Cannot search the internet
I have lost the manual and cannot configure the wireless connection to the internet. When I try a box comes up saying windows cannot configure the wireless connection and to use software if I have enabled another programme-but I haven't used any other software.
Can you default my laptop to the original settings or guide me to be able to use the internet
Thanks
  • clarejordiso Nov 25, 2008
    Did all you said and the system couldn't be restored as it said no changes had been made. It would only allow me to go back to september to restore. Is there anything else I can do?
    Scholar:
  • 162 Answers
Try to restore your system to previous state.
click Start> all programs> accessories> System tools> System restore.
Posted on Nov 25, 2008
Dell inspiron 1525 says limited or no connectivity
Could be an issue with the router. Try resetting the router.
Mar 08, 2017 | Dell Inspiron 1525 Laptop
Show me how to connect linksys wireless
Hi
The Router configuration is not that much difficult, only few thing you have sure,
1) Correct ADSL Connection User name & password,
2) Chose unique ip address in All host.
Follow the mention bellow instruction to configure and connect to Wifi Router,
  • Plug the network cable ( Mine was Blue ) which comes with the Router Box pack to your computer. The other end goes into any of the Router Ethernet Port ( 1 or 2 or 3 or 4 )
  • Now type in 192.168.1.1 in IE or Firefox or any browser. You will prompted for password which is admin. You must be logged into Linksys Router.
  • Now since your ADSL modem is also having the same IP , we will change the IP address for WRT54G2 Router to 192.168.5.1
  • Under Setup >Basic Setup look for Network Setup and Change Router IP. Change to 192.168.5.1 and Save changes.
  • Since the IP has changed you will need to close the Browser.
  • Sometimes the IP doesnt change automatically. Do a IPCONFIG / RELEASE and then IPCONFIG / Renew
Making WRT54G2 Router talk to ADSL broadband modem
  • Plugin the Ethernet cable which comes from the Modem into the port on Wrt54g2 router which says Internet.
  • Open Internet Explorer and Type in 192.168.5.1.
  • Type in same password ( admin )
  • You will be in Setup > Basic Setup
  • Take a look at Section , Internet Setup. The current selection should be Automatic Configuration DHCP. Select Static IP instead.
  • Add following details to it. In the first step we backed up All the IP configuration. Use them here
Internet IP Address: . . .
Subnet Mask: . . .
Gateway: . . .
Static DNS 1: . . .
Static DNS 2: . . .
Static DNS 3:
ADSL Modem Settings to Wrt54g2 Router
  • Once Done just save changes and you should be back at same page.
  • Now try to connect any application which talks to internet. You should be able to connect
Configuring for Wireless Connection :Now once your Router is talking with Modem, it is pretty easy to connect on Wireless. The only thing we need to setup here is Security. Lets get WIFI
  • Get to the Lynksys page again. Do all login and regualr stuff.
  • Now look for menu Wireless, click on it. You should land on Basic Wireless Settings.
  • Select wireless configuration to Manual .
  • Wireless network mode to Mixed.
  • Give a Wireless Network Name (SSID), make sure its unique.
  • Make Wireless channel selection 11 ( 11 - 2.463 GHZ)
  • Select Wireless SSID Broadcast to Enable
  • Save Settings and you will be back at the same page with changes you made.
Now Lets secure the Router :
  • Go to Wireless Security on the same page.
  • You will need to configure here Security Mode : WPA Personal, WPA Algorithms: TKIP
  • WPA Shared Key is what you will need when you connect to your router without wire. This key does the authentication and keep unwanted people away. Add 8 digit alphanumeric key.
  • As suggested in comments, there is a new mode which you can use : WPA2 with AES
  • Save changes.Just make sure you save that key to a notepad or remember it.
Wrt54g2 wireless security
  • Now last step, Move to next menu Security > Firewall .
  • Uncheck Block Anonymous Internet Requests .
  • Save Settings.
Wrt54g2 firewall settings
  • Remove the blue cable which you had connected with Router.
That's it. Now just turn on your WIFI and Search for the router. The name should be visible. Click to connect. At this stage it will ask you for the Password or Shared Key which we configures just above. It will connect and you will be able to connect to Internet.
That's all Folks. This is how you connect WRT54G2 Linksys router with Adsl Broadband Modem. If you have any questions feel free to comment.
