Question about GE GSS25JEMWW Side by Side
Icemaker works fine, only dispenses water
I have a GE side by side with ice and water in the door. Icemaker works as it should but when the lever is pressed to dispense ice, the lights on the door dim, the flap in the door opens, but nothing else. Water is dispensed fine. With the solenoid that upens the flapper in the door unhooked, the motor runs the auger in the icemaker. So I know the motor is good. Also the solenoid checks out good. I replaced the control board and the problem stays the same. Could this be the motherboard??
Make sure that the ice shoot is not clogged up with ice or the in the ice basket where the ice goes through. Sometimes the ice can be stuck together and jam and nothing will come out.
Posted on Jan 08, 2009
  • Andy Corbin Oct 03, 2011
    I emptied the ice basket just to make sure that wasn't the problem.
My icemaker has stopped receiving water
it sounds like your water valve is bad. you have a double water valve - one side operates the ice maker and the other side operates the water dispenser. the ice maker side of the valve is bad.
you can manually pour a little water in the ice maker ice mold and wait an hour or so - if it dumps the ice then you know for sure that the ice maker is cycling and water is not getting to the ice maker from the water valved
May 25, 2010 | GE GSS20IEP Side by Side Refrigerator
Ice maker isn't making ice, but the water works just fine.
switch the wires on the water valve (it has two plugs) and depress the water lever and see if the icemaker fills with water, if it does, change the icemaker, if it doesn't change the water valve. make sure there is no ice obstruction in the fill tube in the freezer
Oct 01, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Icemaker does not make ice after first harvest.
theres whats called a cam inside of the ice maker and that is more than like;ly the problem. you can but your own ice maker from place like first service. good luck.
Jan 30, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Monogram ZISS480DMCS Ice Maker Problem
i would first check water supply to ref. measure the resistance of coil either open or resistance. if all this is ok then exit side of line needs to be checked for water.
Sep 22, 2008 | GE Monogram ZISS480DRSS Stainless Steel
Water not being dispensed thru the door
There is a solenoid-actuated water intake valve in the back of the refrigerator. Actually there are two - one for the icemaker and one for the water dispenser - which are usually combined into one assembly. Sometimes the electromagnetic coil burns out in one of them. The other possibility, which is less likely, is a bad mocroswitch at the dispenser where you press the lever.
Jul 25, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice/Water Dispenser in Freezer door not working when you press the lever. Also the light dims when lever is pressed. Icemaker working fine.
Sounds like a frozen waterline. I fixed mine by leaving the light on the dispenser on. It took about 6 hrs, but the little heat from the light bulb was enough to defrost the water line.
Nov 28, 2007 | GE GSS20IEP Side by Side Refrigerator
GE GSS25JEMWW Side by Side Logo
342 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
