Question about Soyo SY-KT333 DRAGON Ultra Motherboard
No video, monitor and video card are good
Hi. Had a power outage the other day. When power came back on, computer was running, but no video. Monitor said "NO signal, check cables". I did all the obvious things like try another monitor, try another video card, and reset the CMOS via the jumper like it said in the manual. I even replaced the CMOS battery which was going bad. Computer starts up, but I don't hear the hard drives running, so I'm assuming it doesn't boot (even before I reset the CMOS).
When I turn it on, I hear one long beep and two really short, stutter like beeps. If I reset the CMOS and turn it back on, I get the one normal short beep I used to get when all worked well. If I shut it off and turn back on again, I get the long beep and two really short beeps again.
I'm stuck. Any thoughts? Thanks for any input.
  • borisjr999 Nov 26, 2008
    Ok, thanks. But how do I check the BIOS and the Processor if I can't see anything on the screen?
  • borisjr999 Dec 26, 2008
    It was the memory. Thanks for your help! I never would have thought a bad stick of RAM would do that.
    Scholar:
  • 135 Answers
There 3 possible problem with your board...
1. Processor
2. Ram
3. Bios
Check one by one
Posted on Nov 25, 2008
  • Naveed khan
    Naveed khan Nov 26, 2008
    Normal
    0
    false
    false
    false
    MicrosoftInternetExplorer4
    /* Style Definitions */
    table.MsoNormalTable
    {mso-style-name:"Table Normal";
    mso-tstyle-rowband-size:0;
    mso-tstyle-colband-size:0;
    mso-style-noshow:yes;
    mso-style-parent:"";
    mso-padding-alt:0in 5.4pt 0in 5.4pt;
    mso-para-margin:0in;
    mso-para-margin-bottom:.0001pt;
    mso-pagination:widow-orphan;
    font-size:10.0pt;
    font-family:"Times New Roman";
    mso-ansi-language:#0400;
    mso-fareast-language:#0400;
    mso-bidi-language:#0400;}
    Brother the fault is in your ram because if you pull out the
    all rams from your motherboard then it should beep you to tell you bios are
    there and it not found ram. This whole work is being done by processor.
    If you have 2 rams then try one by one is both slot may any slot is not
    working.
    If you can't get it by changing rams then you can check your processor in
    another board and you can check your bios by placing other working processor and
    rams.
    Remember doing this all pull out your all other extra pci slot items and pull
    out USB port accessories. If possible remove cd rom.
    Hope you will override your problem.
What do I do after power outage and monitor will not work?
If the device was plugged in when the outage started and / or when power was restored - it may have suffered a power outage related voltage "spike" (or instantaneous rise in voltage greater than it is designed to handle).
Unplug it for 5 - 10 minutes and reconnect. If it fails to function you may need repairs or replacement. Try a different monitor on the computer before condemning it - it may be a problem with the computer's video card instead.
Mar 11, 2015 | Computers & Internet
Toshiba laptop pas409e-d screen is black
Step 1:
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Only work inside the computer case when the power has been switched off and disconnected. Never open the power source. Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards Causes a Computer Monitor to Go Blank b> While a blank screen may be caused by a general power outage, more often it's a problem with the screen itself. It could be a loose video or power cable going to the monitor. If that's the case, you can get the screen working again and be back in business in a few minutes. b> Power Problems All the power might be off due to a bad outlet, switch, fuse, or circuit breaker. If you hear no sound coming from the computer and its power light is off, check the power connection and breaker or fuse. Video Cable Many times the cause of monitor blackouts is a loose video cable connection. This might happen if you move the monitor or the cable. The video cable runs from the back of the computer to the monitor. It has a multi-pin connector on each end and both of them screw down securely. If the screws aren't tight, either connector could become loose. If that happens, the video signal could stop suddenly and make the picture go blank. Check both ends of the connector to make sure they're firmly seated and the screws are tight. The cable itself might be bad.This is unlikely, but possible. b> Display Power The monitor must have power. If the power light isn't lit on the monitor, it may have been turned off or become unplugged. Press the power button to make sure it wasn't accidentally turned off. Make sure the monitor is plugged in. If it's connected to a power strip, check that the power strip is on. If that checks out, unplug the monitor and try a different outlet. Power strip sockets can sometimes fail. Flat-screen monitors may have a power-brick-style adapter. It, too, has connectors. Follow the power cable from the monitor's power plug back to the monitor. About halfway up you'll find a thick rectangular plastic brick. The power goes into a modular-style equipment socket. This can become loose. Follow the wire the rest of the way to the monitor. It connects to the back of the screen with a small round plug. Check that it's firmly plugged in. If everything's plugged in right and the power light on the monitor's still off, the power brick might be bad. b> Video Card Some computers have a separate video card inside. It may come loose and cause a blank screen. If this is the case, open the computer and inspect the video card. Sometimes removing and reseating the card will fix the problem. If it has to be replaced, most video cards are not expensive.
