Question about Indesit W 123 Front Load Washer
Terrible Smell There is a terrible smell emanating from my machine. I have tried products to clean drum etc but still did not help. The smell is like a wet dirty mop. Can you help me with a solution?
    Problem Solver:
  • 8 Answers
Soda crystals  -  whole packet about the same size as a small bag of suger - into the drum -select 90 degree wash with NO prewash -let it run through . very hard too get rid of smell completly but if u repeat the process a few weeks later and do a hot wash[90 degrees] at least once a week you should notice the difference ---  hope this helps
Posted on Oct 25, 2007
I understand that problems with smell are to do with bacteria that build up when low temperatures are used most of the time. Try doing a hot wash occasionally without clothes. That should eliminate the smell. You may want to do it with a biological liquid too.
Posted on May 10, 2007
  • 175 Answers
Most of the time this smell can be taken care of by adding white vinager to the wash cycle through the soap dispenser whil e it is running. you may have to use quite a bit to do the trick, and even run it through several times. the second thing you can do is if you arent already, leave the door ajar when the machine is not in use so it can breath so to speak. hope this helps
Posted on Jan 13, 2007
2 Suggested Answers
  • 30 Answers
SOURCE: Terrible Smell
Try a Quarter cup of dish washer detergent and a hot wash. this will flush out the inner bowl. Make sure you use the powder only and watch for over foaming. You might be getting a funny smell from the fabric conditioner.This stuff forms badly to the side of the bowls like glue. You couild take the bowl to pump hose off and clean the system out including the pump making sure you unplug the washing machine first. I would personally flush it out two or three times first. steve NZL, keep it simple
Posted on Jan 05, 2007
How do I get rid of this terrible fishy smell from my freezer/refrigerator?
Hello Heather.
Have you had anything wrong with fridge that caused the smell.
Try charcoal in both fridge and freezer.
Hope it will help.
Fish smell is hard to get read off
May 21, 2015 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Terrible smell from the washer. This is a new
do not use baking soda this will react with your detergent and leave smelly deposits and reduce the wash performance modern good quality detergents contain everything needed for a good wash result and a sweet smelling machine. try a hot wash with detergent and an empty load to get rid of smell.
Nov 07, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Terrible smell coming from our washing machine
remove bottom cover at back of machine, loosen large jubilee clip on hose between drum and pump. pull hose down and off, take out strainer basket and pull top off, clean top, ball and basket by running under tap. clean out hose with an old rag. reassemble strainer and put back into hose, in the correct position. fix hose back on to drum and tighten clip. run machine on a hot wash and all should be fine.
Nov 04, 2009 | Hotpoint Ultima WF860 Front Load Washer
Dirty smelly front loading washing machine
you need to find and clean the water return filter
Oct 11, 2009 | Washing Machines
Mymachine smells terrible all the time. What can I
TRY RUNNING A LOAD WITH A HIGH CONCENTRATION OF BLEACH THE SMELL IS PROBABLY A BACTERIA OF SOME SORT
Aug 13, 2009 | Maytag Washing Machines
Terrible mildew type smell
Water forms in the Bellows it is a rubber boot between the door the drum.. clean this out real well ..To prevent this in the future leave the door cracked open when you are done using the machine to allow it to dry out.
Aug 25, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Terrible smell in washing machine
I used white vinegar in the machine and did a full wash.
I am subsequently not using a softener in the machine as I have found out that this is what caused the smell.
I now use white vinegar instead of softener and this has solved the problem.
Jul 01, 2008 | Washing Machines
Terrible Smell
Jan 04, 2007 | Indesit W 123 Front Load Washer
Indesit W 123 Front Load Washer Logo
255 people viewed this question
Top Indesit Washing Machines Experts
shaun taylor
Marvin
Marvin
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
