Question about Panasonic PT-50LC13 50" Rear Projection HDTV
Need LCD lamp for panasonic PT-50LC13
I would like to purchase lamp and use the housing of the old one. Can I do that? Where can I purchase the lamp? Is it recommended?
  • 51 Answers
Sure - worst thing that happens is that the lamp could blow up if you don't have an exact match. Get something in about the same lumen outout and you absolutely can re-use the module. There used to be a place called Zeeco sales, Don Zeiller in FW texas you could get them from. You may also search for used lamps on ebay. Keep your fingers off of the glass.
Posted on Nov 25, 2008
Panasonic PT-50LC13 50 blinks 8 times at power button
hi, make sure the lamp is fitted securely and the lamp cover as well you may need to reset the lamp counter hope it helps
regards
shaun
Nov 27, 2011 | Panasonic PT-50LC13 50" Rear Projection...
How to reset lamp timer on pt 50L C-13
Their manual says:
After lamp replacement, you must reset the lamp
time. Refer to the instructions enclosed with the
lamp unit (Part No.: TY-LA2005).
lamp unit (Part No.: TY-LA2005)."
http://www2.panasonic.com/consumer-electronics/support/Televisions/LCD-Projection-TVs/model.PT-50LC13
Aug 09, 2010 | Panasonic PT-50LC13 50" Rear Projection...
Red lamp
If it is a new bulb and does not come right on you need to take the platis housing off of the old bulb and put the new bulb in the old housing, the new bulbs dont always fit just right
Jun 08, 2010 | Panasonic PT-50LC13 50" Rear Projection...
Need to replace bulb in lcd panasonic
After lamp replacement, make sure that lamp cover is properly fixed on its location and if TV still does not turn On then it is ballast power supply issue, qualified TV tech will fix it.
If you think you can repair ballast supply and have enough knowledge about TV repair, let me know to provide you technical info about that.
Oct 02, 2009 | Panasonic PT-50LC13 50" Rear Projection...
Lamp power supply board on Panasonic PT-50LC13 mulfunction.
You can purchase the lamp supply thru "Encompassparts.com... The cost is $100.00, there is a $250.00 core charge on that module, so when you return the old they refund the 250. Initial investment will be 350.23 then take the 250. off that. That will be the end cost.
Part # LSEB3087A
Apr 16, 2009 | Panasonic PT-50LC13 50" Rear Projection...
I have a Panasonic 50" LCD TV PT-50LC13 and the power botton blinks orange 2 time and there is no pic but i can here the fn runing what can i do???
if the tv keps trying to turn on three times and later the lamp led stays steady red. (see owner's manual to replace the lamp process) the lamp is damaged. ones you open the lamp door and take the lamp out you can see the lamp damaged even before to buy it.
Apr 08, 2009 | Panasonic PT-50LC13 50" Rear Projection...
Can't locate housing
The lamp comes out the front of the tv. There is a rectagle pice of plastic on the front that pops off and then there is a lamp door about 8 inches left of center with one screw in it. take that one screw off so you can get to the lamp, then take the screw out of the lamp and it slides right out.
Let me know if you need any more help!
Tim Nolan
Sep 12, 2008 | Panasonic PT-50LC13 50" Rear Projection...
Panasonic PT-50LC13 Television Lamp Replacement
not really, just be careful about getting finger prints on the lamp as the oils from your fingers will shorten the lifespan of the lamp.
Mar 17, 2008 | Panasonic PT-50LC13 50" Rear Projection...
Panasonic pt-50lc13 shutting off
i'm on my 3rd bulb in 5 yrs. i hate this tv. this time my bulb light didn't come on. instead the power light flashed green fast then went to red flashing after. i took out the bulb and it's blown!
Nov 19, 2007 | Panasonic PT-50LC13 50" Rear Projection...
Panasonic PT-50LC13 50" Rear Projection HDTV Logo
47 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
