Question about Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune Washer won't stop running/or shut off after cycle
The dial goes to "off" but the machine still keeps on running for hours? What do I do about this?.
The only way I have been able to unlock and open the door and stop it from running on the cycle is to hit the "stop" button and then wait approx. one minute for the machine to stop and unlock the door.
Please advise ASAP on this annoying problem
  • 1 more comment
  • xcoconut68 Dec 17, 2008
    Maytag neptune will noy cycle. How do I Fix??
  • Anonymous Jan 30, 2009
    same thing, just before it finishes spinning it starts another 45 minute cycle and always on hot water!
  • sdmc73
    sdmc73 May 11, 2010
    did the unit spin if there is water still in it it will keep running clean the pump sump and the presser hose out
  • 121 Answers
Clean the small presser hose out and check the pump sump make shur there is no obstruction
Posted on Nov 30, 2008
Wash cycle are running to long
FIXED Maytag Neptune, Timer Problem - ApplianceBlog
www.applianceblog.com/.../23387-Maytag-Neptune-Timer-Problem
Mar 4, 2011 - 8 posts - ‎3 authors
My countdown timer is stuck at the 33-minute level in the "wash cycle", and repeatedlyruns for a 30-40 seconds, then stops, then runs, then ... Maytag Neptune TL Washing Machine stops in spin cycle ...
Jul 25, 2013
Maytag Neptune Washer Won't Spin/drain
Jul 4, 2013
Neptune TL Washer FAV6800AWW - DC and UC ...
Jul 3, 2007
MAYTAG NEPTUNE WASHER CONTROL PANEL ...
Jun 29, 2005
More results from www.applianceblog.com
Troubleshooting a Too-Long Wash Cycle - whirlpool washingmachine ...
ask.metafilter.com/233920/Troubleshooting-a-TooLong-Wash-Cycle
Jan 25, 2013 - We have a Whirlpool Duet washing machine (about 2 years old). Thecycle is taking WAY too long to complete. The load that's running now ...
Maytag Neptune washer repair: motor/motor control circuit ...
? 12:10
https://www.youtube.com/watch?v=ITTbDh8CFEU
Dec 11, 2013 - Uploaded by daytonaturbofreak
Maytag Neptune washer motor/motor control circuit board ... my board just fried - is your washer still working? wondering how longthe conversion fix will last. ... Other times it will run a completecycle without any malfunctions.
Jan 11, 2016 | Maytag Neptune MAH5500B Front Load Washer
My maytag neptune front load washer keeps shutting off during the wash cycles. Any idea as to what is wrong and how to fix?
my matag neptune front load washer keeps shutting off durning the wash cycles,and the letters LP keep appearing.Any idea as to what is wrong and how to fix it?
May 01, 2010 | Maytag Neptune MAH5500B Front Load Washer
Washer timer advances all the way to off, but never stops. washer just keeps spinning. new timer is not the solution.
IF THE TIMER HAS BEEN REPLACED AND SOUNDS LIKE IT'S WORKING THERE HAS TO BE A WIRE OUT OF PLACE. THE TIMES HAS CONTACTS THRU OUT THE DIAL TO PUT MACHING INTO DIFFERANT CYCLES AT THE STOP CYCLE THE WASHER SHOULD STOP IF THE CONTACTS ARE GOOD
Sep 06, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag Washer never stops running, goes from 1 cycle to the next
The timer is not stopping the agitate mode. And the timer is suppose to have its own off setting at the end of cycles. Suspect pretty strongly that the timer is at fault. Cant say for sure without looking at a wire diagram and eliminating any other controls.
If this helps you please rate me as high as possible.
If it doesn't help you please rediscribe your problem in more detail to help me understand, post back and I will follow up.
Mar 24, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptun will not agitate or spin
Change your timer. or timer sensor. behind your knobs
Feb 14, 2009 | Maytag Neptune MAH5500B Front Load Washer
MAYTAG Mah4000 front loader washer
HAVE YOU CHECKED THE MOTOR CONTROL BOARD?IT IS LOCATED INSIDE THE FRONT RIGHT BOTTOM OF WASHER BEHIND FRONT PANEL,LET ME KNOW IF YOU FIND ANYTHING-MIKE
Nov 01, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH4000 - Washer won't shut off!
sounds like to me you have a bad board needs to be changed
Sep 16, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune rinse cycle doesn't start.
cold water valve screen plugged or bad valve, just check it!
Aug 06, 2008 | Maytag Neptune MAH6500A Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
690 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
