Question about JVC AV-60D501 60" Rear Projection Television
I have a JVC AV-60-D501 projection tv. At first there was a 1" black line with a little rainbow effect. Then it happened on the bottom too. After that when you would turn on the tv it would be a green screen for a while, but then would go back to the right colors. Then the picture went darker, so I have it all the way to bright. All of a sudden a set of four lines would appear in the middle of the screen. When you would change the channel and change it back it would go away for a while. Then all of a sudden one day the set of four lines became two. Then it bacame more with them moving up the screen. I took off the back of the tv. All three bulbs are on and no blown fuses. What else is it? Please help
  • skithree Nov 25, 2008
    What is a convergence board? Where is it located? Is it the big board inside on the bottom of the tv where the fuses are?
  • 51 Answers
Convergence board is failing
Posted on Nov 25, 2008
The picture is showing multiple images with red, green and blue rainbow effect. The picture is also bowed on the top and bottom
This is whats called a convergence failure. You will need to call in a repair shop or goto sites like www.TvRepairKits.com hthat ave the parts to fix this yourself. Its a common failure on projection TV sets.
Aug 07, 2011 | JVC AV-56WP74 56" Rear Projection...
Picture has lines and goes black after warm up
Try unplugging for 2 mins. Or press power button for 30 seconds. Your Light in the tv might be shot.... happens every 5 or so years.
GOOD LUCK
CNBY
Jun 03, 2010 | JVC RM-C18G-1H Remote Control
PROJECTION BULB GOINNG OUT. RAINBOW TYPE COLORS APPEARING ON SCREEN. WHAT IS THE REPLACEMENT BULB # ??
Problem is you convergence ICs, you need to replace Both of them STKs big black ICs will have part number on them .Mats has ICs 1-800-628-1118
Mar 17, 2010 | JVC AV-65WP74 Rear Projection Television
My picture is like a 3D effect and is getting worse
Your problem is a converge alingment. in most JVC projection TV,s The main problem for to happen is heat eventully breaking down the solder on the converge ICs which destroys them you can still bye them at most electronic parts supply stores .
Jul 07, 2009 | JVC AV-48WP30 48" Rear Projection...
Rainbow on the screen
Do you have any larger speakers close to you tv. Or any magnets been neer it. If you unplug it for a while the tv should have remove the rainbow
Aug 28, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Phillips 60PP920217F bows in on top and bottom
convergance amp ic are bad.
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Nov 28, 2007 | Philips 60PP9202 60" Rear Projection...
Bowing red lines at top and bottom of screen
Try this, it might be just the thing:http://www.techlore.com/article/15929/Fixing-My-Own-TV/?textpage=3
Sep 19, 2007 | JVC AV-48WP30 48" Rear Projection...
JVC AV48WP34
I have a JVC AV-48WP30, and I had a lot of issues w/ red lines appearing on my screen. If your problem is like mine, then you have to find the video processor, which is a small, squarish metal box on the main board right behind where the a/v plugs are on the back, and jiggle it a little bit, maybe stick a zip tie on there. That always made my lines disappear.
Sep 11, 2007 | JVC AV-48WP30 48" Rear Projection...
Tv screen waves and is double
No. You have bad convergence output ic;s and probably at least 1 burnt resistor. This liely will have to be reconvergec in the servcie menu after the aprts are changed.
Jul 12, 2007 | JVC AV-56WP30 56" Rear Projection...
JVC AV-60D501 60" Rear Projection Television Logo
218 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
