Question about Kenmore 62602 Electric Dryer
Dryer body very hot, loud squeking, soot from ball in back
Electric Kenmore dryer heats up very hot, has a very loud squeak when operating, and I've noticed some black carbon/soot from the back side of the machine out of the hole with the ball bearing in it. Any ideas?
  • farleycarl Nov 30, 2008
    Carbon soot was from a pad (vibration isolation i think?) that fell out of place and hung down in front of heating coils, it was blackened and charred. Separately, the drum is held in place with a ball and socket. The metal ball had worn/melted the plastic socket down such that the metal ball rubbed against the metal plate holding the socket in place. A new socket fixed the squeek.
    But the dryer still gets too hot, and this may have been the cause of why the plastic socket was melted away. If you touch the top of the dryer when running on high heat cycle you will get burned immediately. SO, WHAT MAKES IT RUN SO HOT? IS THE THERMOSTAT BAD, OR THE HIGH TEMP EMERGENCY SHUT-OFF, OR BOTH?
    Problem Solver:
  • 4 Answers
I would replace the high limit control and the thermostat to be on the safe side. There is a real danger of burning the house down.
Posted on Dec 26, 2008
Loud squeak and not staying hot
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Sep 16, 2010 | Maytag Neptune MDG5500AW Gas Dryer
My dryer has a loud squek when it starts and goes for about one minute and then quits. What should I do?
That is probably a roller or that crappy idler that comes in some models. You need to break it down and do a looksee. Here is a nice pictoral: KENMORE DRYER
Bonus stuff here
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Aug 15, 2010 | Kenmore 62802 Electric Dryer
My gas dryer is not heating up and is making a loud rattle noise.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
heatman101
Aug 13, 2010 | Kenmore 73952 Gas Dryer
My Kenmore front loading dryer squeaks loud now when I start drying clothes. I clean up around the dryer and took the vent off and cleaned the lint and particles out of the vent and vent tube.sometimes it...
either the bottom pulley or the rollers are whats making the squeking noise you can buy a dryer belt kit which comes with two rollers pulley and a new belt for around 25-30 from marcone appliance
Jul 12, 2010 | Dryers
My GE dryer is squeking
Dryer2_bing.gif Repair Squeaks, Grinding, Clicking and Knocking Noise
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Asker's Testimonial " This should give me an ida of what to look for once I open er up "
Feb 22, 2010 | Kenmore 62802 Electric Dryer
417.83142201 just replaced felt pads, upper and
try to lube the rollers on the back wall, where the drum mounts , sometimes the wheel bearings tend to make noise specially when dryer is overloaded and hot
Feb 05, 2010 | Kenmore 83142 Electric Dryer
Dryer squeak and back panel is hot? Frigidaire Dryer FDE436RES1
It sounds like you have a rear bearing bad.
as far as over heating check the vent line. Your thermostats are ok or your high limit would blow and you would have no heat.
Sep 01, 2009 | GE DBXR463EDWW Electric Dryer
Dyrer gets to hot
heatman101
a454a
Jan 04, 2009 | Kenmore 62602 Electric Dryer
Dryer makes squeaking noise ,then dryer shuts off. mdl.#CYG4000AWW
Hello, sounds like the rear drum rollers are in need of replacement which is causing the motor to get hot and cut out on the thermal cut out. It can be tricky to service if you not handy. Good Luck
Oct 19, 2008 | Magic Chef CYG4000AWW Gas Dryer
Kenmore 62602 Electric Dryer Logo
184 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
