Question about Acer Extensa 4620 Notebook
Blutooth headset connecting problem
Iam connect an external bluth divice.thats working perfectly. file transfer is working. but not receive any audio output from laptop to blutooth headset. windows is serch the divice. but not pairing.
I have blutooth divice and i want to connect that divice to my pc
Unless your PC has a built in Bluetooth receiver you would need to purchase one. Then you can connect Bluetooth devices to it.
Thanks,
Lee
Apr 05, 2011 | Computers & Internet
When i connect to other phone i cannot receive files from them it always failed please help me
Are you trying to connect via Bluetooth?
Bluetooth have different profiles. The Bluetooth profiles are A2DP (for connecting the phone to a headset with mono sound), AVRCP (for headset with stereo sound and remote control), Dial up networking (for internet connection), and FTP or File Transfer (for sending or receiving files).
Your phone should support FTP or File Transfer. If your phone does not have FTP, it will connect to other phone, but it will fail when you try to transfer any files. You may need to verify it by checking the user's manual or by calling the tech support of your phone.
If your phone does not support FTP, ask the tech support if there's a firmware that will add the FTP profile to your phone.
If your phone supports FTP, but it keeps on failing on receiving a file via Bluetooth, then try to soft reset the phone by removing the battery for 5 mins. If the same problem occurs, then this phone needs to be reprogrammed.
Thank you!
Oct 22, 2010 | Cell Phones
How to connect the some blutooth divice (E.g) PC & Phones thanks!!
connect blue tooth device to usb port and if you have got cd with blue tooth device install it
Jul 30, 2010 | Computers & Internet
My samsung doesnt recognize anyother divice or the divices cant recognize the samsung, so i cant transfer any files via bluetooth.
It is not possible from my experience (I have one and I have tried everything). The Bluetooth on this phone is only for connecting a headset, nothing else. It paired with my Jawbone set quite fine. You want to share photos...you are forced to use the T-Mobile service....
Oct 14, 2009 | Samsung SGH-t239 Cell Phone
Files can not be received on storage card on HTC S710
try moving all recieved files to d card, also if d file size exceeds d size of available memory, it aint gonna work..
Last resort, use d phone cable to transfer heavy files wit a PC
May 01, 2009 | HTC S710 Smartphone
I have a blackberry 7290 and ican't use the bluetuth
The blutooth on blackberries is mostly for connecting a headset. Certain models allow you to transfer files to people using blutooth. But only you connecting to the other party not them connecting to you.
Dec 29, 2008 | RIM BlackBerry 7290
Wireless transfer bluetooth
may be u should try to change the headset status to looset status and again to headset. It may solve ur problem.
For it, open the settings, open the enhancements.
In it, there is a menu called Enhancement in use. In it, change headset to loopset or text phone. Restart the phone. And in the same option, change it to headset later !!!
I think ur problem can be solved by this.
If it works, dont forget to send me a feedback.
I am hoping for it . If any problem rises, just ask me.
I will be there.
Sajan(sajwhat_2003@yahoo.com / sajwhat@hotmail.com)
May 04, 2008 | Nokia N70 Cellular Phone
Nextel I870 phone and my HS850 blutooth
hold down hook button until blue indicator goes solid blue
(mic FOLDED IN) flip out mic quickly and go to settins on phone and select bluetooth or connections and select find/add bluetooth device and select bond or pair enter passcode 0000.
select done and blue light should now be blinking indicating it was connected
Jan 09, 2008 | Motorola Mobility HS850 Consumer Headset
Unable to access other blutooth devices
IF you want to connect to a device or transfer to and from your phone, you have to make that item discoverable. This is a secuity measure so people arent just taking or install systems without the user's knowledge. Confirmation has to be made on both devices, like a pin number or what have you.
Oct 24, 2007 | Compaq Presario Laptop
Acer Extensa 4620 Notebook Logo
53 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
