Question about Hamilton Beach Big Mouth 70590 Food Processor
While mixing pie crust is the blade to be removed from the bowl or to remain inside? This is the first time I'm attempting to mix pie crust in my food processor and I have misplaced my manual. Many Thanks
  • 65 Answers
You need the blade in the unit in order to mix the pie crust. but do not over mix. its best to do it in short pulse bursts. otherwise the crust will come out resembling fluffy playdough and will not holdtogether during baking
Posted on Nov 29, 2008
KitchenAid KFPM770 motor runs 3 seconds and stops
Determine first if it really is the motor. Does it only cut out if loaded or will it happen without any load? Remove all bowls and blades, plug it in and turn the power on and press the on button. With something plastic press the small white button that is in the middle above the switch panel and normally hidden by the bowl. This is the safety cutout switch avtivated by the bowl, lid and pusher being in position. Does the motor run while the button is depressed or does it again cut out after a short time but with button still depressed. If it doesn't cut out it's likely that wear in the complicated mechanisms in the lid and bowl handle are releasing the cutout switch with small vibrations of motor running. I figure out which one to replace by swapping out one of the 2 parts for a new one as I try to carry both parts in stock for that purpose.
Jul 11, 2016 | KitchenAid Food Processors
The metal blade does not reach the bottom of the bowl
I am confused by this too! I have a brand new magimix 5200 and all my blades sit about 2 centimetres above the bottom of the bowl resulting in nothing being mixed below them. Very annoyed after spending $700 on this thing!!!
Dec 06, 2013 | Magimix 5150 Food Processor
Cuisinart DLC-10S food processor leaks when liquid is above blades
Yes. It's the basic physics of all liquids.
Perhaps a blender might be a more suitable tool?
Generally you would use the food processor for mixing/blending/chopping all the dry ingredients (and maybe the butter if you are making something like cookies).
Separately mix all the really wet ingredients together in a mixing bowl/large measuring cup.
Then combine the dry ingredients from the food processor with the wet ingredients in a mixing bowl (you can fold the dry into the wet if you used a bowl to mix the wet ingredients together. If you used a measuring cup for the wet, then it's usually better to put the dry ingredients into the mixing bowl first, making a depressed area in the center, and then add the wet into the dry.)
Nov 28, 2013 | Cuisinart DLC-10S Pro Classic Food...
Haw can i use ?
My food processor is one of my most-used appliances. I just got a new Cuisinart (at Costco - with an extra workbowl!) and use it at least twice a week. I grate cheeses like cheddar or swiss, pulverize parmesan, make bread crumbs, hummus, pesto, salsa... I make pasta dough in it before rolling out in my Kitchenaid pasta attachment. Pie crusts come together in a flash. And it's great during the holidays for chopping nuts and certain cookie doughs. I've chopped my own beef for burgers, etc, etc. I keep it in a cabinet but it's easy to pull out whenever I need it. And there are only 2 of us at home.
By the way, the blades are so sharp in the new machine that I cut my finger trying to clear something from the blade. I'll use a spatula next time!
ford performance chips.
May 25, 2012 | Food Processors
Attachment stuck on shaft of food processor
put the mixing bowl up as much as possible. spray some wd40 into the groove between the attachement and the motor shaft. Wait for several minutes, then with a hammer and a piece of wood, give the bowl a good wack. With a few goes, it will gradually come off. I will be putting some butter inside the attachement from now on to keep it lubricated
Jan 11, 2010 | KitchenAid KFP750 Food Processor
Need bowl of Braun food processor 4262
http://abtecparts.com/braunfoodproc.htm
I need a lid for mine here in Bristol RI but I did see that the bowl was still available. If the site I sent doesnt have the one you need try a google search (Braun 4262 ) and there were a few sites that had the mix bowl but no lid
May 30, 2009 | Braun UK-250 Food Processor
Instructions for the food processor of my Cuisinart Duet
Place the gearbox on top of the blender/food processor
Place the work bowl over the spindle, with the handle facing the front of the machine - make sure the tabs lock into place.
Place the stem adapter on top of the spindle, then the blade.
Place the lid on top of the bowl, with the feed tube facing the back of the food processor. Then the pusher into the feed tube.
Here is the link to the user manual with visuals 9p.6 is most helpful):
http://www.cuisinart.com/share/man/10_man.pdf
-Tha Mp3 Doctor
Mar 23, 2009 | Cuisinart BFP-703 SmartPower Duet Food...
Hamilton Beach Big Mouth 70590 Food Processor Logo
157 people viewed this question
Top Hamilton Beach Food Processors Experts
Jim Thurston
Robert Plante
Oloyede Monsuru
Are you a Hamilton Beach Food Processor Expert? Answer questions, earn points and help others
