Question about HP Photosmart A617 All-In-One Printer
Dull Round Spot
When printing with A617 I have a small round 8 mm diameter dull spot on the print. My cartridge 110 was dry, because I didn't use it for 6 months. After printing 10 photos, the print is back to normal, however the dull spot remains.
I cleaned via computer the printer and the matter was solved.
Posted on Nov 26, 2008
No magenta printing
Dirty mirrors will gives you dull color images..It seems color combination faulty..
chk original cartridges installed? or refilled cartridges?
Take supply status page..
chk colors..If color is dull(light) clean laser scanner assembly mirrors.
Do the color calibration..
chk drivers.,
Print from other file..
May 09, 2014 | HP COLOR LASERJET CP 3505 N PRINTER
How to reset the 'toner out' message in the Canon MF4350d laser printer?
This problem bugged me for months! Selecting CONT. PRINTING as indicated by Small6363 allowed to print with the warning light on but did not solve the warning light problem. I eventually found a way to bypass the flashing light and warning message.
Underneath the cartridge, on the cylindrical portion, in the middle there is a small flat rectangle. This is the ink level detection spot. Cut a piece of aluminum foil of the same size and place it with a piece of scotch tape overt that flat rectangle. Voilà! No more flashing red light and no more out of toner message! Of course you have to monitor your level visually and change the cartridge when printing starts to fade.
Hope this helps!
Patrick
Dec 02, 2010 | Canon imageCLASS MF4150 All-In-One Laser...
Drum error. slide green tab in each color
1. power down the printer.
2. remove all color cartridges from their slots.
3. inside the color slot, you will see a green slide that will not move until you pick up the plastic cover.
4. rotate the plastic cover forward.
5. slide the green slide 3 or 4 times. (DO NOT TOUCH SMALL WIRES!)
6. return slide to original position.
7. snap the plastic cover back in place
8. return each color cartridge to it's slot.
9. replace color cartridge holder back to printer.
10. close all covers
11. turn printer back on.
If you still get the "move green slide" error, just repeat these steps
This took me about 10 minutes for the process, after understanding what the "green slide" meant.
Oct 04, 2010 | Brother HL4040CN Laser Printer
Canon mp530 - colors print dull and faded
The ink tanks may be full but sometimes the pins that connect the cartridges to the printer may have dried up ink on them preventing the ink from flowing. You can try to swab these with a bit of rubbing alcohol on a Qtip and letting it dry for moment or two. I would strongly suggest doing a couple of deep cleanings first and try test printing of the individual colours separately in a program such as paint to see which colour is affected.
Jan 24, 2010 | Canon PIXMA MP530 All-In-One InkJet...
Hp Officejet Pro K600 is not printing black and making the other colors appear saturated and dull
Your ink cartridges seems to be dry/near emtyness, buy a new black and color cartridges and it will print as new.
Nov 29, 2009 | HP OfficeJet Pro K8600 Printer
Sharpening Ryobi 4046c - what size file ?
Chain Type File File Profile
1/4” Micro 5/32” (4.0 mm) Round
3/8” Picco Mini 5/32” (4.0 mm) Round
3/8” Picco Micro 5/32” (4.0 mm) Round
.325” Micro, Super 3/16” (4.8 mm) Round
3/8” Micro, Super 13/64” (5.2 mm) Round
3/8” Square Grnd Tapered
.404” Micro, Super 7/32” (5.5 mm) Round
.404” Square Grnd Tapered
Depth Gauge File Flat
Jul 11, 2009 | Ryobi 18-inch Electric Chainsaw Chain Saws
Dull srtipe over almost the middle of medium 3 to 4 mm wide
In the menu under troubleshooting there is a selection called Eliminate Light Streaks. Run it a couple of times that should take care of that, It will blow out the blocked jets.
Mar 19, 2009 | Xerox Phaser 8400 Laser Printer
Print is dull.
Listen I have seen really, bad print ctgs from HP, before you drive yourself crazy replace the ctgs again, see if your print quialty improves. just cause it's new doesn't mean it's not defective.
Mar 07, 2009 | HP DeskJet 5150 InkJet Printer
Brother 5240 dots on prints 3-3/4" apart
turn the cartridge upside down on a table. turn the drum gear by hand and clean the spot with a dry cotton pad.
Jan 02, 2009 | Brother HL-5240 Laser Printer
HP Photosmart A617 All-In-One Printer Logo
54 people viewed this question
Ben Johnson
