Question about Pioneer GM-7100M Car Audio Amplifier
No power with amp
I have a 800 watt gm-710m pioneer and itook out my amp and box for a few months then put it back in never removing any cables. when i hooked up th amp i got no power from he amp. the power source is good because i get a spark from the power wire. the blue light on the top of the amp does not light up. very confused. thanks for your time
  • 160 Answers
Make sure the remote wire has juice when the head unit is on then check ground
Posted on Dec 01, 2008
My kicker 12 inch cvr's arent hitting as hard as they should
amps and wiring kits are very optimistic on the output. If you want proper wire, buy some welding cable "0" or "00" guage. That solves the power delivery. Put a 1 Farrad (or more) capacitor near the amp, that solves the surge power issue. Make sure the box is suitable for the subs. Lastly I'd say do some research and find the right amp that can deliver the clean, huge current required to move some serious air!
Jan 28, 2014 | Kicker Comp CVR 12 x 12 Car Subwoofer
Alpine 6x9 speakers 90 watt rms.Are they compatable with a pioneer gm 3000 amp
the alpines will take every drop of power from that pioneer and smile... it will sound quite good,and if you ever want to you can actually put about 2x that much power to them 1 of those amps per 6x9 would rock
Apr 08, 2013 | Pioneer GM-3000T Car Audio Amplifier
MY AMP WAS WORKING UNTIL IT JUST STOPPED WORKIN AND WHEN I CHECKED THERE WAS A FUSE BLOWN UP BUT NOW AS I HAVE A NEW FUSE ITS STILL NOT WORKING ANY ADVICE WHAT TO DO THIS IS THE SECOND AMP IN A MONTH
Sounds to me like one of your positive cables keeps hitting metal somehow and causeing the fuse to blow. Ive had it happen to me when i had one of those amp splitter boxes that i didnt have mounted down properly and it slid into the metal on a seat post and same thing happened.
Apr 26, 2010 | Pioneer Car Amplifier GM-7100M - Mono Bass...
Pioneer GM-7200M 800 Watt Amp shut off and wont turn back on.....
Hiya, first check by triggering or powering the amp manually by putting a voltage at the trigger. Just use a jumper from power. If the amp comes on then check the feed from head unit. Loose wire, inline fuse near the head etc.
If it still doesn't come on the hate to say its gonna have to go in for repair. Could be anything inside from protection, blown track etc.
Hope that helps
Jul 27, 2009 | Pioneer GM-7200M Car Audio Amplifier
Red light showing up on amp ( pioneer 800 watt GM 7200 amp )
it could be the amp it could be the way you've installed and if you have a sub in an enclosure the wires could be touching the postive and negetive speaker wires what ever the problem is the amp is in protection mode i hope this helps hope its not the amp i hope its just the wiring
Jun 05, 2009 | Pioneer GM-7200M Car Audio Amplifier
Wiring
Usually an 800 watt peak sub would be a 400 watt rms. Hmmmm. Anyway, just bridge the amp (1x 380) nd keep the gain up enough to stay clean. Watch the sub and turn up gain until it starts to distort, then back it down a hair. Do this with the CD players volume up 2/3 to 3/4 volume with the BASS and treble at zero (bass better at minus 4 or so if you are a bass head! Hope thishelps.
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Jan 27, 2009 | Pioneer GM-5300T Car Audio Amplifier
Pioneer GM-7200M 800 Watts Mono Amplifier
you Amp is overloading and going into protection mode. if it cuts out with the wire u were using first then their would be no need to upgrade the size of ur wire cause that would only be, doubling or trippling the power u are getting threw those wire now. bottom line the 2 subs u are using are obviously to much for the amp. try dropping the OHM's by connection the subs together and runnig just a single positive and negative to the amp! or just get a better amp
Mar 19, 2008 | Pioneer GM-7200M Car Audio Amplifier
Is it good
If you are using a GM-7200 amp, it should sound great. Both the amp and the subs are rated at 800 watts so be careful not to overload the bass by turning them on full power. It is good practice to have a slightly lower watt amp than the subwoofers. If you can power your rear speakers from the amp, that would take away some power to prevent the subs from overloading. Overall, you should get a nice THUMP!!
Oct 30, 2007 | Pioneer GM-7200M Car Audio Amplifier
Pioneer GM-7300M 800 Watt amp will not power on
This may have a different type of triggered turn on wire. On some of the older Pioneer amps (and maybe some new ones) the trigger wire would SUPPLY B+ TO THE RADIO and when the radio was switched on the amp would sense a current draw on that wire and would then switch on. Unlike most common amps which sense the presence of B+ on the trigger wire supplied by the radio and then turn on. Look in your owners manual to see kind of turn on system you have. If you don't have an owners manual then perhaps you can download one from Pioneer support. good luck
Aug 23, 2007 | Pioneer GM-7200M Car Audio Amplifier
Pioneer GM-7100M Car Audio Amplifier Logo
184 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
