Question about Casio FR-2650Plus Calculator
How do I replace the ink?
How do I replace the ink in this Casio FR-2650?
  • 374 Answers
There is a little ink roller in there that should just pop out and then you can snap the new one in.
Posted on Jul 10, 2007
SOURCE:
Casio FR-2650A Not Pulling Paper Through
See if the roller gear is jammed or rusted. A little wipe with WD40 may help.
Jan 27, 2012 | Casio FR-2650A Calculator
My Casio FR-2650 Plus isn't printing in the hundreds or thousands place. For example the number 1500.00 looks like 00.00. Can anyone help me?
There is settting for the print setup for this calculator I believe if not then check the print head for build up or blockage
Mar 02, 2011 | Casio FR-2650Plus Calculator
Casio fr-2650 plus is showing an E on the screen and not allowing me to input data. Ideas?
Follow theses steps (from Casio Support) :
First, check the batteries, and ensure there is not a paper jam in the printer.
If both are fine, then while the calculator is in the "Print" mode, press the [CA] (or [AC]) button 20 times consecutively to clear out memory buffers. Try some numerical calculations, and if the problem persists, repeat pressing the [CA] button 20 times.
If the problem still persists, then the calculator may require service
Sep 28, 2010 | Casio FR-2650Plus Calculator
Casio FR-2650PLUS Calculator Error Code
the ink roller installed wrong, remove ink roller, re-install it
May 20, 2009 | Casio FR-2650Plus Calculator
Don't know how to change the ink?
How do I change my ribbon on a CASIO FR - 2650 PLUS
May 15, 2009 | Casio FR-2650Plus Calculator
FR-2650 Plus adding machine
How to install paper tape on a adding machine?
Apr 27, 2009 | Casio FR-2650A Calculator
Casio fr-2650 plus calculator
SETTING YOUR TAX RATE
you hold your set % button down for three seconds until set shows again, then hit tax rate button it shows your tax rate, change your tax rate then hit set your tax rate should be set.
cliff notes:
hold set% button
hit tax+ button
change the desired %
hit set done
Do rate the solution.
Apr 05, 2009 | Casio FR-2650Plus Calculator
How to ink Casio FR 1211 Printing Calculator
I have a Casio FR-1211 Printing Calculator and I have the same problem. I removed the roller and tried inking the roller with "Sanford's Roll-On Stamp Pad Inker". It works beautifully ! I don't know how long it will last, but for now the print is dark and clear.
John
Apr 05, 2009 | Casio Office Equipment & Supplies
Changing Tax calculation
Printing models (except HR-8TE): 1. Have calculator in ?print? mode 2. Press [CA] 3. Hold [SET/%] key for about 3 seconds 4. Input the tax rate 5. Press [TAX+] 6. Press [SET/%]
Feb 15, 2007 | Casio FR-2650Plus Calculator
Casio FR-2650Plus Calculator Logo
1,147 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Colin Stickland
Colin Stickland
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
