Question about Alpine CDE-9845 CD Player
Not much sound from external amp.
Hooked up Optimus 200w. amplifiier w/ MTX Thunder 5000 speakers, using RCA cables from rear output jacks. Sound comes out of factory speakers just fine, but MTX speakers don't move or make much noise. Is it something to do w/ POWER IC setting, or is there another setting that I should try? Any info to help solve my problem would be greatly appreciated!
Check the gain
Posted on Dec 19, 2008
Getting no sound hooked up to pre-amp and 2 rotel 200w amps with snell speakers
You didn't say whether the player is connected by 2 RCA cables (analog) or by digital cable. If by RCA, does the player have a headphone jack? I had a player once with a piece of a headphone that broke off inside the jack, muting the analog outputs.
May 16, 2014 | Sony CDP-CX300 CD Player
Connecting tv external speakers
If you connected R/W RCA cables to the AUDIO OUT RCA jacks on the rear of the TV and connected the other ends to the TV AUDIO IN jacks on the receiver, you should be able to select an input on the receiver that will deliver sound to the Bose speakers. If you went to TV setup and selected external speakers, you directed output from the TV amplifier to external speakers which is not what you want.
Jan 27, 2014 | Televison & Video
My mtx thunder 6500d amp hums when connected light turns on but no output
Make sure you have a proper ground wire connection. The ground wire should be connected solidly to the vehicle chassis in a paint-free location. If it is loose or there is paint t the connection site, you will have problems with the amp output. Also check the speaker wires to see if they are touching the vehicle chassis. This will cause a short circuit and you will not have output from the amp. Finally, check the leads from the head unit. They should be RCA cables, and should have a good connection to the amp.
Feb 22, 2011 | MTX Thunder 6500D Car Audio Amplifier
MTX Thunder 3401 not responding. Lit but no sound.
turn down music open sub box and put another speaker at wire and check again if work means sub is ok if not check the signal cable, and put there the speaker to try signal
Apr 05, 2010 | MTX Thunder 3401 Car Audio Amplifier
I have a 42 inch sanyo tv I am trying to hook up saround sound or just extra speakers
Extra speakers without having the external speaker jacks in the rear is definitely a NO NO. The surround sound is used by connecting the RCA jacks from the TV that say Audio Out to the surround sound audio input on the receiver.. The RCA cables are cheap, you can get them at Home Depot ect....
Nov 27, 2009 | Sanyo Televison & Video
Feedback issues.
Did you run your power and remote wires the same route as your RCA cables? If you dont run the RCA cables on the opposite side of the power and remote you will get feedback through your speakers. I run my power on the side closest to the battery along with the remote ( passenger in my case) and the RCA cables should be on the opposite side( driver side). They say the power current will create a disturbance in the RCA cables that you would hear as feedback. Hopefully this will help you.
May 28, 2009 | MTX Thunder 8302 Car Audio Amplifier
My mtx thunder 1501d car amp making noise in the subwoofers
This is common with pioneer head units, the rca jacks are not properly grounded and this lets engine noise come through the rcs cables. This thread explains a fix http://www.caraudio.com/forum/showthread.php?t=337644.
Nov 13, 2008 | MTX Thunder 1501D Car Audio Amplifier
THUNDER 5601 WHEN VEHICLE TURNED ON, SUBS BOOM, THEN WORKS OK. ALSO WHEN RADIO TURNED OFF
If the amp produces no boom with no signal input cables connected, I'd suggest using an LOC.
Let me know if you have any other questions.
Sep 30, 2008 | MTX Thunder 3401 Car Audio Amplifier
My tweeters do not give sound
just run the tweeters to the front speaker channels on the radio
Mar 10, 2008 | MTX Thunder 1501D Car Audio Amplifier
Alpine CDE-9845 CD Player Logo
81 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
