Question about Mitsubishi WS-65807 65" Rear Projection Television
Picture bowing I have your response about soldering, but that is not suffient info. Soldering is not a problem, but location is. Where and what am I looking for please?
On the inside of the tv, there is a circuit board with a metal cover over it. looking in from the rear, it is the tallest one and to your left. its where your usb ports are and also the digital audio ports.its tricky to get it out but once u do there will probably 4 capicators on one corner that will be swolen. they are bad if u see this. you will need 4 16volt 1000 uF(micro Farret) 105degrees c. once u have soldered them into place and are ready to install make sure u get the board in line tn the groves of the plastic line up tool that will still be attatched on the board, and make sure u get the panel conected. plug your tv in wait bout a min, the light dosnt go off reset and wait one more min. it this dosnt cure your problem you probably have a bad module. but if it does work you have a cheep fix. the capacitors are only about 25cents each on mouser.com, and anyone can buy from them.
Posted on Dec 09, 2008
My RCA big screen bows at top and bottom and picture is very blurry can I fix it myself. Cost?
Hello. You have a failure of the convergence circuitry. If you are familiar with soldering, you might be able to fix it yourself. First, I would check for what's called "cold solder" on the pins of the convergence ICs. If there's cold solder joints, re-soldering them might fix the problem. Repairing convergence circuits can be difficult if you're not used to doing it. Then there's the problem of finding the parts. If you want further information, let me know. I hope this helped.
Aug 01, 2016 | RCA Televison & Video
Rca r52wh72 picture bow and colors off
If this is an ITC 222 chassis, then you have a blown fuse right beside the high voltage transformer (transformer has the large red wire coming out). The fuse is a small brown (square) component. There are two together at this location and one will be blown. Check with an ohmeter. I usually solder a strand of copper wire taken from an ac cord across the blown fuse. ALSO the cause of the problem is bad solder connections on the transformer pins. So inspect the pins carefully for bad connections. (usually the pin going to the fuse mentioned) If you have a soldering iron, then this can be repaired with no cost..just time.
Jun 16, 2011 | Televison & Video
On my Sony KP-65WS510 The colors are misaligned in the picture and the picture is bowed. Any ideas? Thanks!
This problem appears due to convergence output ICs failure located on D board in tv. There are two big black ICs that need to be replaced, soldering work is required.
Let me know are you handy with electronics stuff repair and can replace parts in circuit board to provide you more technical info OR local tv repairman will do this job for you.
Thanks.
Nov 23, 2010 | Sony KP-65WS510 65" Rear Projection...
The picture just changed & the convergence is off with the picture bowing inward on top & bottom of screen & you see the image in red,blue & green. The auto convergence feature in the setup...
U have a soldering iron,solder wick or a desoldering pump,and solders?U know how to do soldering?U can fix this problems like about 20 mins.The convergence fuse part (FL231) is dead.Very common on this model of RCA tvs.U can buy this convergence fuse (FL231) at Ebay.com pretty cheap like $3+ shipping.There 3 small brown or pinkisk sqaure look like caps.The one in the middle is dead.But they're fuses located right side of the Flyback transformer,call a FBT(a big black block of transformer).Resolders the FBT too.
Jun 18, 2010 | RCA HD52W59 HDTV Projection Television
Model 51S715: 2 issues: (1) Screen is bowed at top...left and right edges turn down and are black. (2) picture color will turn green randomly. If I turn tv off and leave off for a while the color goes...
Ur tv have a problem call convergence,it dying about to be dead.The tv convergence board 2 STK Convergence ICS and some or all it resistors require changing to solved the covergence problems.U have tools,soldering iron,solders and know how to do soldering?Tries websites like Tvrepairworld.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300-350 for parts and labors.
May 29, 2010 | Hitachi 50UX57B 50" Rear Projection...
Colors are distorted and the picture bows in at top and bottom
you have a convergence circuit failure there are a couple ics and resistors that will need to be repalced
if you have the tools and soldering station and know how you can do this your self
the parts are available through MCS or Encompas
if you need more info let me know
email amelectronics@frontiernet.net attn Tim
Oct 24, 2009 | Philips 60PP9363 60" Rear Projection...
MY HDTV 52IN RCA HAS BOWED PICTURE. I CANT FIGURE HOW TO FIX IT
heres where they are located but you have to resolder the flyback and vertical IC also.
Look at the flyback ( with the Large red wire) Just to the right of the flyback you will see three small brown Fuses the cehter one is FL231 DL231 is just to the right of FL231 and Cl230 is just below and alittle to the right of DL231
Jun 14, 2009 | RCA HD52W59 HDTV Projection Television
Mithsubishi Projestion TV MDL VS-60609-Picture bow
Sounds like bad convergence chip. I think you can get a kit to repair it at www.tvrepairkits.com
You need to be good with a soldering iron if you plan on doing this yourself.
May 17, 2009 | Mitsubishi VS-60609 60" Rear Projection...
Samsung HCN4226WX has green and red ghosts very bad
Probably bad IC's (color or convergence amplifiers). Soldering and knowhow required.
Apr 26, 2009 | Samsung HCN4226W 42" Rear Projection...
Sound but no picture, menu looks bowed/hourglass screen
This is a common problem on projection sets and if you have someone carefully resolder the pins of the convergence chips, it will probably solve your problem. If you continue to use the set, the amps will fail and leave a dead set condition. What needs to be done is to disconnect the power, remove rear cover, loosen all snug wiring making sure to mark any wires that you disconnect, remove screws holding chassis in and undo plastic hooks at front of chassis, access bottom of circuit boards and with low wattage soldering iron resolder convergence amps, reinstall chassis and rehook all plugs in original places especially ground wires and high voltage leads, and test. If the soldering iron is too powerful it will damage the chips, also, be sure each solder joint is clean and not touching the one next to it or you will fry circuitry. Hope this helps. Russmann.
Jan 28, 2009 | Mitsubishi VS-60703 60" Rear Projection...
Open Questions:
See all Mitsubishi WS-65807 65" Rear Projection Television Questions
Mitsubishi WS-65807 65" Rear Projection Television Logo
42 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
