Question about Xerox WorkCentre M123 Copier
Getting a black line on the coppied paper - Xerox WorkCentre M123 Copier
  • 65 Answers
If you lift up or open the auto feed you should gain access to a small sliver of glass underneath the autofeeder. Clean that glass with alcohol or some other glass cleaner. That should clear this up.
If any debris get on that glass the result is dark lines caused when the page travels over that part of the glass. Hope this helps. Let me know.
Posted on Nov 25, 2008
How to get rid of the vertical black line on the paper?
Usually replacing the toner cartridge fixes that problem. Sometimes it's the fuser.
Jan 20, 2014 | HP LaserJet 1018 Printer
How do i fix the black streak in my coppies
Could be many things. Maybe as simple as cleaning the **** glass under the feeder if it only happens when using the document feeder but not when making a copy from the glass. If both copies from the feeder and the glass have lines then it is probably coming from the drum or fuser area inside the machine.
Jul 23, 2012 | Ricoh Aficio 2228C Copier
I have tried everthing in "Lexmark X5495 Help"
Sounds like you just need a new printer. Some times the encoder wheel can get dirty with aerosolized ink and it will start to skip lines. The encoder wheel is a small plastic wheel on the paper feed of your printer. Around the edge of the wheel are hundreds of small thin black lines. As paper goes through the printer it counts these lines as the wheel turns to know how far to push the paper. If ink or debris gets between the lines over time it can start counting two lines as one and thus advance the paper too far, causing blank space between prints. See the below picture of a printer encoder wheel for reference. My professional opinion is to not purchase Lexmark. New Canon printers are very reliable with a high quality output, look for one that uses CLI-221 cartridges. Or most any HP.
Oct 29, 2010 | Lexmark X5495 All-in-One &USB...
Bad copies/grey lines
hi do u have cleaned the scanner miror and the coppy glass may be coz of that u having that grey line
thanks
May 11, 2010 | Canon imageCLASS D761 Copier
Black line down paper
Pull the doc feeder open and clean the scanner glass
Feb 11, 2010 | HP 1040 Plain Paper Inkjet Fax
Wide black lines down the paper. I have changed
Have you changed the Drum unit. Also there is a cleaning pad that you slide across the corona for cleaning. If you leave it in the middle it will give a black line, should be moved all the way to one side.
Nov 18, 2009 | Brother IntelliFAX 3800 Plain Paper Laser...
I only get margins out copies
I'm Guessing but I would appear to be a paper size setting are not correct. the other problem I have seen is a problem with the registration timing, (modification spring or paper feed rollers) for that you need an engineer
Jun 08, 2009 | Kyocera Copystar CS-1620 Black and White...
Both paper and cartrige lights blink & E in coppies won't leave
just replace the cartridges its the cartridge replacement error .or check out in the printer for any paper jam that also gives this E error on the printer.but mostly its the cartridges error.also try cleaning the cartridge before replacing them sometimes the cleaning helps.
Dec 14, 2008 | HP PSC 1315 All-In-One InkJet Printer
Black lines on photo
Are the lines always in the same places? If they are, then I would try using different photo paper. Humidity plays a big factor when printing with any kind of paper and buying new paper would be a good start. Make sure that the paper is made for your printer specifically. You might also try printing on plain paper to see if you get the same results.
Jan 17, 2008 | HP PhotoSmart 7760 InkJet Printer
Black line down right side of paper
On the ADF check the twink mark on glass scanning mirror
Oct 15, 2007 | HP LaserJet 3055 All-In-One Printer
Xerox WorkCentre M123 Copier Logo
53 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
