Question about Kenmore 62602 Electric Dryer
No heat in dryer - kenmore model 110 60902990
Thought the heating element went bad so we replaced it. Still no heat. For a while I had low heat only and it went out and have no heat on any setting. We cleaned the vent and lint traps, too. Don't have a diagram to replace the fuse. Where would it be? What's the next step if the fuse is not the problem?
    Sergeant:
    Champion:
  • 291 Answers
The themofuse is in 1 of 2 places ,,,, on some you take the back off and its on the excust pipe or take the bottom front down on it is on the pipe there ,,,, it dont look like a fuse your used to seeing ,,, it is a small plastic piece with only 2 wires connected to it ,,,, be sure to have dryer disconnected before replacing
Posted on Nov 25, 2008
I have a Kenmore fabric care 220 dryer cleaned the left side sensor started to heat went cold again
Heating elements could be going bad. Or the high temp fuse is out. Check the fuse for continuity and inspect the element for any breaks in the wiring
Jul 28, 2015 | Kenmore Dryers
KENMORE DRYER JUST STOPPED HEATING UP WHAT CAN I DO TO REPAIR IT?
Replace the Heating Element. The heating element is usually located behind a panel on the back. To replace you will need to remove the back cover of the dryer, then locate the heating element. The heating element is screwed into place and is easy to unscrew and replace. Be sure to have the dryer unplugged while doing this.
Here is the part for it:
http://www.repairclinic.com/Kenmore-Dryer-Model-11060602990-ID-501912-Heating-Element-Parts
Mar 13, 2013 | Dryers
I have a kenmore dryer model 96585210 it wont heat up
The Heating Element went out and needs immediate attention. A simple replacing of the heating element will fix your issue. 10-15 minute job.
Apr 18, 2011 | Dryers
Heating element quit working on model # ler4624bw2 Whirlpool electric dryer
Hello there
Here is a couple of links that will help you replace the heating element along with some manufactures that can also help ok?
Best regardss michael
  1. Whirlpool Dryer Heating Element 279838 Kenmore | Estate ...unknown.gif ... REL4632DW0,LER6638DW0 LER4624BW2,LER7646AW2,KEYS677EZ0,REL4632DW1,LER6638DW1 ... Model: Whirlpool | Kenmore | Sears | Roper | Kitchen Aid | Estate. Shipping ...whirlpoolpartssurplus.com/cart/whirlpool-dryer-electric-h...
  1. How to Replace Your Electric Dryer's Heating Elementunknown.gif How to Replace Your Whirlpool, Kenmore, Roper, or Kitchenaid. Electric Dryer's Heating Element ... 3 styles of heating elements in use for these dryers. ...www.davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm - Cached
  2. How to Replace the Heating Element in A Whirlpool Dishwasherunknown.gif How to article - how to replace the heating element in a whirlpool dishwasher. When your dishwasher heating element goes bad, your dishes will not dry quickly. Before...ehow.com/how_5337380_replace-heating-element-whirlpool-di...
  3. How to Replace the Heating Element in A Whirlpool Ovenunknown.gif How to article - how to replace the heating element in a whirlpool oven. If the lower heating element in your Whirlpool oven no longer gets hot, or if you n
Oct 15, 2009 | Whirlpool Dryers
Heating element or coils not glowing and getting no heat model is a kenmore 70 series and is electric
Bad Thermal High limt,
Bad Thermistor,
Bad heat element.
Need model number, located on inside of door, usually.
Oct 01, 2009 | Kenmore 62882 Electric Dryer
I have a Kenmore electric dryer that suddenly went ''poof'' (like when a light bulb that goes out). It threw the breaker. I reset the breaker and the dryer started. I thought that was all there was to it,...
Q - My electric dryer runs but will not heat, what could stop my dryer from heating?
A - Things that could stop a electric dryer from heating:
- house fuse or breaker ( needs two of them ), heating element, burnt wire, thermostat(s), thermal fuse ( not all models ), motor heat switch, timer, selector switch, burnt power cord/plug.
A ohm meter test for these parts is here.
Mar 03, 2009 | Kenmore Dryers
Whirlpool dryer low heat works low heat does not
You may have either a bad thermostat control or wiring to the heat element burned in 2. Are you getting power coming out of the control switch when it is on high. If you are, then the element or wiring is bad. If you aren't, then more than likely it is in the control switch. Let me kmow how you do.
Jan 07, 2009 | Kenmore 62602 Electric Dryer
Kenmore Dryer
I am sorry to hear this, my name is Marc White, i am self employed and it seems as though you have a bad timer, bad timer will cause the timer not to go to the off position and blow your fuse......change your timer..
thanks
Apr 03, 2008 | Kenmore 73952 Gas Dryer
Dryer produces low heat but not high heat
check the vent outside it seems to be getting too hot and cycling the element off and on your safety therm.
Oct 22, 2007 | Kenmore 62802 Electric Dryer
Kenmore 62602 Electric Dryer Logo
201 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
