Question about T-Mobile Dash Smartphone
Speed-dial has quit working
Speed dial has been set up for keys 2, 7 and 8. 1 is defaulted to voice-mail. Now when I press one of these keys, it displays the single digit and does not dial the associated number.
Went into "Contacts" and selected one with speed-dial to edit. Made no changes but saved the contact. Magically, speed-dial began working correctly for all numbers. Rebooting or removing/reinserting the battery may also have worked but were not tried.
Posted on Nov 26, 2008
How do I set up my voice mail
On the LG500g the number 1 is programmed as your speed dial number to connect to voice mail. So, just press 1, then press call (center button on navigation key), and follow the prompts.
Oct 03, 2014 | LG 500g TracFone
NEED TO SET UP MY VOICE MAIL
Hi,If your account is enabled for voice mail, you can receive voice messages in your Inbox and also in a text message on your mobile phone. Both the message in your Inbox and the text message will include a preview of the voice message in text.
How do I set up voice mail?
1. Go to https://outlook.com to sign in to your mailbox, go to Options > Voice Mail tab, and then click Set Up Now.
2. When you set up your voice mail:
* You'll register your mobile phone number.
* Text messaging is set up. You can choose to be notified in a text message that you have voice mail or have missed a call.
* Call forwarding is set up so that your mobile provider forwards calls you receive to your voice mail. So if you don't answer your phone, your phone is busy, or you're unreachable or unavailable, the caller will be sent to your voice mail. After your personal greeting is played, the caller can leave a voice message for you.
* You can test whether your voice mail has been set up correctly by dialing your mobile phone number from your mobile phone. This verifies that call forwarding is correctly set up with your mobile provider.
How do I change my voice mail after I've set it up?
After you've finished setting up voice mail, you may want to:
* Change the mobile provider's voice mail number so you can use the key your provider has reserved for accessing voice mail to access your voice mail. For details about how to do this, see Changing the Number You Call to Access Your Voice Mail.
* Create a contact on your mobile phone. For details about how to do this, see Create a Contact for Voice Mail.
* Assign a speed dial key to the contact you create for Outlook Web App voice mail. For details about how to do this, see Set Up Speed Dialing for Voice Mail.
What else do I need to know?
* The voice mail service is available only to certain customers in certain regions. If you can use voice mail, you'll see a welcome message in your Inbox telling you how to set up voice mail for your account.
Thanks for using fixya...
Jan 20, 2011 | Cell Phones
How do i set up speed dial on my KX-TG9391C
The speed dials are set in the contacts or the names directory. Open the directory and scroll down so that you see the options available to modify the names list. In this sub list you will find the speed dial. select this menu and open to see the locations 2-9. Since no 1 is assigned for voice mailbox you can assign the rest from 2 to 9 by select the destination and assigning with the selected name. Even for the no 1 voice mail box you can assign a name but must select it from the settings menu in the messages window, Now try to press and hold the set numbers to confirm that you speed dial works fine, Hope you try this out. Good day
Jul 29, 2010 | Panasonic Lands Phones
Setting up voicemail on sch-u340 phone..cannot read buttons on manual to set up..
Check out this link below to download a PDF manual, software, and more for your phone. Just copy and paste into your browser.
http://www.samsung.com/us/consumer/mobile/mobile-phones/more-carriers/SCH-U340ZBAUSC/index.idx?pagetype=prd_detail&tab=support
Setting Up Your Voice Mail from page 10 in your manual:
Voice mail allows callers to leave voice messages, which can be retrieved any time.
Note: Once your voice mail account has been set up, you can use the Voice Mail folder (under the Message menu) to view details of voice messages in your voice mail box.
1. In idle mode, press and hold the key or dial your own mobile number
to dial voice mail.
2. Follow the prompts in the new user tutorial to setup your mail box.
Listen to voice mail
to dial voice mail. After connecting, you will hear your voice greeting.
2. Interrupt your greeting by pressing .
3. You are then prompted to enter your password.
Hope this helps, let me know if I can help you with anything else. It would be very kind of you if this does work for you to please rate me or leave a short note. I would really appreciate it. Thank you for your time.
JimmyC
Oct 16, 2009 | Samsung SCH-u340 Cellular Phone
Line rings does not fo to voice mail
The call forwarding was canceled; try this
1. pick up handset or press speaker
2. dial the code for call fwd busy/ no answer (default code is 744)
or press the forward function key
3. dial 1
4. dial the extension (lead number of your voice mail)
5. press speaker or hang up
May 20, 2009 | NEC Lands Phones
Voicemail box not set up
I have seen the same problem with some users (I look after the PABX) so I just go into the maintenance console and set up the foreward to the default voice mail number. Or you can try the following:
CALL FORWARDING HANDSET 1. Press the Speaker Phone Key on your handset 2. Then Press the FWD/DND Key 3. Then select the Forward type you desire - Key 2 - Immediate Key 5 - Busy/No Answer 4. Then dial the internal extension number (eg.444) or voicemail pilot (201) 4a. If forwarding to external number dial 0 then dial outside telephone number 5. Dial # then press the Speaker Phone key
Use the voice mail that is set for your system.
Hope this helps
Jan 08, 2009 | Panasonic KX-T7630 Corded Phone
Calls go straight to voicemail
Your phone is fowarded to Voice Mail and do not disturb is on. Turn DND button off. If it is not the case on your phone press intercom # key 601 then hang up. Then do intercom #key 604, dial your voice mail extension numbe, r press the speed dial Select button, dial 16, press the redial button then hang up.
Dec 11, 2008 | Toshiba DKT-2020 Corded Phone
Voice Mail
delete the speed dial number from the list or just master reset the phone
Oct 12, 2008 | AT&T LG CU515 Cell Phone - Black
Wrong Voice Mail number programmed into Speed Dial "1" Key
You can not remove it; But you can change it
Follow the steps :-
>Menu
 >Messaging
   >Voice Messages
     >Voice Mailbox NO.(CHange it)
Sep 06, 2008 | Nokia 3110 Cellular Phone
Delete old voice mail - program new voice mail
You can usually access the system voice mail setup from any extension.
Press Speaker
Dial ext 200.
When asked for security code, dial *,2,# (dial it twice if there is no code).
When main greeting begins, dial 632.
Using the soft keys under the display, press MORE, then MGR, then CHBX or, follow voice prompts if non-display phone.
Follow voice prompts. Remember, 1=Yes, 2=No.
Mar 10, 2008 | NEC Electra Elite DTU 16D-2 Corded Phone
T-Mobile Dash Smartphone Logo
73 people viewed this question
Top T-Mobile Computers & Internet Experts
ismael castillo
Marvin
Marvin
Edward Talavera
Edward Talavera
Are you a T-Mobile Computer and Internet Expert? Answer questions, earn points and help others
