Question about Sony CDU4811 48x IDE CDROM drive (CD-U4811) CD-ROM Drive
FATAL DISK ERROR, RETRY
When i run my program/application i got error like below.
Error Window Title "LIBRARY MANAGER"
Error Message "FATAL DISK ERROR, RETRY?"
There are also two buttons RETRY and CANCEL.
  • 2 more comments
  • t15474 Jan 22, 2009
    fatal disk error, retry?
  • bhoopal12584 Mar 02, 2009
    when i run my program/application i got error like below.
  • umali2000 Mar 16, 2009
    whin start oracle file exe I receved massege fatal disk error
  • arif rashel
    arif rashel Mar 24, 2014
    I am facing the problem too. pls help if any solution..
I need a support from you
Thanh you very much!
Posted on Jan 13, 2009
    New Friend:
I am also facing the problem...
Pls help.....
Posted on Mar 24, 2014
  • Arif Rashel Apr 03, 2014
    I solved the problem with sallitykiller.
One thing to check is connectivity and permissions on any nework paths or folders the sofware you are using is accessing or writing too.
Regards
software development team
www.demonsolutions.co.uk
Posted on Jan 06, 2009
I have solved the problem with salitykiller.
Thanks.........
Posted on Apr 03, 2014
What is the Android Architecture?
The Android Framework is an important aspect of the Android Architecture. Here you can find all the classes and methods that developers would need in order to write applications on the Android environment. Real Time Live IEEE Project Project Titles Projects Titles Projects...
Jun 09, 2014 | Broadcom BCM94306MP - IEEE 802.11b/g...
Flash MX 2004 configuration
there are few steps you can try
Create a fresh Login ID for your Windows OS
Login with new ID
Increase your Virtual Memory
remove the slack files in Temp folder, You can use ccleaner addition to disk clean up.
Secure the registry changes, (you may you use spybot tea timer)
Please let me know the details, like your current operating system, RAM, CPU, Exact version of your Flash MX
Good Luck
Mar 24, 2008 | Macromedia Flash MX
Tip
Xpcom_core.dll file error
The xpcom_core.dll is included with Mozilla (Firefox) enables the Mozilla program to be an actual framework. The xpcom_core.dll module provides a development environment that includes file abstraction, component management, memory management and object message passing for software developers.This DLL allows for the access of components that can be contacted from a web browser or scripted from any application from Mozilla.
If you're having an issue with your xpcom_core.dll file, the exact message displayed will vary. A few examples are listed below:
  • "The dynamic link library xpcom_core.dll could not be found in the specified path"
  • "Missing component xpcom_core.dll"
  • "This application has failed to start because xpcom_core.dll was not found"
  • "xpcom_core.dll is not loaded"
This dll file can be downloaded by clicking here
on Apr 25, 2010 | Microsoft Windows XP Professional SP2
Hi,my laptop become so slow and its keep freezing
Head over to download.com and do a search for Ccleaner. Once you download and install it, run the cleaner and registry fixer. Registry errors are a common cause for a computer slowing down. If you are running Windows XP, a good idea would be to change the size of paging file which will increase performance.
http://www.microsoft.com/resources/documentation/windows/xp/all/proddocs/en-us/sysdm_advancd_perform_change_vmpagefile.mspx?mfr=true
May 09, 2011 | Fujitsu AMILO PC Laptops
The error message says fatal system error.
Hi. The STOP 0xC000021A error occurs when either Winlogon.exe or Csrss.exe fails. When the Windows NT kernel detects that either of these processes has stopped, it stops the system and raises the STOP 0xC000021A error. This error may have several causes. Among them are the following:
  • Mismatched system files have been installed.
  • A Service Pack installation has failed.
  • A backup program that is used to restore a hard disk did not correctly restore files that may have been in use.
  • An incompatible third-party program has been installed.
Booting the computer to its Last known good configuration will resolved the issue. Please see procedure below:
Turn of the computer
Keep on tapping F8 key the moment you press the power button
You should be getting a advanced boot screen
Select Last known good configuration from the selections then hit enter
Computer should be booting up by now to windows
All the best!
Jul 24, 2010 | Acer TravelMate 2480-2968 Notebook
Fix the fatal error in my warcraft 3 frozen throne
This application has encounter a critical error:
FATAL ERROR!
Program: F:\games\lan games\warcraft 1.24.1.6374\war3.exe Exception 0xC0000005(ACCESS_VIOLATION) at 001B:15019B9E
The instruction at '0x15019B9E' referenced at '0x57746E65' Ther memory could not be 'read'
Press OK to terminate application.
Then:
Frozen Throne was unable to locate your CD-ROM drive. Please make sure your Frozen Throne disc is in your CD-ROM drive, then click on 'Retry'.
Oct 22, 2009 | Blizzard Entertainment WarCraft III: The...
Install MS office home and student 2007
Reboot
Shut down any active protection software such any antivirus, antispyware, antitrojan, or registry monitoring software.
Try to Unistall by using the install disk. It should detect a previous installation and ask if you want to Install, Repair, or Uninstall.
If that fails, download and run CCleaner - Use the Cleaner and Regisrty modules default settings
http://www.ccleaner.com/
Reboot, and shut down active protection software.
Download and run Windows Installer CleanUp Utility.
http://support.microsoft.com/KB/290301
Remove the applicable entries.
Reinstall
Hope this helps - good luck!
Nov 01, 2008 | 10 10 Computer Network adapter Cable...
Fatal disk error, retry? error comes . pls help. o.s. windows nt citrix envirinment s/w- oracle-pb erp system
Hello rbirnale,
Are you using a CD? Do other disks work? Or is it just that disk that gives that error? If CD is a problem, I would try to get another copy, if that is not possible... I have used cd fixer machines before, they have worked well for me in the past.
Chester
Dec 26, 2007 | Sony CDU4811 48x IDE CDROM drive...
Computers & Internet Logo
9,997 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
