Question about Foxconn (865G7MC-ES) Motherboard
Help needed..... Baught a new motherboard with processor today and fitted it into the computer (upgrading an old computer used to have an AMD fitted). When i try to boot the pc the power light comes on. The processor, case and PSU fans come on but nothing else happens, there is no bleep from the m/board and no HDD activity. I have tried taking everything out and trying hardware bit by bit and even replaced the RAM with a different set, but still nothing happens. Thanks in advance for any solutions :)
  • 624 Answers
Hi Octane, If you?re not getting any beep codes then something real basic is wrong. To start off I would check the following: -check the new power supply and ensure it is designed for your motherboard. -check the power supply connections to the motherboard, the connectors should mate up exactly to the motherboard connector. -check for shorts (mounting screws against capacitor leads are common), correct grounding and so on. Any of those can cause the same symptoms. -test the power supply in another computer or if not available you can generally pickup an inexpensive tester for $10 to $15 at a computer store that sells parts. -make sure your motherboard is designed to accommodate your processor. I would expect a beep code for this but you never know. Let us know how things go and please don?t forget to rate the posting.
Posted on Jan 05, 2007
Can I make my Dell 0MG532 motherboard work at 800Mh FSB
upgrade the bios and check this url www.dell.com
Dec 31, 2011 | Dell Computers & Internet
I just bought your AMD Athlon ll #x2 255 to replace replace my old one. I see in the instructions that I have a socket 754 and the new one is different. I/m trying to upgrade my computer. i also got y
Hello, I am the technician that will be assisting you today. My name is Norman-Wynne Damstra.
Welcome to Fixya, Roger Gross.
Yes your new AMD Athlon 2 X2 255 processor is made to fit both AM2+ or AM3 sockets.
Since your current socket is 754, you will need a new mainboard and DDR3 RAM to go with your new processor.
ASUS make very good mainboards. The ASUS M4A88TD-M EVO/USB3 mainboard is a good companion for your new processor. Install DDR3 1333MHz CL9 RAM from either Kingston or Corsair. 2X2GB modules should do nicely.
Feel free to contact me should you require additional assistance.
Take care!
Dec 22, 2011 | AMD Athlon II X2 255 ADX255OCGQBOX
Like to replace my processor which is AMD Duron 900MHz to Motherboard Gigabyte 7VM333M-RZ. Which current processors are compatible with this board? Please advise. I want a current fast processor.
Hi, As far as I can see, this motherboard is very old, and the faster processor you could get would be around 1.8 ghz, single core. Here's the list of supported processors:
http://www.cpu-upgrade.com/mb-Gigabyte/7VM333M-RZ.html
What I would suggest is that you buy a motherboard/cpu combo, then you could get a quad core with a recent motherboard for less than 150-200$. Of course you'd have to be willing to change your motherboard, but unfortunately, you're not gonna get a good processor with your current motherboard, and computer parts (like Ram, hard drives, video cards) are going to cost more and more for their rarety, while they are less performant.
Best of luck to you!
Mar 14, 2011 | Computers & Internet
I am using amd sempron LE-1100 i want to upgrade to a gaming pc so that i can play the sims3. so if i like to upgrade to amd athlon x2 how to know my socket type. please help
Your socket is AM2. You can put any AMD processor that has AM2. If the processor is AM3 just upgrade the bios of your motherboard and it should work. If you need further assistance, just leave a comment. Cheers
May 24, 2010 | AMD Athlon 64 X2 3800+ Dual Core Processor...
Computer upgrades
hard drive:http://www.amazon.com/Western-Digital-Intellipower-WD20EADS-Frustration-Free/dp/B001RB1TIS/ref=sr_1_fkmr0_1?ie=UTF8&qid=1266265361&sr=1-1-fkmr0 processor: http://www.amazon.com/AMD-HD9750XAGHBOX-Phenom-Quad-Core-2-4GHz/dp/B0016HK7A4/ref=sr_1_3?ie=UTF8&s=electronics&qid=1266265416&sr=1-3
graphics card:http://www.amazon.com/BFG-BFGE981024GTGE-GeForce-Graphics-EcoIntelligence/dp/B00288BH9K/ref=sr_1_2?ie=UTF8&s=electronics&qid=1266265506&sr=1-2
hope helps!!!! :D
Feb 15, 2010 | HP Compaq Presario 6016US PC Desktop
Chip up grade options!
That
is a socket 754 motherboard. It will support AMD Athlon processors up to Athlon64 3400+. It is a bit long in the tooth by today's standards, and only uses DDR memory, not DDR2. You may get more of a bang for your buck by buying a "barebones" system, which can consist of a motherboard with processor and memory, depending on how much you want in the barebones package.
Typically you use the case, power supply you already have with the new motherboard and processor and ram (memory).
At any rate, if you only want to upgrade your processor, keep in mind that your board only supports up to the Athlon64 3400+. It will support up to DDR 400 ram. You would probably benefit more by buying 2 sticks of 400 DDR ram at 2 gigs each, if you don't have much ram now. If your processor is close to the 3400+, then another processor in that board isn't going to change things much.
Good luck, and write back if you'd like more help.
Sirwriter
Socket754 Supports AMD Athlon64 upto 3400+;
Nov 02, 2009 | Computers & Internet
Help Upgrading Processor
You'll find the information you seek at both the processor company and the motherboard company. As for remounting it in a Compaq case you may run into some issues of the On/Off Switch, power lead, reset button ect...matching up. You might be suprised at how inexpensive a new computer case is. I've seen some as low as $25. Your power supply can be removed and it will fit in your new case. You may just have a easier go of it. Good luck...please leave a rating, thank you kindly
Apr 25, 2009 | Computers & Internet
Upgrade Acer Aspire m1100
Is you are going to do a complete overhaul, you are better off going with a ASUS motherboard, with a processor, and 4 GB of memory. Here is a good place to get all these parts and your computer will run REALLY great.
www.computershopper.com
Feb 08, 2009 | Acer Aspire M1100-U1402A Refurbished AMD...
Problem with upgrading processor
Sounds like the processor you're trying to upgrade to isn't the same frequency. The processor, motherboard, and memory have a matched frequency. For example; a motherboard with a frequency of say PC4200 will only accept a processor and memory of a PC4200 frequency. If you try to use PC5300 memory it basically won't do anything, blank screen, or maybe a beep. The same if you tried to use a processor with PC5300 on the PC4200 board. The best way to find the frequency rating is to look on the memory. They class the memory by frequency, but rarely ever list the frequency for the board or processor. Research the new processor to find out the memory class and then see if it matches the memory in your machine. If it doesn't then the processor won't work. If it does, then new processor may not be compatible, and that means more research.
Jul 18, 2008 | Shuttle AV42 Motherboard
Upgrading
To upgrade from pentium 3 to P4 you have to change alot of the hardware.
You need a NEW P4 Socket mPGA 475 Motherboard.
New DDR RAM
New 478 PIN Processor.
You can use the old CD rom and Hard drive and any other PCI card but You Need the Mentioned Hardware to Upgarde.
Jan 08, 2008 | Intel (P42000400512SK478) Pentium 4, 2 GHz...
Foxconn (865G7MC-ES) Motherboard Logo
67 people viewed this question
Top Foxconn Computers & Internet Experts
Alun Cox
Rommel Balcita
David
David
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
