 is the + (your blue wire)."""
May 18, 2009 | PC Chips MB PCCHIPS SiS746FX M848A V5.0...
Hooking up case wires to motherboard: ECS M925
If you look at this picture, the pins on the motherboard should be on the far left below the brown slot and above the white connector. The pins on the board are marked with tiny white letters HDD, PWR, RST, SPKR. The USB connection on the board may require a separate header, I can't find a manual to see for sure.
Apr 04, 2009 | PC Chips (M925G) Motherboard
Wiring schmatic for kenmore canistar vacuum
Generally, there are two wires inside the unit which connect to the wiring going down the suction hose.  Since the unit is a/c...it doesn't matter which of them goes to which terminal.  The wires are switched in some cases.  Look for the open terminal.
Dec 19, 2008 | Kenmore 23612 Progressive PowerMate Bagged...
Mag Innovison LT917S LCD Monitor
After looking at the description of the pin outs on the BIT3193 and following signals to/from that chip I discovered I had burned up one of the FETS that I had installed. With the FETS replaced for the second time the monitor works fine now. HEY!!
Jul 21, 2008 | Gateway FPD2275W LCD Monitor
Radio wiring
The connector configuration and wiring color scheme for a Toyota Radio Harness is available here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa
Jul 07, 2008 | 1985 Toyota Pickup
EliteGroup K7VMM Motherboard Logo
287 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Iqbal Husain
Iqbal Husain
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
