Question about Canon PIXMA MP780 All-In-One InkJet Printer
Printing color pictures are streaky
There is new cartridges in there. How do i do i print check or is there a way to clean?
  • 903 Answers
The easiest way to do this if you have not got the software loaded for the printer, is open a document in word for instance, go to File>print and when the print window opens, go to properties, and see if there is a utility tab, if there is click on it and select clean nozzles.
Also have you tried looking under programs, if there is a program for your printer the maintenance tools should be there
Posted on Nov 25, 2008
MFC 240C will not print yellow despite new cartridge
check if plastic cover on ink cartridge . may need a lot of cleaning of print heads may need to get cleaning alcohol and a cloth and clean print head physically
Dec 24, 2014 | Brother Multi-Function Center MFC-240C...
New ink cartridges not printing
The ink cartridges that you replaced are brand new or refilled ?
Thanks
Proton
Sep 07, 2008 | Brother MFC-5840CN All-In-One InkJet...
Print cartridge is missing or not detected.
removed and uninstall the cartridge once more, or cleam with dry cloth the metallic surface on your ink, gently rub until you removed any dirt, if you cannot fix it chances are the cartridge is damage already and you need to buy a new one
Aug 11, 2008 | HP Office Equipment & Supplies
My DSC38 printer is leaving streaky lines all over the printed sheets what do I need to change? thanks
If you have tried a new toner cartridge and that didn't fix it you probably need to put in a new drum or Fuser kit. If it is really old and has had a lot of use I would consider replacing the whole printer with a new one. The fuser kit I saw listed on Amazon for this printer was half the price of a newer printer. If you do a lot of printing or this is in a business environment make sure when looking at replacements that you get one rated for the number of pages you print a month. I have had really good luck with HP and Brother laser printers.
Mar 17, 2014 | DSC GESTETNER - DSc38u Color Printer
Prints pictures faded
On the pixma printer each time you remove a cartridge. you will need to do a clean of the nozles and print head. you can find instructions in your online operators manual. You hold down the wi-fi button and watch the
Home Click Here to Search
MG3500 series > Overview of the Machine > Maintenance > When Printing Becomes Faint or Colors Are Incorrect
Maintenance Procedure
Printing the Nozzle Check Pattern
Examining the Nozzle Check Pattern
Cleaning the Print Head
Cleaning the Print Head Deeply
Aligning the Print Head
Page top
error light flash. 1 flash release prints all saturation levels2 flashes prints the head alignment chart. 3 cleaning 4 flashes deep clean and so on. or its a transfer problem and this case do a transfer belt clean, and a head alignment.
Feb 28, 2014 | Canon Ink Cartridge for Pixma MP252
Color printing problems
check the in printer settings about printing with color, and also on the pc side make sure its not set to black and white only.
Jun 20, 2008 | HP OfficeJet V40 All-In-One InkJet Printer
HP A636 will not print yellow; tricolor cartridge is new
  • Align the print cartridge.
The printer automatically aligns the print cartridge after a new one is installed. You can also align the print cartridge at other times to ensure optimal print quality. Indications that you need to align the print cartridge manually include borderless prints with white space
along an edge, colors not printing satisfactorily, or poor print quality.
To align the print cartridge from the printer
  1. Load a sheet of HP Advanced Photo Paper in the input tray.
  2. Touch the Setup icon to display the Setup menu. For more information, see "Setup Menu" on page 16.
  3. Touch Cartridge.
  4. Touch Align Cartridge and follow the prompts.
Clean the print cartridge automatically.
If the printed pages are missing lines or dots or contain ink streaks, the print cartridge might be low on ink or need to be cleaned.
CAUTION: Clean the print cartridge only when necessary.
Unnecessary cleaning wastes ink and shortens the life of the cartridge.
  • Clean the cartridge.
Follow these steps to clean the cartridge automatically:
To clean the print cartridge from the printer,
  1. Touch the Setup icon to display the Setup menu. For more information, see "Setup Menu" on page 16.
  2. Touch Cartridge.
  3. Touch Clean Cartridge and follow the prompts.
If the documents are still missing lines or dots after cleaning, replace the print cartridge.
Attaching User Manual (see page 59).
http://h10032.www1.hp.com/ctg/Manual/c01518966.pdf
Feb 18, 2014 | HP Photosmart A636 Compact Photo Printer
Streaky printing
I have replaced the color and black cartridge . I have cleaned it and it is still streaky printing. What do I do?
Dec 23, 2012 | Kodak Esp 3250 Allinone Multifunction ( ...
HOW CAN i CLEAN THE HEADS AND RESET THE NOZZLES.
How to Clean Print Heads
Method 1 of 5: Self Clean Program for Windows XP/Vista Users
1 Open the control panel menu and select "printers."
2.Choose the printer to be cleaned and right click. Select "properties" in the drop-down menu.
3. Choose the tab for cleaning. Various printers might have it listed under different names such as services, cleaning or maintenance.
4. Select the nozzles that should be cleaned, if applicable to your printer, and run the printer's cleaning program.
5. Print a test page and check results. Repeat cleaning 2 to 3 times if needed.
Method 2 of 5: Self Clean Program for MAC Users
1.
