Question about Olympus Camedia P-10 Thermal Photo Printer
Ribbon problem The printer keeps saying their is a problem with the ribbon. What's up?
  • asteraceae Nov 25, 2007
    My Olympus P10 printer keeps having a problem with the ribbon. The ribbon light flashes, and the unit shuts down. I put in a new ribbon, with the same result. When I take the ribbon out, it is a bit scrambled, but not torn. I then readjust the tension in the manner described in the instruction manual, and try again. The print comes out from the previous attempt - just a smudge of yellow. With each new printing attempt, the ribbon gets crumpled. It is very frustrating. What do I do to rectify this problem?
  • repochic May 20, 2008
    The printer does not print at all the ribblon light comes on and the camera reads error. It is a brand new ribbon and i have turned it. it doesnt get crumpled or anything. Very Frustrating
If it was a 100 print ribbon try a 40 print ribbon
Posted on Apr 04, 2008
  • 114 Answers
Is the ribbon new?, sometimes they have problems, if that one is alright, u need to send it to a repair centre, it must need to repalve the mainboard
Posted on Jan 17, 2007
Printer keeps saying out of ribbon....but there is a new ribbon
Revise bien este procedimiento y corrija si es necesario.
Realize and perform this procedure well and correct if necessary.
Aug 04, 2016 | Zebra P120i Thermal Card Printer
My printer keep saying"error condition
It sounds like you may have loaded the ribbon incorrectly.
Sep 22, 2011 | Zebra Z4M Printer
Bought a DTC520 and replaced Printer ribbon and now message reads " No Printer Ribbon Installed" Used Part # 86031 DTC500-YMCKO I powered down machine and started again, still NO Ribbon...
You have to check which ribbons are loaded.
Depending on that you have to select the appropriate mode in the driver else it'll keep giving this message.
Y = yellow
M = magenta
C = cyan
K = black
O = overlay
May be you don't have overlay loaded
Aug 15, 2011 | Fargo DTC515 Thermal Printer
My Printronix P5005B says "RIBBON STALL" what
Remove the ribbon and check for play when turning the plastic ribbon hub by hand. If it is loose try tightening with a torx bit. But it is probably cracked and needs to be replaced.
Dec 07, 2010 | Printronix Line Matrix P5005B Printer
DTC550 Fargo printer it says out of ribbon with new installed
Check to see if the RFID (green ring) from the old ribbon has come off and is stuck near the reader (located behind the green stem). I've seen that happen. I've also see some bad RFID rings. If that happens they should have a warranty from Fargo.
onlineidtech
Mar 19, 2010 | Fargo DTC550 Thermal Card Printer
Datacard sp55 printer won't recognize ribbon
PR-01726 Ribbon Out
Out of print ribbon.
Possible Cause 1 : The print ribbon Cartridge is empty.
Solution 1 : Reload the print cartridge. Change the cleaning sleeve and replace the cartridge in the printer. Run a cleaning card as soon as printing is completed.
Possible Cause 2 : The printer ribbon is not loaded correctly.
Soultion 2 :Load the printer ribbon correctly and then close the cover.
Possible Cause 3 : This ribbon has been completely used.
Solution 3 : Use a new roll of ribbon.
Tips for Success
* When this message appears, replace the old ribbon with the new ribbon of the same type. The printer has already prepared the card data for this ribbon type. You can change the colors of monochrome ribbon (such as from dark blue to gold).
* If you must change the type of ribbon (such as (YMCKT to KT) when this message appears, install the new ribbon, cancel any cards waiting to print, and change the ribbon type settings. Finally, return to the card creation program to send the card data to print.
* If the ribbon was repaired, the wrong take-up spool was used. Repair the ribbon again, using the correct take-up spool.
If you cannot fix the problem contact your service provider for assistance.
FTB
Nov 23, 2009 | Datacard Group SP55 Card Printer
Keep getting broken ribbon message on zebra P330i printer
Hello, assuming the supplies are Zebra and there is no discernible damage to the ribbon, it could mean that the ribbon sensor on the printer is broken. if your printer is still under warranty you can ship back to Zebra (Illinois) to get it repaired. The zebra website has info on how to return printers for service. Hope this helps.
Oct 15, 2009 | Zebra Eltron P330i Card Printer
Tec 572 printer gives "no ribbon" error with ribbon installed
You have to set the ribbon type to be "non-transmissive" for black transfer film.
To set the ribbon type, turn the printer off. Then press and hold the "feed" and "pause" buttons while turning on the power. The printer will now be in diagnostic mode - you can page through the menus until it says "ribbon type"
Pick the correct type and press the "pause" key to save the value. Then turn off the printer and turn it on again normally. The ribbon error goes away.
Mar 19, 2009 | Toshiba TEC B-572 Printer
Olympus Camedia P-10 Thermal Photo Printer Logo
119 people viewed this question
Top Olympus Office Equipment & Supplies Experts
James Cagle
James Cagle
Norman Worley
Are you an Olympus Office Equipment and Supply Expert? Answer questions, earn points and help others