b>
Feb 15, 2013 | Computers & Internet
My acer monitor come on and screen go blank
Step 1:
Feb 15, 2013 | Acer Computers & Internet
Screen is black when computer is turned on. Tthe monitor power button blinks, but when you push the button, the light does not stop blinking and the screen stays black.. The monitor was working and last...
Try a different video card or disconnect the one you have in your PC and use the VGA monitor connection on the motherboard. If it works your video card is gone.
Dec 22, 2017 | Envision 19" Widescreen Flat Panel LCD...
Dell monitor has stopped working.
good day, i think you have no problem with the monitor, you may have a video card problem. have it replaced and you'll have your computer running back to normal again. hope this helps, have a nice day
Feb 04, 2010 | Computers & Internet
Old monitor wont switch on
hi friend,
First, try connecting your monitor to a known good PC, possibly the old laptop you are using now. If the monitor works, the problem is with the video card in your PC. If the monitor does not come on, it is the monitor. It is usually cheaper to purchase a new monitor than to have an old one repaired, unless the monitor is still under warranty.
Try plugging a known good monitor to your PC. If the monitor works, your old monitor is fried and needs to be replaced.
If Your monitor works when connected to another PC, the problem could be your video card. First, then you turn on your PC, do the power supply and case cooling fans run. If they don't, it could be the power supply.
Next, open the computer case. Before you do anything inside, unplug the power.
IMPORTANT!! Touch any metal portion of the computer case to ground yourself to the PC. The slightest static spark can destroy computer circuits.
If the video card is the card type that plugs into a slot on the motherboard, remove the retaining screw or fastener at the top of the card, carefully remove the card, handling the card by the edges as to not disturb the circuits on the card, and re-install the card. Sometimes simply re seating the card corrects the problem.
If that doesn't work, replace the video card with a similar type card. Maybe now is a good time for a video card upgrade.
If the video card is integrated into the motherboard, you can only install a new card into one of the PCI slots on the motherboard. When the PC boots for the first time, go into bios and disable the on board video card. hope this helps u
please rate me..............
thank u for using fixya
regards
sivaranjini
Nov 25, 2009 | Computers & Internet
ACER P221W No display and power light blinking
You have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of he monitor. If you are good at electronics repair/soldering you can usually fix he problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts, replace any that look like the pictues and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping. If the monitor does not have any bad caps then I would be that when the video card died it sent a spike to the monitor and killed the driver board. I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Jun 28, 2009 | Acer P221W LCD Monitor
Gateway E-3200 no video signal
hi! there,
there are common factors why no video on your screen.,right one factor is ram,the other are video card,processor and monitor
you can't trouble shoot with out other computer available,tester cann't detected all this,it make easy to parts to parts.disconnect cd room,hardisk and floopy also disconnect your video card and memory card put video card and ram one by one (if youhave nultiple ran) to other computer ,be sure other computer is run good and observed, if no video take the previous video card and put back if there video,possible your video card is busted,or try to put other video card and ram to your pc be sure this are good,if ok select your own part that you think is busted since you said your ram is good,put back to your pc observed.....replace aby busted parts,
take all precaution avoid electric shock wear safety shoes.regards and have a nice day
Apr 03, 2009 | Gateway Computers & Internet
Blinking monitor screen
this might be overly technical, but it sounds like the video card is on the blink (no pun intended). I'd power down the machine, open it up, pull the video card, re-seat it, and power the computer back on.
If it continues to do this, that card is probably toast.
Dec 06, 2007 | Computers & Internet
Problems After Power Outage
Sounds like the power outage damaged the video interface could be damaged. You might have had a spike that effected the red input of the monitor. You can try to order a video interface, or like I suggest to others, look for the same monitor but broken on ebay and swap out the interface board. Chances are this will fix your problem. Good luck
Oct 02, 2007 | Kogi L9CH 19" Flat Panel LCD Monitor
Soyo SY-KT333 DRAGON Ultra Motherboard Logo
236 people viewed this question
Top Soyo Computers & Internet Experts
Roy May
Marvin
Marvin
Matson Kurian
Matson Kurian
Are you a Soyo Computer and Internet Expert? Answer questions, earn points and help others
