Question about GE JVM2050 Microwave Oven
GE Microwave problems after HV capacitor replacement???
I have a GE JKP69BW1BB built-in combination Microwave & Oven unit. Recently while doing a lot of cooking with both the microwave and oven the microwave audibly "popped" and quit working. The pop was accompanied by a bright flash. Both the oven and microwave were very hot at the time. My appliance repairman doesn't handle microwaves so I took a look at it and found the fuse was blown. Replacing the fuse and starting the microwave resulted in a split second of cooking hum and then the fuse blew. Research showed the problem was most likely the door switches, the transformer or the HV capacitor. I tested the capacitor first and it showed 1.7 ohms resistance. The original GE part was not available, but I was able to find a very close replacement. I installed the replacement capacitor and tried the microwave again. The microwave now runs without blowing the fuse, but it doesn't sound right. It runs very quiet even on full power. I heated 2 cups of water for 2 minutes and it did get hot. In the past there was an audible hum for the cook cycle and also what I always thought was a "fan" running. Now the cook cycle is very quiet and there is no "fan" noise. There was also an electrical heat smell coming from the microwave. I tested the fan by bypassing the thermal cutout and it ran continuously. And this fan noise is not the sound I normally associated with the microwave during cooking. It appears to only come on when the microwave or oven heats up enough to trip the thermal cutout. So, did something else fail at the same time as the HV capacitor? And what makes the fan-like noise during cooking that isn't now? Thanks for any help you can provide.
  • 4 more comments
  • Brendan McKee Jan 05, 2007
    Thanks for the quick responses.
    The existing capacitor was 0.95uF and 2000watts. The replacement was 0.92uF and 2100watts. This was the closest in rating and case dimensions that I could find locally (Alaska). Online I've found 0.95uF/2100watt capacitors with similar case dimensions. I could always order one of these.
    I wondered about the diode. I'll see about testing it and looking locally for a replacement.
    If you have other ideas please post. I'll post what I find with the diode.
  • Anonymous Oct 22, 2008
    Cant bug diode my voltmeter wont detect the high forward voltage, but the 0.92 uF 2100 volt cap seems shorted and reads 9 ohms.
    Have some spare mw guts in the garage I might have the used parts.
    Sharp 1100 watt oven, microwave only.
  • janine4 Nov 26, 2008
    hello, good afternoon, I need an answer, I took to pieces a microwave samsung mod. smw 8711 w made in brazil with 1500 watts and I am going to get on a row of seats, which is going to happen with me the magnatron is tied
  • Anonymous Mar 14, 2014
    The diagram on the VP235A-OF switch in my GE microwave oven (JVM1339) indicates it is normally closed but I found during debugging a problem with my microwave that it is normally open. I can't find a schematic on-line. Does anyone know what it's unclosed state is supposed to be?
  • Anonymous Mar 27, 2014
    Everything works fine except that it quit warming or cooking...even bread is still
    after 10 sec run...could it be the fuse?
  • Anonymous Mar 31, 2014
    Microwave was heating, then made a louder than usual fan noise for a few seconds, and then shut off with no sign of life in the unit.
  • GE Master
  • 9,149 Answers
The rectifier diode could indeed be bad. But first I would want to know what value (in uF) the old one was and what is the value of the new one? If they're too far off, the difference in the capacitive reactance could throw off the "tuning" of the circuit. The uF value of the capacitor is optimized in relation to the other components used in the system. Of course, you'd also want to be sure your new cap is at or slightly above the working voltage rating of the old one, too.
Posted on Jan 05, 2007
  • William Miller
    William Miller Jan 05, 2007
    That cap sounds good, both capacitance and working voltage (WV).
    The diode is the next suspect. Generic replacements are usually fine as long as they fit.
    Sergeant:
  • 216 Answers
You can disconnect the HV wire (red) at the magnatron (isolate it so there can be no sparking). Activate the oven and see if it still blows the breaker. If not, the magnatron is defective and should be replaced. They are available online for around $60. If the breaker "blows" as a result of the test, it's time for a new microwave oven! (You know you want one!)
Posted on Apr 25, 2014
Where is my answer?
Posted on Nov 27, 2008
    President:
  • 3,130 Answers
If the capacitor was shorted, I bet the diode that is connected to one side of the capacitor is No good as well.
Have GE built in microwave on top, oven on bottom. Microwave stopped all sudden, changed out fuse and comes back on but soon as press start button..fuse blows and unit stops..need help troubleshoot
If the unit shorts when you push start. it is something shorted in the high voltage section of the unit. The HV section is made up of 4 parts. The High voltage transformer, the Capacitor , the rectifier / diode. and the magnetron. If the mag shorts it will just hum loudly and not heat, so Your problem is probably the capacitor or a shorted transformer. More commonly it is a bad capacitor. If you have an ohm meter, check the capacitor. It should not read shorted. If it does that is your problem. If so replace the rectifier too just for good measure.
