Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Husqvarna rider 155 won't start
There was a problem with the engine stopping when the forward pedal (or reverse) was pushed. Checked the safety switch that controls that -switch checked OK. plugged it back in and it would start and run OK, but engine would stop when the blade was lowered - checked the switch that controls that - checked OK. Plugged it back in and engine started, mower drive worked and mower deck worked. Great! but brought the mower back in to install a cover and currently it will not start. 15 amp fuse looks good. Checked the other switch (seat) and it checks OK too. What now?
I took a wire and jumpered all of the switches until I found the one that would let the mower start. The switch was still good, but vibration or whatever had moved the plug just enough to lose contact. Plugged it on more firmlly - problelm solved. Thanks.
Posted on Nov 26, 2008
Husqvarna mower forward/reverse pedal is stuck in the forward position. Engine runs but transmission not engaging. Cause-probably pushing pedal forward when cruise was set. How can I get it unstuck?
If this model has the CVT transmission, you should check to make sure the CVT is cleaned in the area where the CVT unit connects to the trans. This model has been known to collect debris and cause this issue. If not a CVT, check you return spring on the pedal itself.
Oct 29, 2016 | Husqvarna Garden
Husqvarna 2754GLS, Hydrostatic forward/reverse pedal will not return to neutral position.
Parts and Diagrams for Husqvarna 2754 GLS 96043004700 2008 01
I suggest following all the safety procedures suggested in the operators manual first!
ENGINE NOT RUNNING,wheels blocked to prevent being run over, check the return spring ref # 161
Apr 12, 2014 | Husqvarna Garden
My Husqvarna Rider 16c wont reverse - first it was slow in reverse then not at all
You need to check the cable, it is a push pull telescopic style so it is possible to get forward and no reverse, if it was a hydro problem you would not get forward or reverse, there is also timing gears on the forward and reverse pedal, you nee to make sure they have not jumped a tooth as this would reduce movement on the cable at the hydro
Feb 12, 2013 | Husqvarna Garden
Mower dies when directional pedal ( F/R) or engageing blades
check the safety switches start with the one on the pedal
May 16, 2012 | Garden
JD 855 the idle spring broke and th hydrostatic pedals would not return to their neturel position . before I new what had happene I pushed the reverse and the tractor lunged backward then I pushed the...
Yes there is a safety switch.And this safety switch has to be engaged.If its not engaged then the JD tractor will not start. On JD 855 the safty switch is located under the seat, There is a rod that must be depressed before engage Somehow that rod is bent or its not pressing the switch to the point that the seat would not fully engage the safty switch.In some cases the switch itself is faulty.It has to be checked . Thanks. keep updated for any more query.you can rate this solution and show your appreciation.
Jul 20, 2010 | John Deere 420,1020,2010,2020,2510,2520...
My Rider will not turn over it just makes a strong noise as if it is trying to start but not kicking over. It also will not go in forward or backwards the rear wheels seem froze. The brake is not on and...
not a expert just trying to help,, try jacking rear end up and see if it move with gears or not,,, if it move like it should then maybe a safety switch bad,, hope this help you,,
Nov 15, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
try checking the ignition switch for any damage and replace if necessary
Nov 25, 2008 | Garden
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
142 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
