Question about Canon FAXPHONE L80 Laser
Tengo un fax l80 me pide cambie cartucho
Fax l80 me pide cambie cartucho y ya cheque el que tiene y si tiene toner que le puedo mover para que me lo reconosca
  • Anonymous Mar 29, 2014
    O TELEFONE ESTA EM PULSO QUAL O CODIGO PARA COLOCA-LO E TONE
Te mando mi correo escribeme y te puedo decir la solucion. richard.zarate.df@gmail.com
Posted on Apr 16, 2009
  • 65 Answers
Excúseme por favor. Hablo muy poco español. No estoy seguro si entiendo su pregunta. Si su cartucho es vacío usted puede sacudirlo. Esto le dará más copias. Para cambiar el cartucho, abra la portada y saqúela. Chasque aquí para la página L80 del canon. Espero que esto le ayude. Clasifique por favor esto como " helpful" o " fixya".
Posted on Nov 28, 2008
I replaced the K cartridge and i get this caution. I-Unit End Replace K
If "[Color name] Toner Empty. Replace with a new toner cartridge." is displayed and printing stops, replace with a new toner cartridge.
([Color name] indicates one of the following: C or Cyan, M or Magenta, Y or Yellow, K or Black.)
Jan 10, 2017 | The Office Equipment & Supplies
HOW DO I un-lock the scanner on a Brother MFC 7420?
Unfortunately, the MFC-7420 doesn't have a physical lock switch. You need to turn off the all-in-one and wait for the unit to clear its memory. If the error recurs after you press the power button again, wait 30 minutes and try again. (Note: you will lose any faxes that are in memory. See the User Guide page 11-5 to save this information.) You can find the manual on the Brother support page for the MFC-7420: https://www.brother-usa.com/support/ModelInfo.aspx?R3ModelID=MFC7420 . Click on the Manuals & Documents tab. Then click on the Manuals on our Online Solution Center for the English version of the manual. The direct link to the User Guide is currently: http://download.brother.com/welcome/doc000387/ALLFB_UsaEngUsr_B.pdf .
You can also try unplugging the all-in-one for several minutes to reset the error codes. If the error persists, contact Brother if the MFC-7420 is still under warranty (1 year). If it isn't under warranty, consider replacing the unit. The repair costs may be unreasonable.
I hope this helps.
Jan 09, 2017 | Brother MFC-7420 Printer
My sharp color copier Mx 3100n is indicating F2-73 after using 88-1 how do I restore it
Hello Tijjani,
The error code that you are experiencing is as follows;
F2 73 IMPROPER TONER CARTRIDGE DETECTION (YELLOW)
You need to replace the yellow cartridge with the proper part # Item Number: MX 31NTYA, MX31NTYA.
Good Luck!
Rich Lilja
Jan 08, 2017 | SHARP MX-3100N
Bizhub C250 using to much toner. Images are very dark. Ink can even be rubbed off pages. How do you adjust?
Check that the fuser is not in enevople mode. two green handle up not down. check the files
Oct 28, 2016 | Konica Minolta bizhub C250 All-In-One...
Colour cyan not printing
Did all of the packaging come off the toner successfullywhen first installing. Can you see cyan toner on the transfer roller? (Black roller on actusl cartridge)?
Dec 08, 2013 | Office Equipment & Supplies
Laser printer makes light clicking noise when idle
When idle is potentially the fuser unit, after heating and cooling. However the print quality issue associated with the clicking sound could indicate an electrical issue. The HVPS maybe faulty causing the print quality issue (due to dependant parts) and the electrical click. In any case I would recommend calling Brother and finding the nearest authorised service agent.
Oct 20, 2012 | Brother Mfc-9840cdw All-in-one Laser...
Sc 395 ricoh aficio 3045
fix copier is a youtube channel
fixing error in videos
this is a video see you how to fix sc 395
https://www.youtube.com/watch?v=cI6o6mYOqow
Jul 05, 2012 | Ricoh Office Equipment & Supplies
My fax wont work in my ricoh aficio 1515 mf??
Using the 1515 as a fax machine is a pretty simple procedure if everything works right. All you have to do is hook a working phone line up to the phone jack on the back of the copier (the one labeled LINE, not TEL).
Why won't the fax work? If it is giving you an error message, what is the message?
If you are not getting a dial tone when faxing, unplug the fax from the phone line and plug a working phone in, and see if the phone gets a dial tone. If it doesn't, there is a problem with your phone line.
You can also try plugging the fax machine into another phone line. If the fax works on that line, then there may be a problem with the first line.
Are you having problems sending faxes or receiving them, or both?
Jan 05, 2010 | Office Equipment & Supplies
Canon FAXPHONE L80 Laser Logo
393 people viewed this question
old marine
old marine
