Question about Canon PIXMA MP530 All-In-One InkJet Printer
White bands on color photo prints
Whenever I print color photos, there are white bands, about 1/4 inch wide and about 1/16 of an inch apart, covering the entire print. I get the same results regardless of the quality of paper. This condition existed even when the printer was new. Is there an adjustment I can make, or am I stuck with this situation?
    Scholar:
  • 134 Answers
Perform Print Head Alignment Instructions to perform a Print Head Alignment directly from the machine. If diagrams or ruled lines are misaligned, print head alignment is required. The print head alignment can be performed automatically or manually. If the automatic print head alignment does not work, adjust the print head manually. Automatic Print Head Alignment
  1. Press <ON/OFF> to turn on the machine.
  2. Load a few sheets of letter-sized plain paper in the auto sheet feeder.
  3. Press the Open button to open the Paper Output Tray. Then open up and set the extension by pressing down the hollow on the front side.
  4. Execute automatic print head alignment.
    1. Press <COPY> button.
    2. Press <Menu> repeatedly to select [MAINTENACE].
    3. Press the left or right cursor to select [AUTO HEAD ALIGN], then press the <OK>. (A pattern is printed and the print head is automatically aligned. It takes about five minutes to finish printing the pattern.)
Manual print head alignment
  2. Load two sheets of Letter-sized plain paper in the auto sheet feeder or cassette.
  3. Ensure that the proper paper source is selected.
  4. Execute manual print head alignment.
    1. Press <Menu> repeatedly to select [MAINTENACE].
    2. Press the left or right cursor to select [ALIGN PRINT HEAD], then press the <OK>. (The nozzle check pattern is printed.)
  5. Check the printed patterns and use the left or right arrow to input the number of the pattern in column A that has the least noticeable streaks.
  6. Press <OK> to move the cursor to column B, and then use the left or right arrow to input the number of the pattern that has the least noticeable streaks.
  7. Repeat the procedure until you finish inputting the pattern number for column P.
  8. When you have finished inputting all pattern numbers, press <OK>.
    Note: For columns A through N select the patterns with the least visible vertical streaks. For columns O and P select the patterns with the fewestwhite bands on color photo prints - align_compare.jpgal streaks.
    <1> Example of the pattern with the fewest visible vertical streak
    <2> Examplewhite bands on color photo prints - mp500_alignment_manual_3.jpgt visible vertical streak
    <1> Example of the pattern with the fewest visible horizontal streak
    <2> Example of the pattern with the most visible horizontal streak
I hope it helps!!!
Posted on Dec 01, 2008
Uneven color on photo prints.
You need to clean your print cartridges.
Go to servicing the device in printing preferences or settings.
It should print a test page and your prints should be fine.
Aug 02, 2010 | Canon PIXMA MX310 All-In-One Printer
Mutiple lines on right side of photo
try removing the ink cartrage and clean the heads in the printer with a quetip and rubbing alcohol. same with the cartrages.
Nov 12, 2007 | Canon PIXMA iP5000 InkJet Photo Printer
On the right hand side of a print there is a band about 1 cm wide
For the last half inch or so of the print the printhead swaps the direction of print - if you listen you can hear the change, and, if you open the cover and wedge something into one of the now exposed holes on the left side, to push down the switch (this will fool the printer into thinking that the lid is shut and enable you to print) thenyou'll be able to watch it as well.
It must be something to do with the end of paper sensor triggering it, but why it has the effect of creating this banding I've no idea. By all accounts it's a common problem with the i9950. Some folks report sticking a post-it note to the top back corner with an inch or so showing fools the sensor. I've not had any luck with this but it's worth a try.
Mar 27, 2010 | Canon BubbleJet i9950 InkJet Photo Printer
The text of a document will not print. The
Print From Your Computer : Windows Printing Select Basic Options Click the Main tab on the top of the printer settings window to select your basic print options. 1. Select a Quality Option that matches your document or photo, and the print quality you want. Quality Option settings WebWorks_WriteArrow(WebWorksRootPath, "wwdd1032347", false); WebWorks_WriteDIVOpen("wwdd1032347", false); • Draft: for rough drafts with reduced quality • Text: for documents containing only text • Text & Image: for documents with text and images • Photo: for photos and graphics with good quality and print speed • Best Photo: for photos or graphics with high print quality WebWorks_WriteDIVClose(); 2. Select the paper Type setting that matches the paper you loaded. 3. Select the paper Size setting for the paper you loaded. Paper size settings WebWorks_WriteArrow(WebWorksRootPath, "wwdd1032380", false); WebWorks_WriteDIVOpen("wwdd1032380", false); You can load paper in these sizes and select the size in the printer software. (Wider papers are for use only when reducing large images with the Reduce/Enlarge Document option.) A User Defined option is also available so you can create a custom size. A4 (8.3 × 11.7 inches) A6 (4.1 × 5.8 inches) Letter (8.5 × 11 inches) Legal (8.5 × 14 inches) Half Letter (5.5 × 8.5 inches) 3.5 × 5 inches 4 × 6 inches 5 × 7 inches 8 × 10 inches 16:9 wide (4 × 7.11 inches) Envelope #10 (4 1/8 × 9 1/2 inches) WebWorks_WriteDIVClose(); 4. If you’re printing borderless photos, click the Borderless checkbox. For documents or photos with borders, select Borders. Note:
For borderless photos, make sure you loaded a compatible borderless paper size and type. 5. Choose Portrait or Landscape orientation for your document or photo. You can also:Select Print Options Select Basic Options Click the Main tab on the top of the printer settings window to select your basic print options. Select graphics & text. USER'S MANUAL EPSON WEBSITE: http://files.support.epson.com/htmldocs/cx44__/cx44__ug/wwhelp/wwhimpl/js/html/wwhelp.htm
Jul 22, 2009 | Epson Stylus CX4400 All-In-One InkJet...
Epson Stylus Pro 4800 Never Before Seen Banding Problem
Clean the nozzles, align the print heads, turn it off for about an hour. You may need to do this twice, but it works for me.
May 26, 2009 | Epson Stylus Pro 4800 InkJet Printer
Canon pixma ip3000 print problem
tthanks about that but i dont know how to deel with that
Dec 05, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Printer is Not using all the colors when printing?
if you download the ssc you can do a power clean if you dont have this tool let me no
Nov 16, 2008 | Epson Stylus CX9400 Photo Printer
Problems printing photos
please specify what printer, model,
Jul 23, 2008 | Apple HP Officejet G85xi InkJet Printer
Inkjet photo printing
This may sound idiotic, but print out a nozzle check pattern in your maintenance tab. Good chance you have a clogged printhead. Check out how to do a print head cleaning and what solutions and tools you'll need. Careful if you're using compatible inks or refilled cartridges, or long expired ink.
http://www.simplyinked.com/support/index.php?tsrc=knowledgebase&act=24&category=C5
This one works great for me. Go GENTLY, best not to use Windex or any unauthorized solutions, as they may cause damage to plastic parts.
May 30, 2008 | Epson Stylus 2200 InkJet Photo Printer
White bands across printouts
Either one of the print heads are bad or a cartridge. This is what causes that problem. I know it is a hassle but I would take it back. If try and fix it you could void the warranty.
Mar 16, 2007 | Canon PIXMA iP4000 InkJet Photo Printer
Canon PIXMA  MP530 All-In-One InkJet Printer Logo
727 people viewed this question
old marine
old marine
