Question about IBM Office Equipment & Supplies
Beeps and Flashing Lights
Typewriter beeps and then the lights 1 and 2 on the right side flash.
  • Geno111
    Geno111 May 11, 2010
    this is an error code that is different for different models
    always give manuf. and model #
  • Anonymous Mar 21, 2014
    When I turn on the typewriter it beeps six times the single and double space lights flash continuously in sinc and it doesn't respond to any key presses.
  • IBM Master
  • 3,594 Answers
It sounds like a keyboard but you didn't give a make or model, if it is an IBM Wheelwriter see my tip under WW 1000
DickyO
Posted on Nov 25, 2008
6 beeps linespace lights 1@2 flash
Hello, flashing 1 and 2 indicates that the machine has a keyboard problem. I have found that the keyboards are starting to fall apart due to the age factor and the only solution is to have the keyboard assembly replaced. EBM is where I usually get keyboards. good luck.
Sep 13, 2012 | Lexmark Wheelwriter 1500 Typewriter
IBM Wheelwriter #5 - The line space keys are flashing and the typewriter will not work. I unplugged it and replaced the batteries.
There are a lot of possibilities. Which lights are flashing? In sequence? Beeps? How many?
These all are codes to the problem.
DickyO
Sep 15, 2010 | Lexmark Wheelwriter 5 Series II Typewriter
When I turn on typewriter it beeps 4 times and lights on 1 & 2 on right side light up - can't use typewriter at all. What is it?
the most common problem is the homing sensor. You can buy them from Radio Shack and replace it, but it is + and - sensitive. A little tricky the first time It has to be soldered in,
May 20, 2010 | Lexmark Wheelwriter 10 Series II...
IBM Wheelwriter 5 nonresponsive, line spacing lights flashing
A lot of possibilities Which lights, beeps, how many? Check for debris in and around the printwheel, look for any obstructions under the carrier, put a few drops of oil on the silver shaft the carrier ride on.
Good Luck
DickyO
Jul 01, 2009 | IBM Wheelwriter 30 Typewriter
Space lights flashing
Tell me the pattern. Are they flashing or on solid? Do you hear beeps. Count the beeps. Is it a WW 30?
Jan 12, 2009 | IBM Wheelwriter 30 Typewriter
Beeping and keys don't work
When you power up what happens? What lights are lit, are thy flashing, are there beebs and how many? These are error codes and are important.
DickyO
Sep 25, 2008 | Lexmark Wheelwriter 1000 Typewriter
Typewriter is beeping at me
Probably needs a keyboard. See my tip under ww1000.
DickyO
Jul 11, 2008 | Lexmark Wheelwriter 1000 Typewriter
Flashing lights
You have a keyboard problem. The rt. connector has 7 contacts bussed together, wrap a piece of foil over that portion of the connector and plug it back in. BE SURE TO COVER ONLY THE 7 BUSSED CONNECTORS!
Nov 26, 2007 | Lexmark Wheelwriter 1000 Typewriter
Typewriter won't type
Yes, those batteries do need to be changed. They are probably corroded. clean up all he corrosion, reinstall the batteries and give it a try!
Jun 04, 2007 | Lexmark Wheelwriter 1000 Typewriter
486 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
Jim Keysor
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