Sep 23, 2017 | GE Microwave Ovens
Microwave activate but will not heat food all light and buttons work but will not heat up
Sorry to read about your problem, I hope this helps you out.
You can many different issue's
  1. Blown fuse in HV transformer primary circuit or HV fuse (if used).
  2. Bad connections (particularly to magnetron filament).
  3. Open thermal protector or thermal fuse.
  4. Open HV capacitor, HV diode, HV transformer, or magnetron filament.
  5. Shorted HV diode, HV capacitor (will blow a fuse), or magnetron.
  6. Damaged protective VDR from filament to chassis (not commonly used).
  7. Defective HV relay (not commonly used).
Microwaves must be serviced by technicians due to the inherent dangers involved in repairing these appliances. Internal capacitors can retain a lethal electrical charge even though the unit is completely unplugged. A microwave radiation leakage test must be performed on the unit following any internal component repair.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Jan 04, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
GE JVM1440 will not heat.
No heat but otherwise normal operation.
Possible causes:
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
3 Thumbs - Helpful
Jan 01, 2011 | GE JVM1440 Microwave Oven
A few weeks ago our GE JVM1660 quit heating and GE sent me a replacement magnetron. I've heard that the capacitor will discharge after the unit has been unplugged for 24 hours... mine has been unplugged...
I don't know where you got the information that the high voltage capacitor takes 24 hours to discharge. The capacitor will actually discharge after a few minutes. If in doubt as to whether or not a capacitor is still charged, however, you should short the capacitor to discharge it. You do this by fashioning yourself a grounding probe:
1. Take a screwdriver and a set of alligator clips with a wire.
2. Connect an alligator clip to either end of the wire.
3. Connect one clip to the screwdriver and the other end to equipment ground.
4. Short the screwdriver across the capacitor terminals.
If the capactor casing is grounded (mounted to the equipment chassis) you only need to take a screwdriver and touch each across each terminal to the capacitor case.
CAUTION: Make sure the unit is UNPLUGGED prior to servicing any components inside the HV network. The HV network consists of the HV Capacitor, Magnetron, HV Diode and HV Transformer.
If you still have questions, please post back and let me know. I hope you find this information helpful.
Mar 17, 2010 | GE JVM1660 Microwave Oven
How to replace a fuze in a ge spacemaker xl microwave oven
depending the age of the unit and its usage, if not a lot its not the fuse,but I would say its more likely a H.V. Diode,H.V. Capacitor, or the magnetron tube.
Sep 20, 2009 | GE JVM1630 Microwave Oven
I have a Kenmore model 66561689101 that doesn't heat properly anymore. What is wrong?
The most common problems of microwave oven are the HV capacitor, HV diode and lastly the magnetron which is the main part of M O. check the capacitor and diode first, if its okay, then you have a decision to make. replace the magnetron or the whole unit. magnetron are costly
Jun 28, 2009 | Kenmore 62622 Microwave Oven
GE spacemaker microwave still not heating
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
if7
Dec 15, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
New GE Magnetron. Where does this new HV diode go?
Fixed it. There was a back capacitor fuse (I believe that's what it's called) on the old magnetron. I removed it and put it on the new magnetron. The HV diode is on the big silver capacitor and very easy to replace. I just didn't see it. It was definitely the magnetron and I hope that this new one comes with a warranty for 5 more years.
Nov 29, 2008 | GE JVM1631 Microwave Oven
Microwave oven problem
If your microwave is doing everything, but heating it could be any one of the following components: Magnetron HV Capacitor HV Diode HV Transformer This network works in conjunction to produce the high voltage required to heat. Taking live voltage measurements is dangerous and not recommended. You can, however, do resistance checks on the components with the unit unplugged to see if you can isolate the problem any further. The HV Diode should be mounted somewhere on or near the HV capacitor and will read an open in one direction and a relative short in the other. If you put a meter on the capacitor you should see a varying resistance as the capacitor charges and discharges. There should should be a wiring diagram inside your control panel with the resistance readings for the primary and secondary windings of the transformer and the filament of the magnetron. In a nut shell, you probably have either a bad magnetron or a bad diode. Those are the two components that fail more frequently. Of course, double check all your interconnecting wires too. Good luck and let me know if this helps.
Jun 22, 2007 | GE JVM1660 Microwave Oven
GE JVM2050 Microwave Oven Logo
1,578 people viewed this question
Top GE Microwave Ovens Experts
vince
D. E. Hev
 Larry
Larry
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
