Question about Mitsubishi Mr. Slim MXZ30TN Air Conditioner
Mr. Slim msz-a17na won't turn on after power outtage
Can you help me out? After a power outage last night....one of my indoor units won't turn back on. I tried flipping the breaker and nothing...no green light on the machine...i also pressed the E.O SW (Emergency Operation Switch on the indoor unit and it still didn't activate itself.....any thoughts here?
Much appreciated,
Matt
917.287.3745
  • 958 Answers
After a power outage, normally as power comes back in, it's a little bit high than normal.
with a dead set that you got, it would probably be the control transformer. the primary could have been burn by a spike voltage.( sudden rise in voltage above normal).
or im sure it has a fuse. check first the fuse. if the fuse is ok, then it would be the transformer.
tnx 4 using fixya,
Drcool
Posted on Nov 26, 2008
Wall unit keeps frosting up, will not heat
Clogged air filter or a loose belt between the fan motor and fan wheel will cause a frost up.
Nov 19, 2015 | Mitsubishi MSZ-GE15NA Mr. Slim Wall...
There is a bad smell coming from the indoor unit of my Mitsubishi Mr Slim split-type a.c.
Mitsubishi MSZ-GE06NA Mr.... Repair Questions - Fixya
www.fixya.com/.../p3677512-mitsubishi_msz_ge06na_mr_slim_wall_m...
Recent Mitsubishi MSZ-GE06NA Mr. Slim Wall Mounted Indoor Unit Air Handlerquestions, problems & answers. Free expert DIY tips, support, troubleshooting ..
Jul 26, 2015 | Mitsubishi MSZ-GE06NA Mr. Slim Wall...
How do I clean Mr Slim MSZ 24NA
usa.mylinkdrive.com/.../MSZ-MSY-A09-24NA_GA24NA_Service_OB
Sep 19, 2014 | Mitsubishi MSZ-GE24NA Mr. Slim Wall...
Horrible musty smell
try to find the filter or look it up on the internet.
Dec 17, 2013 | MSZ-A17NA 16,200 BTU, Mr. Slim Wall...
Msz a12na unitHOW DO I TURN HEAT ON? it worked fine last winter...? now the icon doesn't come up on any of the 3 units i have in the house.
Clean filters. disconnect from power for 10 minutes Reconnect and replace flitrs restart units. Set to heat on high.
Nov 09, 2013 | Mitsubishi Mr. Slim MXZ30TN Air...
I have a Mitsubishi Mr. Slim Model MSZ-A09NA. We just purchased the house and have only been using it for a week. I had it serviced on Friday and was told it worked fine. Sat. we had a power outage. ...
Hi, it sounds like you may have lost the blower motor due to the power surge. Normally, it would kick the breaker off.The code is just telling you something is not right as you know. You can try turning off the breaker to the indoor unit for 10 minutes or so, and reset it to see if the blower will start. If you have the manual, that might tell you what the code or light is. Its more then likely a 220 volt indoor unit. Sometimes on a double pole breaker, only one half of it will trip in a power surge. Check to see if this is the case, as you may only be getting 120 volts to run the vanes. If its half way tripped, turn it off hard, and back on hard. that may be your problem. If not, call the service tech, and just tell him it stopped working. He will come out at know charge to you. I bet its your breaker though. Please let me know.
Sincerely,
Shastalaker7
A/C Contractor
Jun 06, 2011 | Mitsubishi MS09TW Air Conditioner
My Mitsubhishi Mr. Slim MSZ-A17NA 1 is drippping water on the inside. I have turned it off for now. What should I do? We're in Mississippi and it is a hot day! thanks
Hi!!
Make sure the unit is leveled, there is a drain hose coming from rigt side of the unit goes through the wall to the outside and down, this hose is probably clogged up.
Go outside the house and look for it. there should be some tubing wrapped in insulation going up to the roof top and a drain hose coming down. You can try to unplugged it from the inside using a wire clothes hanger or you can blow air from the outside end into the unit, you only need a small blow and you can use a flexible funnel or a piece of garden hose and some tape to do it. if you are going to do this make sure to drain all water from unit using a towel to avoit splashing. This works all the time.
Don"t forget to rate this post. Good Luck!
Jul 01, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
Copper condendsing lines are cold but the air is not cold
http://www.mrslim.com/UploadedFiles/Resource/MSZ-A24NA_Op_Manu_SG79Y961H03_12-29-08.pdf Try this web site for you manual. It's where I found it.
Jun 14, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
Mitsubishi Mr. Slim MXZ30TN Air Conditioner Logo
1,120 people viewed this question
Top Mitsubishi Heating & Cooling Experts
vince
D. E. Hev
Stuart Slabber
Level 1 Expert
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
