Question about Maytag MER6772 Gemini Electric Kitchen Range
Maytag electric range oven not working
The heating element (Im guessing-The odd shaped rod on the bottom of the oven that normally gets red) made popping noises and burst into flames on the left side of the oven. Since then the oven will get warm but it took 30 minutes for it to get to 200 degrees and the element is not turning red. Was wondering if this part can be replaced and for approx. how much money or do I have bigger problems? The numbers on the left side door are: 8114P471-60 and on the right side door are:
8114P395-60. Not sure if the product below is even correct.
Debbie
  • reanned Nov 29, 2008
    Mine is the top coil and it caught fire like a white sparkler and now half the coil is in the shape of a moon rock at the bottom of the oven. I am also looking to fix this myself but am having an issue finding parts-
  • Frank
    Frank May 11, 2010
    the numbe ryou have is for the door.
    can you see if you have another tag on the over side?
    there should have a tag on the rear of the oven, if you cna get to it.
  • 1462 Answers
SOURCE: Maytag MER5775Q Electric Kitchen Range
heating elements are usually good or failed with nothing between so unlikely to be the element. problem probably lies with the thermostat. to check, bypass the thermostat and check the oven gets really hot.
Posted on May 18, 2007
dcp2
  • 63 Answers
SOURCE: Oben takes half an hour to heat up
I doubt its the igniter. It could be a faulty gas valve or maybe the orifice is blocked, and not letting enough gas into the burner
Posted on Jan 28, 2008
SOURCE: Maytag MER6772 - Oven bake element not working even after replacing it.
To find service information for your Maytag Model go tothis link
http://www.servicematters.com/
When on this site, click on Maytag Historical Service Library.
Then click on Maytag Service Library.
Click on term and conditions
Click on Literatur by Model
Enter Modle number MER 6772
Clck go
You will be able to print or download the service manual for your model
Your problem may be the bake relay on the clock or wiring.
Posted on Feb 09, 2008
jumptrout51
  • 3361 Answers
SOURCE: My Maytag Electric Range oven part will not heat over 200* ......
Unplug the range.
Open the oven door.
Remove the racks.
Remove the 2 screws holding the bake element to the rear wall of the range.
Carefully pull the element from the access holes in the rear wall.
Remove the wires from the element.
With your meter set for continuity, put one lead on each element end.
If you get a reading it is good.
If it is good. Replace the wires and reinstall the element.
Pull the range out from the wall.
Remove the rear panels.
Plug the range back in.
Set your meter for 220volts or more.
Careful now because you are working with live voltage.
Set the oven for bake.
Put a lead on each element terminal to check voltage.
If you have 220 volts at the element, unplug the range and unplug the temperature sensor.
Set your meter for ohms.
Check the 2 leads on the temp sensor.
If at room temp the sensor is 1050 - 1100 it is OK. If not replace it.
If the temp sensor checks out OK, replace the ERC
Posted on Mar 13, 2009
iwillfixforu
  • 619 Answers
SOURCE: Maytag electric oven Model MER5755QAQ will not heat past 100
Sorry to say but the erc or eoc has gone bad. The oven control is part # 74009212 at about 200.00. Sorry for the news but it is the problem. Hope this has helped.
Posted on Feb 03, 2010
I have a Maytag electric oven model MER5552BAW. Bottom bake element blew out. I replaced the element & now oven will not heat at all. Going nuts!
Go to youtube and type in your model number and ask for repair videos:
https://www.youtube.com/results?search_query=troubleshoot+Maytag+electric+oven+model+MER5552BAW
Feb 20, 2015 | Maytag Kitchen Ranges
Should the lower oven heating element heat all the way around? The heating element in my oven only heats and glows red on the front and two sides, The rear part of the element never glows red.
This is probably normal. the element has a fine wire inside the tube that you see and depending on where it starts in the tube it will start glowing from there.
Nov 15, 2014 | Maytag MER6872BAS Gemini Electric Kitchen...
Oven not working bottom element not working top on broil works ok
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Sep 05, 2010 | Maytag Admiral LER3330AAW / LER3330AAZ /...
Element nor oven will get hot
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
May 20, 2010 | Maytag MER5770 Electric Kitchen Range
Oven will not heat?
check youe elements make sure there good if they u need erc if not replace element and try might still need both replasced
Mar 20, 2009 | Maytag MER6772 Gemini Electric Kitchen...
I have a Maytag Electric Range/Oven The Range MODEL#MER5755QAW
best guess is thermostat I believe the broiler does not need the thermo in oven.. it stays on steady hot .. thats why it still works
Mar 12, 2009 | Ovens
Need to replace heating element
We have a maytag stove and we cleaned our oven on the self clean cycle a week ago. I used the oven once since we cleaned it. today we went to use the oven again, and the oven will not heat and the broiler will not come on either....seems funny that both would quit working at the same time.....any suggestions....
Dec 05, 2007 | Maytag MER6772 Gemini Electric Kitchen...
Maytag MER6772 Gemini Electric Kitchen Range Logo
479 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
