Question about Samsung Computers & Internet
Problem with lcd 22'' tv come monitor connection
Sir,
I have L series 22" lcd tv cm monitor samsung
Initioly i connected to cpu by VGA to VGA cable it was working properly. but when i chang the display seting by 1600 X 1025
i got the message on screen 'MODE IS NOT SUPPORTED'
THE message is still there my tv mode is working well but now i can't shift to pc mode when i shift to pc mode i got the same message .
Please solve my problem .
Firstafal youtell that detials you working to onborad vga are addan vga tell ok aftar you insttall that display drivers
Posted on Nov 26, 2008
HDMI from Virgin cable box to Samsung 400px monitor
should have vga cable and sound cable is the same as the mic cable normal'y green jack on mother board, vga is standard flat screen for computer plugg'es into tv comp or aux will have on tv menu hmi aux,comp
Jan 02, 2014 | Samsung SyncMaster 400PX 40 inch LCD...
How to connect television cable and samsung sync 2233
Samsung SyncMaster 2233BW does not support TV / Cable input (RF Connector).
If you wish to connect Cable to the LCD, you have to buy a TV Box and connect Cable with your LCD through TV Box. (Cable TV to TV BOX and from TV BOX to LCD)
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Sep 09, 2011 | Samsung SyncMaster 2233BW 22" LCD Monitor
COBY TFT LCD TV/2204 works fine connected to TimeWarner cable without HD box. Get same channels as Samsung TV without box in Kitchen. However, I cannot get my old Compaq laptop to drive the 2204 as a...
the native res. for the TV is 1680 x 1024.
you may want to try a different resolution
like 800 x 600 or 1024 x 768. not the native resolution
of the laptop.
Dec 27, 2010 | Coby TFTV2225 22 in LCD TV
Black "tail" lines after every sentence and graphic on screen
same thing with my Envision 22" LCD. I tightened the VGA cable @ the CPU. All fixed.!! Check cable at both monitor and CPU. Replace cable. Check video card in motherboard. Try DVI cable if you have the connections. Good luck
Mar 01, 2010 | Dell E207WFP LCD Monitor
I have a Samsung Series 6-650 LCD TV (Model # LN46A650A1F). I am trying to connect my Laptop to use the TV as a monitor and have done everything to make it work, using a VGA/HDMI cable, but the TV refuses...
Why do you use VGA-HDMI cable? This TV works fine with VGA cable - it has VGA plug.
Or if your notebook has DVI output, then you can use DVI/HDMI cable and connect it to the TV to plug named DVI/HDMI (only one HDMI input is marked as DVI on TV).
I suppose that over HDMI the TV supports only some standard resolutions, but over VGA it supports almost every resolution laptops use. You can find supported resolutions for each input in the TV manual. Try setting the same resolution on the laptop.
Feb 28, 2010 | Samsung LN46A650 46 in. LCD HDTV
Samsung SyncMaster 226BW - floating box "Check Signal Cable"
had the same issue, called up customer care of samsung and they suggested me to change the cable to D-15 10 series. I was getting the comp o/p on TV but with the "Check Signal Cable" messg with the old VGA cable where some pin is not grounded used for computer to monitor connectivity.
Abhi..
Jul 25, 2009 | Samsung SyncMaster 2233BW 22" LCD Monitor
Floating box says check signal cable
plug the blue cable connection into the VGA port (also blue) on the back of the PC and then turn it on. If you have multiple VGA ports and it doesn't work the first time try the other port.
If the cable is white check that you have a white DVI port on the back of your PC and use that port.
Jun 13, 2009 | Samsung SyncMaster 2233BW 22" LCD Monitor
Using my Samsung LCD TV as monitor for my Sony Vaio Laptop
yes sir..i think you must looking and buy VGA adapter 15 to HDMI complete with the HDMI cable set. you can find this adapter at the computer spare part store or electronic part store. not cheap but very usefull for you in the next day.
is very easy to connecting...plug you adapter to the output VGA VAIO.. connect the HDMI cable to adapter (like USB) and the rest to the input at your samsung lcd...good luck..
Jan 31, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Need use New HD PC Monitor with DVI/VGA inputs like HD Ready TV
you need to get a lcd tv device such as from dany or xpod.  it will connect your cable, and its output can be fed into the lcd monitor.
Nov 14, 2008 | Samsung SIR-T451 DirecTV DTV Receiver
Computers & Internet Logo
178 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
