Question about Stanley 100 ft. Tape Measure, FatMax
I have a bostich model S32SX staple gun that misfires
When you first hook it up to the compressor it will fire properly for the first 20 to 30 times, after that the trigger appears to have no pressure on it.
  • 37 Answers
Hi, Its sound like your compressor is not turned on. Make sure your compressor is plug in, and the (on and off) switch is turned on. Check the pressure gage to see what psi you have. You need at lease 90psi. If you don't have that much pressure, There should be an adjusting knob below the gage. Turn the knob until you get the proper psi.
If this doesn’t work for you, please write back. Thanks,
Posted on Nov 29, 2008
How do I unjamb a stanley heavy duty sharpshooter
Hi, You do it very carefully. Take the refill chamber apart and remove all staples or nails. If one is jammed remove it. When all is clear reload and try. Good luck
Jan 12, 2015 | Heavy Duty Stanley Bostich Heavy-duty...
Pneumatic Hardwood floor stapler from Bostitch is misfiring
Put a little gun oil on the staples the spring that helps feed them might be catching
Dec 19, 2013 | Stanley Hand Tools
Bostitch hardwood flooring stapler. The Staples misfire. I have to keep pushing on the Staples to make the gun fire properly
take a small brush like one you would use to clean a gun. clean it well and use gun oil to lube it
Dec 19, 2013 | Hand Tools
My paslode air framing nailer model 5350-90s is loosing air out of the trigger valve when I press on the trigger and the nail does not fire. What is the problem ?
Sounds like a bad O ring. There are rebuild kits you can get with a new set of O rings. Or you can have it done for about $30-50.
Jun 09, 2011 | Heavy Duty Stanley Bostich Heavy-duty...
My bostich flooring staler wont fully drive every staple and it is getting is not leaking air
Your compressor needs to be checked first. There is an air pressure regulator on most machines - be sure all is in working order. It might help to be sure you're playing any lubricants in the stapler configuration as well.
Nov 05, 2010 | Stanley Bostitch STB-MIIIFS Flooring...
Staples not coming out
yes they are, I would double check the guage and shape of the staples for this tool to ensure they are correct. If you give me the model number I will find what guage you need and get back to you.
Oct 25, 2009 | Stanley Tools & Hardware - Others
Bostich nail gun plumger not retracting
spay with pb blaster while rapid firing gun into a piece of junk material , once free oil with a small amount of hold or sewing machine oil and then oil after each use
Nov 27, 2008 | Heavy Duty Stanley Bostich Heavy-duty...
Powerfast strap gun for romex misfiring
just a try spray with a generous coat of pb blaster while firing a few then follow with a good coat of household oil then oil before using just something to give it a try
Nov 17, 2008 | Tools & Hardware - Others
Stanley 100 ft. Tape Measure, FatMax Logo
178 people viewed this question
Top Stanley Measuring Tools & Sensors Experts
Lawrence Oravetz
Vernon Taylor
Are you a Stanley Measuring Tool and Sensor Expert? Answer questions, earn points and help others