Click on "system preferences" and select "open print and fax."
2. Choose the printer that needs to be cleaned and open "Open Print Queue" or "Print Queue."
3. Click the utility icon for the applicable printer and select "maintenance." Select "cleaning" from the pop-up menu and click "OK." You might have to choose the tank you want to have cleaned.
4. Run the head cleaning program and print out a test page. Repeat cleaning 2 to 3 times if needed.
Method 3 of 5: Manual Cleaning
1.
Check your printer's owner manual for the location of your print head. Refer to the directions below if the head is in the printer and not part of the individual ink cartridges.
2. Remove the ink cartridges and dab hot water or isopropyl alcohol onto a cotton swab.
3.
Rub the swab against the print head to loosen dried ink. You can also use a dropper to drip 7 to 10 drops of the isopropyl alcohol into the ink receptacle if your print head is deep in the printer.
4. Run the printer's own cleaning program 2 times and then let the printer sit overnight. Repeat the self-cleaning utility the next day.
Method 4 of 5: Cartridge With Print Head
  1. 1Soak the ink cartridge in a bowl of hot water overnight if your print head is inside the cartridge.
  2. 2Remove the cartridge from the water and dry it thoroughly with a paper towel.Put it back into the printer and run the cleaning program. Repeat 1 time if it does not work.
  3. 3Place the ink cartridge into a bowl of isopropyl alcohol and let it soak overnight if the hot water soak did not work.
  4. 4Remove the cartridge and wipe it off with a damp towel before drying it.Attempt the self-cleaning program again. If it does not work this time, you probably need a new cartridge
Method 5 of 5: The Vacuum method
  1. 1I replicated the way the printers themselves try tho clean the cartridges
  2. 2Using a Vacuum cleaner hose
  3. 3attach the printer cartridge to the vacuum cleaner hose with the cartridge upright, nozzle down using plasticine or blu-tack
  4. 4for no more than a few seconds at a time turn on the suction , regulate using the suction or curtains regulator on the vacuum cleaner.
  5. 5Repeat if necessary
  6. 6if the print cartridge is cleaned , ink will be visible , if its a multicolour cartridge the resultant ink will be black if all 3 jets are clean
  7. 7wipe off the residue ink with tissue or toilet roll .
  8. 8Refit & print test page as per other comments .
  9. 9This definitely worked for me and has no know side effects apart from the odd inky finger !
Tips
  • Print a page every 2 weeks or so and turn off your printer when it's not in use to keep the print heads from clogging.
Oct 25, 2011 | Lexmark Z640 InkJet Printer
MY LEXMARK 4505 LEAVES 3-4 BLACK BLOTCHES ON THE EDGE OF EACH PAPER IT PRINTS, TRIED CLEANING THE ROLLERS TO NO AVAIL, ANY SUGESTIONS
ADJUST THE COLOR AND PRINT SPEED You may need to adjust the color and print speed. CHECK THE LEVEL OF INK IN THE PRINT CARTRIDGES 1 From the Finder desktop, double-click the Lexmark X5400 Series folder. 2 Double-click the Lexmark X5400 Series Utility icon. 3 From the Maintenance tab, check the ink levels of the cartridges. If an exclamation point (!) appears on a cartridge, the ink level is low. Install a new cartridge. Improving print quality These are possible solutions. Try one or more of the following: CHECK PAPER • Use the appropriate paper for the document. If you are printing photos or other high-quality images, for best results use Lexmark Photo Paper or Lexmark PerfectFinish Photo Paper. Do not use Lexmark Premium Photo Paper. Your print cartridges are not compatible with this type of paper. • Use a paper that is a heavier weight or bright white. CHECK PRINT CARTRIDGES If the document still does not have the print quality you want, follow these steps: 1 Align the print cartridges. For more information, see "Aligning print cartridges" on page. If print quality has not improved, continue to step 2. 2 Clean the print cartridge nozzles. For more information, see "Cleaning the print cartridge nozzles" . If print quality has not improved, continue to step 3. 3 Remove and reinsert the print cartridges. For more information, see "Removing a used print cartridge" on and "Installing print cartridges" . If print quality has not improved, continue to step 4. 4 Wipe the print nozzles and contacts. For more information, see "Wiping the print cartridge nozzles and contacts". If print quality is still not satisfactory, replace the print cartridges. For more information, see "Ordering print cartridges". CHECK PRINT CARTRIDGES If the document still does not have the print quality you want, follow these steps: 1 Align the print cartridges. For more information, see "Aligning print cartridges" on page 124. If print quality has not improved, continue to step 2. 2 Clean the print cartridge nozzles. For more information, see "Cleaning the print cartridge nozzles" . If print quality has not improved, continue to step 3. 3 Remove and reinsert the print cartridges. For more information, see "Removing a used print cartridge" and "Installing print cartridges" If print quality has not improved, continue to step 4. 4 Wipe the print nozzles and contacts. For more information, see "Wiping the print cartridge nozzles and contacts"
Nov 10, 2010 | Lexmark X5495 All-in-One &USB...
Canon PIXMA MP780 All-In-One InkJet Printer Logo
old marine
old marine
