Question about Asko 24 in. D3250 Built-in Dishwasher
Asko D3250 not working
Asko d3250 is not starting. All "mode" buttons are lit, not responsive. Stuck in delicate wash mode. Start button blinking. Turned power on and off, turned off electricity to dishwasher, no luck
  • Anonymous Dec 03, 2008
    Same here. Starting the water filling syklus. Then Emptying a bit water and 3 small kliks. Then the "fine" program starts blinking. After turning the machine on and off many times it works for one full washing then the same shitt all over again.
  • 725 Answers
If the first start button is blinking then there is a door error...the door switch is not closing... to repair
1) turn off the power at the breaker...
2 ) remove screws in the door T20
3) remove contol panel (slide up)
4) place wire tie behind micro switch on door latch...
5) replace door latch and door.
Hope it helps....If NOT let me know more about your problem ... I will Help
Posted on Sep 26, 2009
Asko 3530
Check the manual for the meaning of the flashing lights, and then look on this site for solutions to the problem. If all lights are flashing the water fill has probably overflowed into the base pan. It is usually a simple fix that is detailed in several places. Check under Asko dishwashers of different models because many have the same problem.
Jun 09, 2014 | Asko 24 in. D3250 Built-in Dishwasher
Asko d3250 pump runs continuously
I have a D3450 that was doing the same. Eventually I ascertained that there was a pressure switch that was not functioning properly. On the D3250 it was only accessible from the rear after taking off the lower panel on the back. It was a black part with a red membrane of sorts. I just disconnected its wire connector instead of replacing the part as it was rather expensive. I've been running mine machine at least 2x day for months since with no problems. Good luck! e53c3564-9255-4057-93f1-a616c7ab21ca.jpg
May 27, 2014 | Asko 24 in. D3250 Built-in Dishwasher
Asko dishwasher heavy wash light flashing and pump continually drains even with door open
The reason our Asko D3250 had this problem was because of a leak. The pump hose (approx. 2" black rubber hose - find it here http://www.repairclinic.com/PartDetail/Pump-Hose/8801409/1810263) was split, causing a leak and the blinking heavy wash light. The sensor did its job and picked up the leak.
If you're handy you don't necessarily need to call a repairman in to accomplish the work. You don't need to pull the front of the dishwasher apart. Unplug the power to the dishwasher. Take off the back bottom panel. Next, test where the leak is coming from. Place pans below the holes found on the bottom of the dishwasher. They are visible when removing the back panel and are most likely at the rear of the dishwasher. Plug the power back in then start the dishwasher. If your problem is a leak, you will easily spot it with a flashlight. After ordering and installing your part, make sure to dry all water that has settled in the bottom of the dishwasher. You can easily accomplish this through the back of the dishwasher with the panel removed. If it's still damp the sensor will continue to detect water. Once dry, start the cycle to make sure there are no more leaks before reinstalling the panel.
Aug 09, 2012 | Asko 24 in. D3250 Built-in Dishwasher
I have an ASKO D3250 and it has recently started making a loud noise from the pump area. It starts as soon as the cycle begins and doesn't stop even if you open the door. It seems to stop about 90 seconds...
All power and sounds should stop when any dishwasher door is opened.
Your door switch may be stuck causing it to continue.
The 90 second sound at the beginning of the cycle is the water pump extracting any residual water before taking on clean water for the wash cycle.
Any excessive noise from the drain pump could be debris in the pump. e.g. broken glass.
You can remove the pump and check it for blockage or any foreign object.
Aug 14, 2010 | Asko 24 in. D3250 Built-in Dishwasher
ASko D3250 fully integrated - hotsteam/water swelling joinery
check the area of leak sounds like seals gone on dishwasher see if seal can be put back into groove posistion
Aug 03, 2009 | Asko 24 in. D3250 Built-in Dishwasher
ASKO D3250 Does not run
HI thanks for your question. the problem is with the water pump. its electric, so some of the food got caught in the pump. clean out the pump. thanks, the appliance doc. please rate my answer. thanks.
Oct 09, 2008 | Asko W6661 Front Load Washer
Asko dishwasher d3250 door not closing
the door latch is faulty or needs to be rolled open
Jul 08, 2008 | Asko 24 in. D3250 Built-in Dishwasher
Asko d3250
First I would check the water line from the sink that is hooked up to the dishwasher.
You may have a screen that plugged up.
Also, if you have little pressure at your sink faucet, then you should check your house's water system.
Mar 04, 2008 | Asko 24 in. D3250 Built-in Dishwasher
Asko D3250 Bottom arm not moving
Check that the diverter motor above the wash motor is working and that you havent selected upper basket wash only,could still be a blockage in the lwr arm assy
Nov 17, 2007 | Asko 24 in. D3250 Built-in Dishwasher
Asko 24 in. D3250 Built-in Dishwasher Logo
474 people viewed this question
Top Asko Dishwashers Experts
John Tripp
John Tripp
Jose Pino
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