Aug 03, 2011 | Linksys WRT54G2 Wireless Router
I was doing something with my dell latitude d610 laptop key board and i lost the linksys wifi connection...although i came to know through my friend to press fn+f2 key,wifi LED comes on but no wireless...
Most likely configuration problem,Im afraid youll have to get the settings adjusted yourself most netbooks will auto configure unless you manually or by error change the settings.
Good luck
Davey Snake!
Jul 20, 2011 | Dell Latitude D610 Laptop Computer -...
Cannot connect to internet, already configure my wireless CWR-854, thru 192.168.1.254, when im in internet, my deafault gateway is 192.168.1.1, please help
online user manual is here http://www.cnet.com.tw/download/cwr-854.htm If you goto page 37 it show the dhcp range . Make sure your pc cofiguration is set to dhcp - automatically obtain and IP and DNS - this is explained on page 10/11 try this Start>run{vista/7 search box}>cmd>ipconfig /release Start>run{vista/7 search box}>cmd>ipconfig /renew see if that produces the correct info
Mar 20, 2010 | Cnet CWR-854 Router
I keep tuning on my wireless internet on my dell lattitude d600 and my wireless internet wont come on it doesnt show anything wen i press fn and f2
check the error message when you try to search for your network. If it says it cannot find network in range and wireless zero configuration utility is turned off than click on start go to run and type : services.msc, click ok, on right hand side scroll the window to the bottom and you'll see wireless zero configuration >> double click on it >> change the start up type to automatic and click apply then change service to started and click on ok.
Afterwards check if you see your network name or else
click on start >> go to control panel >> double click on network and internet connections >> right click on wireless network connection >> click on properties and go to wireless tab >> check the box at the top that says use windows utility >> click on ok and than right click on wireless network connection and click view available wireless networks. It will show you your network name. click and connect to your network
try it!
Feb 22, 2010 | Dell Latitude D600 Notebook
Lost my disk for Router in the move.What can i do
The really don't need a disk - just plug it in and go. You may need the directions (default IP address) which can be found at the linksys website.
Feb 05, 2010 | Linksys Wireless-G WRT54G Router
I have windows xp 2000 home edition got altel wireless itsays internet connected but when you go to yahoo it wont run help
Where does it say internet connected?
Check extra (Tools) internet options what is configured there in Internet Explorer You are wireless. The right WEP or WPA key encryption configure? Try first with direct UTP LAN connection lead before wirelesss. Read manual how to configure wireless part.
Feb 22, 2009 | Microsoft Windows XP Home Edition
Belkin wireless G adapter shows as working but no networks
make sure the Wireless zero configuration or WLAN auto configuration service on your OS is running
Try to search for wireless network using the Belkin wireless utility after disabling windows
Nov 19, 2008 | Belkin (F5D7050) 802.11a/g/b Wireless...
Wireless zero configuration is not activated
What are you using Internet Explorer? Anyway I would try using FireFox or some other browser to see if they can complete the downloads.Then if a different browser works the one you are using is faulty and needs to be reinstalled or use the other one as default.The zero configurator is to help you setup and find your wireless conections your router will also have a wireless configutator then the one that windows comes with make sure you know which one you are using.Go to network connections and internet connections, click, then right click on wireless connection,then properties and you should have a wireless tab check to see if the box that says use windows to configure my wireless conections is checked if you want windows to do it. If neither browser finishes downloads redo wireless setup.But I really think it is the browser.Hope you understand what I am trying to say.
Apr 15, 2008 | Computers & Internet
Wired and wireless computers
First get your router works with the internet on the wired connection before considering the wireless connection simplying the initial problem.
Once the router works wired is time to try the wireless.
Once the wireless works unsecured you may want to change the router and wireless adapter to secure the wireless network.
So this can be a three step process.
If you internet service is provided by a cable(tv) there is a reasonable chance your router will work out of the box no configuration changes. However, if your internet service is supplied on the phone line chances your router will work as it comes out of the box are much less. Who is your Internet Service Provider and if possible can you supply a link to their help/support website so I can see if they supply configuration instructions?
Jan 03, 2008 | Linksys Wireless-G WRT54G Router
Computers & Internet Logo
62 people viewed this question
David Payne
David Payne
